LinkBack (2) Thread Tools
Old 26-08-2008, 15:52   #76
DaveB's Avatar
Drives: Corsa XE with TBs
Re: Corsa turbo build
Peter llyod rallying for a cheaper cage than tweeks
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 26-08-2008, 15:54   #77
Rick Draper's Avatar
Drives: 2.2bar = 500bhp :-)
They only list bolt in ones dave?
Losers and cheats do win, just ask Lewis Hamilton and mclaren
Rick Draper is offline   Reply With Quote
Old 26-08-2008, 16:56   #78
Drives: EVO VI & GTE 16v
Originally Posted by DaveB View Post
It's currently sat up in the drive because the gear linkage has broken, twice.
Lost count of the number of times mine did that, gets old real quick
Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
WeeKenny is offline   Reply With Quote
Old 27-08-2008, 07:57   #79
DaveB's Avatar
With the bolt in ones you still have to weld a plate to the mounting points where the rollcage will bolt to. If you really want a weld in one then simply weld in the mounting points, and then weld the cage/foot plates to the mounting points. It's all the same really. lol
Either that or you'll have to go custom I think. I wish I'd done that and gone for a full on climbing frame in the car
Old 27-08-2008, 09:37   #80
Drives: Nova Coupe
Don't get a Custom Cage from Tweeks Rick they add quite a bit on top. Colin Smith (novarally) was telling me of a firm that des the custom cages much cheaper. PM him.
The Simps is offline   Reply With Quote
Old 27-08-2008, 09:42   #81
DaveB's Avatar
http://www.robinson-race-cars.co.uk/
Old 27-08-2008, 10:07   #82
Drives: class 7 corsa;)
daveb - the bolt in cages can be welded to the 'spread' plates BUT also have to have atleast 3 bolts in each mounting point sounds stupid i know, but there the rules if wana keep it FIA legal
philip2 is offline   Reply With Quote
Old 27-08-2008, 10:17   #83
DaveB's Avatar
Ah right, I wasn't aware of that Phil
The FIA rules'll have changed so much by the time this corsa is ready I don't think Rick'll be bothered anyway? (if he's bothered about FIA stuff to start with)
Old 27-08-2008, 10:30   #84
Will be rolling before the year is out.
Anyone know whats best to get the tar adhesive out of footwells with? Removed most of it, just sticky stuff left now.
Old 27-08-2008, 10:36   #85
Jack's Avatar
Drives: Cavalier 1.7 TD
Cavalier: Going strong, 158'900 miles and 169ftlbs.
Corsa: Never get any daylight to work on it!
Jack is offline   Reply With Quote
Old 27-08-2008, 10:48   #86
Drives: Nova Coupe
I gave it "a little" heat with the gun and then used a scraper. Came up fine.
Old 27-08-2008, 11:01   #87
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Meths or another Solvent...
Old 27-08-2008, 13:36   #88
Drives: 11secNova+GTR+CDTI
2k thinners works well and you end up high as a muther f ucker !
Gossipmotorsport.com
turbo gav is offline   Reply With Quote
Old 27-08-2008, 13:41   #89
If your looking for a custom cage try;
http://www.northoffroad.co.uk/vehicles.asp
They will create a custom cage for pretty much anything and I can vouch for their quality, having been rolled in a friends landrover a couple of times!
Looking forward to seeing the finished corsa!
stealth106 is offline   Reply With Quote
Old 27-08-2008, 14:44   #90
Went to the local trade paint place this morning and bought some stuff (spot weld drill bit, primer, thinners, panel wipe and scotch brite pads):
Got home and i set to:
Did quite well i think, only went through with the spot weld drill a couple of times!
Toying with the idea of removing this part as i am having seat bars welded in:
Old 27-08-2008, 14:49   #91
DaveB's Avatar
That needs removing if you want seat bars.
Old 27-08-2008, 15:06   #92
Thanks Dave that will be removed tomorrow then.
Old 27-08-2008, 15:07   #93
DaveB's Avatar
*edit* was going to say check neo1s thread but he's left his in.
I'm removing mine when I go side mounted on each; unsure why he still has his fitted.
Old 27-08-2008, 15:15   #94
Might have a go at starting on the loom tomorrow. Want to keep the central locking for ease really but will loose the alarm, airbag and stereo wiring.
Old 27-08-2008, 15:48   #95
getting there now, id bin the metal work around the exsisting seat mounts, and the metal plate that the selcetor rod runs down too
Old 27-08-2008, 19:01   #96
Yup i am going to gut it all. Infact i am going to do a bit more drilling now.
There might be a few little holes to weld up though where i have gone through! Not many but they need sorting.
Old 27-08-2008, 20:54   #97
I dont know whats worse, drilling spot welds or cleaning off the tar matting ****!
Old 27-08-2008, 22:14   #98
Drives: 2 fast,12 points eek
Good progress there mate, pleasure dealing with you again today, parts will be with you friday.
www.chrisastleymotorsport.com For all your Conversion, Rebuild, Fabrication e.t.c.
eBay shop: ChrisAstleyMotorsport
If there is something you need PM me or call 01257 262565
rallyman is offline   Reply With Quote
Old 28-08-2008, 05:15   #99
Fow16v's Avatar
Drives: Astra Coupe Turbo
looking good mate, supprising how much wasted metal is in there just being extra weight, gonna be watching this build should be another good one
WELSH Member
Fow16v is offline   Reply With Quote
Old 28-08-2008, 06:59   #100
answer....both, think i will have to get a spot weld drill like that, one i had, has a sprung centre, ****ing ****e kept slipping!
as for the holes, just let us know what want doing, and it'll be done
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/370074-corsa-turbo-build.html
Posted By For Type Date
Projects & Restorations on MIGWeb | BoardReader This thread Refback 05-11-2008 23:02
MIGWeb | Site profile | BoardReader This thread Refback 03-11-2008 23:40
Members: 42,547
Threads: 308,192
Top Poster: LEE69 (42,904)
Welcome to our newest member, angelillo
