LinkBack (7) Thread Tools
Old 05-08-2008, 13:52   3 links from elsewhere to this Post. Click to view. #26
Drives: Like its stolen
Re: astra gt35r
Mark Shead is a friend of mine, I was at the dyno yesterday with him in fact, you are in VERY good hands with him
chip is online now   Reply With Quote
Old 05-08-2008, 14:08   #27
Re: astra gt35r
With theese cams and this turbo revs easy at 9000 rpm.
I would prefer cams at 260-270.
Astra Gsi Turbo
kontraman is offline   Reply With Quote
Old 05-08-2008, 14:18   #28
Re: astra gt35r
we will see...
all parts in fibre glass
Originally Posted by philip2 View Post
where abouts are you from? any more pics of the inlet?
sorry mate, i have not more pics of inlet, this is pics of exhaust:
original
work finish
remy16t is offline   Reply With Quote
Old 06-08-2008, 13:22   #29
Re: astra gt35r
Hi,
do you know where is possible to buy diff bearings for f28 or f20 4x4??
in france at opel it is not possible....
i asked here and no answer http://www.cav16.co.uk/pricesf28.htm
do you have link or adress please?
Old 06-08-2008, 19:59   #30
Drives: class 7 corsa;)
Re: astra gt35r
think if you do a search for: pitstoppete
he will know where to get the bearings your after or should do.
good to see you havent gone huge on the exhaust ports. thought may of been close inlet size to breaking through into water/oil ways
philip2 is offline   Reply With Quote
Old 06-08-2008, 20:28   #31
RJM
RJM's Avatar
Drives: corsa gsi turbo
Re: astra gt35r
PM steveboyslim about diff bearings,he has them.
RJM is offline   Reply With Quote
Old 07-08-2008, 12:26   #32
Re: astra gt35r
thank you very much
Old 22-08-2008, 18:23   #33
Re: astra gt35r
hello all
we have start to build inlet manifold
the length was calculed for have acoustics of filling to 6500trs.
Monday we will finish
Old 06-09-2008, 12:13   #34
Re: astra gt35r
inlet manifold finish,
this week we finish to paint and weld the car and last week we will install engine
Old 06-09-2008, 12:17   #35
Drives: Fiesta XR2i 16v
Re: astra gt35r
Nice project. Where did you get the fibreglass body panels? Loving the inlet manifold. Should be a tarmac beast when built!!
Lewis Hamilton - Vodafone McLaren Mercedes - FIA F1 World Champion 2008
Still Building a valver nova...
Pete_58 is offline   Reply With Quote
Old 06-09-2008, 12:40   #36
Re: astra gt35r
thank you.
I have buy all parts in fibreglass in France here : http://www.mcracingsa.com/OPELASTRA%20GSI.htm
Old 06-09-2008, 12:50   #37
Drives: Astra MkI
Re: astra gt35r
Cool project..
you will gain huge amount of power my friend
Kadett GT/E
Sometimes you are the bug
sometimes you are the windsheild
InsaneSwede is offline   Reply With Quote
Old 06-09-2008, 12:57   #38
Drives: Astra MkI
Re: astra gt35r
Honestly guys..
a well tuned engine should have same register,turbo or non turbo.
of course it´s easy to leave camadjustments and get a very revhappy engine.
(but i should take it easy above 8300-8500rpm with std oilpump.)
If you let it take some time in dyno to adjustcamshafts you can gain HUGE amount of torque even with those camshafts.
mine 272´s has almost as much liftarea as your camshafts.
(how long the valves stays at full lift under duration)
if i run my camshafts in for example DesktopDyno2000 they should rev a the way to 10300rpm... but they do not.
my engine has peak power just before 7800rpm.. around 7400 actually.
Old 06-09-2008, 13:25   #39
Re: astra gt35r
Thank you very much.
I think now the most important with this cam is a very good engine management.
Old 06-09-2008, 20:14   #40
Re: astra gt35r
we have start to prepar car for weld
Old 06-09-2008, 21:03   #41
Drives: Cavalier SRi
Re: astra gt35r
Awesome project mate
SteveM is offline   Reply With Quote
Old 06-09-2008, 21:16   #42
Drives: mk3 astra turbo
Re: astra gt35r
mint project you have there, never seen any body put fiberglass parts on a mk3 astra before will be interesting to see it when finished.
16vastraturbo is offline   Reply With Quote
Old 07-09-2008, 10:41   #43
Re: astra gt35r
thank you very much guys.
Old 16-09-2008, 14:11   #44
Drives: Astra GSI MK3 GT28
Re: astra gt35r
What a wonderfull project!!!!!!
il sera très rapide!
I have some curisosity about some special parts...
why you choice the X20XER cranck? It is stronger?
The bottom griddle is standard or customized?
The Engine mount kit is for F28, correct? Where you buy it? It is standard or special?
Where do you fit the oil spray cooling jet? And where you buy these?
Thanks, Luca
avantrax is offline   Reply With Quote
Old 16-09-2008, 15:26   #45
Re: astra gt35r
Great luca you speak a little bit french my friend
so i have buy oil spray colling jet at vauxhall (opel) that comes to isuzu 1.7 (x17xe) Autovaux sell them
x20xer crank is stronger yes!!
engine mount kit is for c20xe so for f20 and not for f28 it is necessarly to modify for install f20 but that is very easy.
i have buy that at harry hockly
http://www.hh-ms.com/database/index....bCategoryID=17
Old 16-09-2008, 15:27   #46
Re: astra gt35r
Movie my engine rebuild and an other project golf vw (2l 16s)
http://www.youtube.com/watch?v=OwMZ72gCBA4
Old 16-09-2008, 18:04   #47
Re: astra gt35r
Merci beaucoup pour ton aide! ;-)
(sometimes i went in France for business: very close to the Pyrenees...wonderfull place)
Do you have a picture about where you fit the oil spray colling jet, please?
It is very interesting
You fit the original lower chassis of the astra, correct?
I'm thinking about to fit the lower chassis of the calibra turbo that has the space for the F28 mount: what do you think about?
Ciao !
Old 17-09-2008, 12:49   #48
Re: astra gt35r
hi luca
yes you have space but engine mount kit is for f20
pics oil spray jet
Old 17-09-2008, 17:47   #49
Re: astra gt35r
Thanks a lot my friend!
How many HP is you target?
Old 17-09-2008, 19:10   #50
Drives: vectra 2000 16v 91`
Re: astra gt35r
Looks really good , will be really fun to drive
C20XE , machined down pistons , MS-I v3.0 , twin TD04H-13C turbos , unknow amount of boost , no grip in 4th after 4.5k RPM and blue smoke out of exhaust :D
GeorgeGt is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/368385-astra-gt35r.html
Posted By For Type Date
GOLFOO :: Voir le sujet - Un VR6 au soleil !!! Photos By Night P.67-68 et 69!! This thread Refback 08-10-2008 17:52
GOLFOO :: Voir le sujet - Un VR6 au soleil !!! Photos By Night P.67-68 et 69!! This thread Refback 07-10-2008 19:18
GOLFOO :: Voir le sujet - Un VR6 au soleil !!! Photos By Night P.67-68 et 69!! This thread Refback 07-10-2008 18:53
GOLFOO :: Voir le sujet - Un VR6 au soleil !!! Photos By Night P.67-68 et 69!! This thread Refback 07-10-2008 18:50
i Malati Mentali dell'ASTRA f - 5 - - Pagina 70 - ElaborarE-Special Forum This thread Refback 16-09-2008 13:46
i Malati Mentali dell'ASTRA f - 5 - - Pagina 70 - ElaborarE-Special Forum This thread Refback 16-09-2008 13:39
i Malati Mentali dell'ASTRA f - 5 - - Pagina 70 - ElaborarE-Special Forum This thread Refback 16-09-2008 13:18
Members: 43,214
Threads: 310,613
Top Poster: LEE69 (43,150)
Welcome to our newest member, chrismessenger
