Old 08-08-2008, 17:42   #1
Drives: corsa let ph3.5
corsa let rebuild
seeing as how its melted a piston after a month of being running im going to rebuild it to a higher spec, looking for a round 400bhp but well see how it goes. going for 87mm omega pistons with steel rods t34 turbo with external wategate xe cams solid lifters etc and dta managment and a quaife diff with equal length shafts to help put it to the road
pic of car before it died
melted piston
engine stripdown
damage to bore
block is scrap so getting another block tomorrow so can get that bored to 87mm and start ordering bits
just had crank back from regrind will get pics up tomoz, hopefully will be running and mapped before the end of the year
stoner_corsa is offline   Reply With Quote
Old 08-08-2008, 17:49   #2
Drives: corsa-c c20let
Re: corsa let rebuild
hey m8..its ben off bebo..gd luck wiv the new engine
showcorsa is offline   Reply With Quote
Old 09-08-2008, 06:43   #3
Drives: class 7 corsa;)
might pull me finger out and get top end done for ya
philip2 is offline   Reply With Quote
Old 09-08-2008, 09:48   #4
donvaux's Avatar
Drives: Corsa GSI c20let WIP
gutted for you mate, a nice innovate wideband setup is on the must list then, what oil pump are your going to use?
If in doubt give it a klout
donvaux is offline   Reply With Quote
Old 09-08-2008, 09:51   #5
hes got a gm one with the SBD inner steel gear
Old 09-08-2008, 09:54   #6
donvaux's Avatar
not going for the z20let?
Old 09-08-2008, 10:02   #7
you'll be suprised how many people are going for the old gm hosuings/pumps now.
the quality of the pump gears on new ones are good, but castings are poor.
+ why spend more money to say you've got a zlet pump, when an SBD one is as good? doesnt really make sense
Old 09-08-2008, 10:05   #8
donvaux's Avatar
far enough dude just a thought
Old 09-08-2008, 10:08   #9
dont mean to sound like having a go lol, but same with coscast heads...you dont have to have one just because everyone else says so.
when yours gona be on the road anyway? might have a build off with you
Old 09-08-2008, 10:16   #10
donvaux's Avatar
the rain is stopping play at the mo so i don't know
Old 09-08-2008, 11:09   #11
Drives: Mk4 Astra SRi Turbo
bout time u pulled your finger out phil.....
sri turbo
andyj775 is offline   Reply With Quote
Old 10-08-2008, 08:56   #12
got an sbd pump thre and there good so mite aswell use that rather than spend anymore money on sumthing ive already got, yeah come on phil get ya finger out. mite be getting a job lot of some go faster bits in exchange for some standard ones
Old 10-08-2008, 09:02   #13
eh?:S wot u mean?
Old 11-08-2008, 13:15   #14
had the crank back from regrind now and ive got my new block all cleaned up ready for re-boring
and i thought id have a go at some body work so ive smoothed the badge recess off my gsi bumper, still a bit rough just put some couler on to see highspots
Old 14-09-2008, 10:51   #15
had my block bored and finished to 87mm now and decided to give it a lick of paint
also had my morrettes painted and removed and meshed the inner lamps to get plenty of cool air in there once its back on the road, also finished smoothing and painting my bumper, hoping to get the solid lifters shims and double valve springs this week to get head built then i can order pistons and gaskets to build the bottom end
Members: 42,546
Threads: 308,175
Top Poster: LEE69 (42,903)
Welcome to our newest member, davidg
