01-09-2008, 12:58
#26 | | MIGWeb User
Join Date: Mar 2002 Location: Reading, Berkshire Drives: Omega & 1.8 Corsa B
| Re: J's Nova Project Makes me think of a Terrys chocolate orange  |
01-09-2008, 12:59
#27 | | MIGClub Member
Join Date: Nov 2006 Location: Kent Drives: ASBO Orang Nova
| Re: J's Nova Project Quote:
Originally Posted by DaveB  did you paint the insides yourself with cans or with a compressor? |
Rattle cans, dont look bad eh!! i have a compressor but Benn scared me with mixing paint n thinners n stuff  |
01-09-2008, 13:01
#28 | | MIGClub Member
Originally Posted by Davey Makes me think of a Terrys chocolate orange  | U aint seen the outside lol, its Ford ST Orange  looks awsome in the sunlight with the paint fleck, my mates call is ASBO orange  |
01-09-2008, 14:21
#29 | | MIGClub Member
| Re: J's Nova Project my heads been delayed until thursday im gutted, was so looking forward to fitting that tonight  oh well ill have to do MORE wiring and try to fix the stupid digi dash i broke  |
14-09-2008, 11:49
#30 | | MIGClub Member
| Re: J's Nova Project Hey Guys sorry for the Quiet Spell have been away with work far too much!!!
So See Below Some pics of my progress ill do my best to explain as i go
After a struggle, the bottom end is back in good old stryt brace to wrap rope around
Re wired the Alternator & starter with dedicated +V to the Battery in the correct colour
I get my head back woohooo
Wasted no time getting it installed
Trial fir the throttle bodies so i can run the fuel lines
Fuel Lines in, I run Teflon Braided from Pump to FPR, then High presure rubber return
Snapped the cam tensioner thingy, so i tapped a thred for a exhaust stud, loctited it in and away we go.
Mounted Coil pack to head this hold the old dizzy blanking plate in place
Installed ECU Harness, test fited ITG Filter Looking good imo
Thats all for now lads ill sort the rest of this pics out soon...
Hope you like |
14-09-2008, 11:59
#31 | | MIGClub Member
| Re: J's Nova Project I did have the car running, the throttle bodies were not as hard as i expected to install & setup, they took a while but WOW they sound good. I found running the hose pipe over the rad lept things in check.
Anyway i used Running in oil to start was aiming at 150 to 250 gentle miles, this passed by fast i then did the oil Filter and replaced with Gen Vaux Semi Syn.
Booted down the motorway chasing a SL55, bare in mind im nervous as it's a fresh engine, checking the Fuel presure, oil pres & temp checking water temp all ok, dumped into 5th hit 100+++mph and lost all oil preasure  Hit the kill switch dumped the clutch and coasted to the hard shoulder thinking ohh ****!
I Got out and a quick inspection reveals no oil leaks or fluid of any sort.. ok confused!! i then start it back up, i have 1 bar of presure the cams sound like a bag of nails and i think fook shut it off and call the RAC.
I get home drop the sump and OMG how stupid do i feel, the only reason im posting this is so others dont make the same silly mistake i did.
I work away alot so when i strip things i lable and take pics, well i did lable all 4 conrods & pistons 1 to 4 with a small bit of insulation tape, which obviously i forgot to take off as it was blocking my pickup  and you could still read the numbers which did make me smile
So next up is the sump, it's full of brass goldy ****!! so i drop the mains bearing's out nope all fine, dropped out the big ends and No3 has mushroomed and spun.  1,2,4 are ok thank god!
I have just finished polishing the crank, i will install new ACL bearings when i get back from work in the week, and let you all know how it goes again!!!  i do hope i have not hidden any other silly surprises in my engine! |
14-09-2008, 12:06
#32 | | Regional Co-ordinator
| Re: J's Nova Project Bugger! Hope you can finish sorting it out.
Next time mark stuff with a lil bit of paint.
__________________ Quote: |
14-09-2008, 13:58
#33 | | MIGClub Member
| Re: J's Nova Project So, as i had nothing to do i decided the nasty cam cover & lead cover needed a good clean up,
I stripped both covers with Nitro Moores, then attacked it with wet n dry, i used my drill with a wire brush attachment to get in the nooks and crannys.
while i was there i did the cam cover breather modification.
Here is the Old paint
Cam Cover painted
Painted the spark plug cover to start
Polished the letters & numbers out, gave it a coat of laquer
Fitted a new Roose Motorsport breather while i was at it
Did the cam breather modification
Dont know why i didnt do this sooner.
Now its just my engine bay that looks ****!  |
14-09-2008, 18:00
#34 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
| Re: J's Nova Project Good work mate |
14-09-2008, 19:05
#35 | | Regional Co-ordinator
| Re: J's Nova Project Why did you do the breather mod?
Love the plug cover. |
14-09-2008, 19:24
#36 | | MIGWeb User
| Re: J's Nova Project To stop the engine smoking like fook if you do a trackday |
14-09-2008, 19:27
#37 | | Regional Co-ordinator
Originally Posted by LongLiveTheNova To stop the engine smoking like fook if you do a trackday | No, i know why its done, i just dont see the point, isnt it just knacked of ones that breath heavery that do this.
Mines not done and it was fine, and mines done 140K |
14-09-2008, 20:21
#38 | | MIGClub Member
Originally Posted by Benn No, i know why its done, i just dont see the point, isnt it just knacked of ones that breath heavery that do this.
Mines not done and it was fine, and mines done 140K | your car is waaaay 2 shiney to be on track :P
anyway, when you shoot round corners you get smoke and oil surge, this mod cuts that out, any oil in the main breather gets dumped straight on the cams so again no starvation from heavy cornering.
Also it has been known that oil in the main breather pressurises the bottom end and boom... again, so i thought better to have it than not. |
14-09-2008, 20:23
#39 | | Regional Co-ordinator
| Re: J's Nova Project Have seen and knowen lots of cars to go on track and not breath heavery so not need it. |
14-09-2008, 20:25
#40 | | MIGClub Member
| Re: J's Nova Project Thanks for the comments  |
14-09-2008, 20:26
#41 | | MIGClub Member
Originally Posted by Benn Have seen and knowen lots of cars to go on track and not breath heavery so not need it. |
my old nova didnt have it and smoked round clearways at brands ill see if this one does.
but this one i intend to try and get 250bhp without a gay turbo lol |
21-09-2008, 09:44
#42 | | MIGClub Member
| Re: J's Nova Project Well the quick fix on the crank did not work  lasted 300 miles lol
So i removed the engine and worked out it was cheaper to get a newer bottom end than re grinding ect, picked up a mint engine so now i have a whole spare XE for parts.
The plan is to use my newly refurbed coscast head with the newer bottom end, the crank, rods & pistons are in better condition than my old ones so i will reuse the whole bottom end including block.
I decided on the block as i couldnt be bothered to clean all the oil gallerys out on my old one to make sure no bits of bearing was left over!
Dirty Pistons
The plan "Dont tell the misses i dont think she will miss the vase hahaha"
The outcome
Gunked the engine then painted
Re honed the bores
Found this!! http://www.migweb.co.uk/forums/other...is-cracks.html
thats as much as ive had time for this weekend... any help on the cracks would be great
J |
21-09-2008, 09:51
#43 | | Regional Co-ordinator
| Re: J's Nova Project Good work, novas do rust well there as its where the rads drip... |
21-09-2008, 10:00
#44 | | MIGClub Member
| Re: J's Nova Project your joking nova's leak ? im more worried about the crack at the tie bar mounts, not to happy bout big power with that in the front i think new front end is in order!
anyone now a place to get parts ? |
21-09-2008, 10:04
#45 | | Regional Co-ordinator
| Re: J's Nova Project Most pannel places will do the x-member, i'd weld all of the cracks, then plate over the top, much like fly did. |
21-09-2008, 10:10
#46 | | MIGClub Member
Originally Posted by Benn Most pannel places will do the x-member, i'd weld all of the cracks, then plate over the top, much like fly did. | im tempted. |
21-09-2008, 18:08
#47 | | MIGClub Member
Closer inspection revealed the X member was rottern as fook under all the underseal, i have ordered a complete new front end, spent the rest of today cutting the front out! what that has been, i know its 15 years old but damn theres some rust on the front end lol!!
Not no more! Will get picks up later  |
25-09-2008, 11:56
#48 | | MIGClub Member
| Re: J's Nova Project Smallish Update,
I have replaced all my CV boots as 2 were split, cleaned & repainted parts, just put bottom end back together its all ready to go back in the car now.
Fresh Bottom end with new ACL Dura Glide bearings in
Crank back in, pistons back in all looking nice and shiney
Water Pump & Oil Pump Back in
Sump re fitted  |
12-10-2008, 09:19
#49 | | MIGClub Member
| Re: J's Nova Project update soon, but it's running, and i need more grip! lol |
13-10-2008, 18:54
#50 | | MIGWeb User
| Re: J's Nova Project this looks awesome |
Members: 43,216
Threads: 310,618
Top Poster: LEE69 (43,150) | | Welcome to our newest member, kaytee_lou | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
