Worked on the inlet valves.
polishing top and bottom:
Valves where sanded and polished with several grits.
(starting with 320 and right now the are polished with 800 grid).
They will receive a second polishing process with 1000, 1200, 1600, 2000, 2500 and i will finally use polishing wax to a mirror finish.
800 grid finish:
custom inlet versus stock inlet (left oversized/right stock):
Check out the shaft's do you see the difference? (will flow better than stock)
Of course they are bigger than stock:
If anybody is interested in custom c20ne 2.0L 8v OHC inlet valves drop me a line. I have a couple sets for sale. They are far from beeing expensive!!!!
