More work an the inlet ports...
...worked on the upper part (rounded the edge at the 45 angle) and more work on the lower section of the port...
This is the upper part of the inlet port: (It is facing down now as you can see)
I tried to round up the angle from the 45 to the roof of the port to speed up the in comming air/fuel mixture.
Lower part of the inlet port:
Photo was taken with inlet plenum attached.
As you can see there is still a spot where i need to fill some material to fix the angle.
Just take a look in the back!
The darker area is added to blend in the base plate port with the inlet port. There is no visible edge or so where the manifold touches the inlet port (at the bottom). The top still needs to be worked on !.
Hope this is not boring for all of you who are watching this but the head work takes a whole lot of time and hopefully i will be finished with the port job this week.
After the port job i will work on opening up the valve seats. For that i have to machine all the valve guides. Found some very good ones on the exhaust side !!!!
Thats it for today
