03-11-2008, 20:45
#26 | | MIGWeb User
Join Date: Aug 2002 Location: Northwest Drives: Phase 2 GSi
| Re: My Astra GSi project Thanks for the commets
Pics from the weekends antics:
Broken bits: front spring hence the funny noises and part seized bearings:
Eibach springs fitted:
Discovered that the front anti roll bar is 26mm thick any ideas ?? I thought they where 22 as standard
Calibra turbo master cylinder compared to standard gsi one on the left:
Fitted:
Hi Specs fitted and all bled up ready to rock
Need to get some rear GSi goodridge hoses next as the ones from my gte dont fit
More soon ! |
03-11-2008, 21:14
#27 | | MIGWeb User
Join Date: Oct 2001 Location: Bedfordshire Drives: Cavalier SRi
| Re: My Astra GSi project Looking good  but i think your springs may be upside down
__________________ The cake is a lie :( |
03-11-2008, 22:17
#28 | | MIGWeb User
Join Date: Dec 2005 Location: glasgow Drives: astra gsi j93 let
| Re: My Astra GSi project nice 2 c another mk3 getting some nice kit on it
__________________ 260bhp ,280lbs of torque |
11-11-2008, 21:30
#29 | | MIGWeb User
| Re: My Astra GSi project Quote:
Originally Posted by SteveM Looking good  but i think your springs may be upside down  | They only fit one way round, would have to be with the writing upside down lol
Small update  Got my painted rocker and cambelt covers back from the paintshop, had them done the same colour as the car and Im well pleased with them, these pics dont do them any justice at all
Started to tidy up the F28 too, steam cleaned it and a few coats of hammerite smooth silver
Should have the 2wd conversion kit and new drive shaft/input shaft seals this week.
11-11-2008, 23:56
#30 | | MIGClub Member
| Re: My Astra GSi project Thats very nice indeed  |
13-11-2008, 08:53
#31 | | MIGWeb User
Join Date: Apr 2007 Location: West Yorkshire Drives: V6 Astravan/2.0 Nova
| Re: My Astra GSi project Will be keeping an eye on this! im liking the way its going! |
14-11-2008, 13:30
#32 | | MIGClub Member
Join Date: Jul 2001 Location: Liverpool Drives: ESCORT COS,MK4 SRiT
| Re: My Astra GSi project |
15-11-2008, 21:38
#33 | | MIGWeb User
| Re: My Astra GSi project Cheers for the comments guys
If anyone remembers my old GTE then you`ll know it was something special and Im hoping to go one better with the GSi  |
15-11-2008, 23:02
#34 | | MIGClub Member
Join Date: Jun 2003 Location: Portsmouth Drives: 2.0 Sport / 1.9CDTi
| Re: My Astra GSi project Excellemt project car, look forward to the progress.
Just out of interest (I have a 2.0 Ecotec Sport) what's the advantage of fitting a Calibra turbo master cylinder compared to standard gsi one?
Does it give more pressure / harder pedal? I use my Astra on Track days with a V6 vectra upgrade and the pedal gets quite spongy when they get hot.  |
16-11-2008, 21:08
#35 | | MIGWeb User
Originally Posted by giles473937 Excellemt project car, look forward to the progress.
Does it give more pressure / harder pedal? I use my Astra on Track days with a V6 vectra upgrade and the pedal gets quite spongy when they get hot.  | Thats it, the turbo cylinder has a larger piston than the standard Gsi one so it gives a much better feel to the brakes when using calipers with a bigger than standard piston or when using aftermarket multi piston calipers. |
23-11-2008, 21:07
#36 | | MIGWeb User
| Re: My Astra GSi project Been doing a bit on the engine over the weekend, got the gearbox off and took the clutch and flywheel off to discover I was right about the rear crank seal leaking !
Nice and oily lol
Yup !
Then got it on the stand to remove the sump and fit the new 8v gasket/baffle plate.
Decided to fit ARP rod bolts whilst Its apart why not hey
Finally gave the sump a good clean and fitted a new oil seal to the level sensor as it was also leaking from there.
F28 almost ready to go in, 2wd conversion kit, new driveshaft seals, and modded F20 quick shift all fitted
Going to be having a go at making a custom steel rear mount soon to avoid any breakages
Waiting on the front mounting bracket and release bearing fork to show up now. Just hope the box is a good `un !
ARP rod bolts arrived, will be fitting these this week along with new bigend shells, just need to get the crank measured to check the size.
Cleaned out all the bolt holes for the sump bolts suprising how much crap came out lol
And sorted out how I want the Electronic clocks to be like, combination of GSi rev counter and fuel/temp gauges fitted with the red needles.
More soon ! |
23-11-2008, 22:21
#37 | | Regional Co-ordinator
| Re: My Astra GSi project Looks like its gonna be a weapon dude.
__________________ Quote: |
24-11-2008, 14:18
#38 | | MIGClub Member
| Re: My Astra GSi project Some nice work there  |
24-11-2008, 18:52
#39 | | MIGClub Member
Join Date: Sep 2007 Location: Co Durham Drives: Astra 2.0 16v Sport
| Re: My Astra GSi project Really nice car/project mate. Great work so far. Hope all goes to plan.
__________________ I used to jog 5 miles a day; then I found a short cut |
24-11-2008, 23:00
#40 | | MIGWeb User
Originally Posted by Benn Looks like its gonna be a weapon dude. | Definately, I cant wait now missing the turbo too much and cant take much more of the ecotec  |
16-12-2008, 21:17
#41 | | MIGWeb User
| Re: My Astra GSi project Time for a little update, got my new lightweight billet steel pot flywheel yesterday from vxlgsi
Weighs about 5 kgs which is lighter than a standard flat one ! Now I can use the proper turbo clutch setup and that should be here this week fingers crossed, I will weight the two setups just to compare them.
Glyco bigend bearing shells from steveboyslim  , these are the wider type LET ones as I had mistakingly bought XE ones which are thinner so would of been no good to me.
Oil cooler bits, I had bought these to fit to the GTE but never got round to doing it, going to fit the cooler behind the bumper like in the pic so will be losing the foglights and using the hole to make a proper duct for it.
Mocal 16 row 115mm matrix cooler and late type sandwich plate
And a large intercooler, 2.5" inlet and outlets.
Using these to stick the sump gasket and seal the flywheel/sump bolts up.
More soon  |
16-12-2008, 21:36
#42 | | MIGWeb User
Join Date: Mar 2002 Location: suffolk Drives: Corsa Tbo n Prelude
| Re: My Astra GSi project coming togther mate, oil cooler is nice and tucked away wish i had room to do that on my corsa
__________________ Bring back the power of LET |
16-12-2008, 21:55
#43 | | MIGWeb User
Join Date: Oct 2005 Location: ThickFord, Shrops... Drives: around looking Cool!
| Re: My Astra GSi project I would say the anti roll bar is very aftermarket seeing as it is PURPLE
__________________ (='.'=)
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot! |
16-12-2008, 22:40
#44 | | MIGWeb User
Join Date: Jun 2007 Location: leeds Drives: vectra 2.6 v6
| Re: My Astra GSi project Stunning M8 Makin Me Well Jealous I Want Another 1 Now Keep Up The Excellent Work Bud. |
16-12-2008, 22:55
#45 | | MIGClub Member
Join Date: Nov 2008 Location: Luton Drives: astra saloon xe soon
| Re: My Astra GSi project :d:d Proper Nice Car M8 :d:d
__________________ I LIKE BIG BOOTS AND I CANNOT LIE :) |
17-12-2008, 01:31
#46 | | MIGClub Member
| Re: My Astra GSi project Some nice bits there bud, I like that oil cooler thats uber cool  |
17-12-2008, 06:34
#47 | | MIGWeb User
| Re: My Astra GSi project nice work !
i loved your car color.
keep it up |
17-12-2008, 12:30
#48 | | MIGWeb User
| Re: My Astra GSi project What a lovely motor matey, i wish i had never sold mine now, keep up the good work....
__________________ Not sure what Engine...... V6 or Turbo????? |
17-12-2008, 13:20
#49 | | MIGWeb User
Join Date: Sep 2001 Location: SW Wales Drives: Project Nova GLF
| Re: My Astra GSi project at the back of the box i had to put some bolts back into the holes because my box was chucking the fluid out the back
check up on that
__________________ Nova GLF 2006... Coming Soon |
17-12-2008, 14:15
#50 | | Regional Co-ordinator
Join Date: Sep 2001 Location: Somerset Drives: '88 Astra GTE 16v
| Re: My Astra GSi project Its coming along really well Tom.
You decided what your doing with the Turbo/down pipe we spoke about yet? Im up north (Blackburn) a fair bit in January.
__________________ Lewis Hamilton - Vodafone McLaren Mercedes - 2008 FIA Formula One World Champion |
Members: 43,214
Threads: 310,613
Top Poster: LEE69 (43,150) | | Welcome to our newest member, chrismessenger | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
