Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 25 of 158
Thread: Mini - Now c20xe build
    Feb 2008
    weston-super-mare
    20xe mini + 20xe corsa b
    Thumbs up Mini - Now c20xe build
    thought id post up a build diary of my 2l 8v mini project feel free to leave tips and advise about the tuning of this engine or general coments cheers guys
    started out a a 1275
    i managed to mince the front end and the it looked like this
    then i decided to pullit all apart and decide on a engine choice
    after buying a tuned a series and began weiging up the cost of a straight cut gear box and other bits i needed and the lack of reliabiliy id have i decided to go for a vauxhall lump and chose the 8v as i met a guy called terry who told me i could get one in a standard length front
    i got the standard mini subframe modified beond belive and then i had this
    sorry crap picture
    Feb 2008
    weston-super-mare
    Re: my mini c20ne project
    i then set out and found a tidy 79.000 mile calibra
    and did this to it
    and put the engine strait in the mini subframe these engines aint light lmao
    thought id put my back out lol
    and after that all the driveshafts and wheels went on to get a look and check everything was as it should be ie driveshafts
    Feb 2008
    weston-super-mare
    next i upgraded my rear shocks to coilovers for better rear end grip
    see even the spider likes them lol
    Moderator Melv's Avatar
    Dec 2006
    KEITH, N.E. SCOTLAND
    1.8 Corsa Merit + ACT
    thats a fair old project there. Will adding a heavier engine in the front not throw the handlilng all to funk though?
    Mar 2008
    Carshalton, Surrey
    BMW E36 M3 3.0
    Been in a mini EX, cammed, throttle bodies and nos, crazy, and you genuinly had that feeling of relief when you got out alive. This should be a torquey little street sleeper when it's finished.
    Plans for the engine itself, or just keep it standard?
    Official Migweb Pervert!
    Aug 2003
    Durham
    Is that front bracing strong enough for the job, what is it 1" box section ?
    Awaiting Email Confirmation
    Dec 2007
    port talbot, s wales
    corsa xe gsi rep
    the engines int he calibras are c20seh which are 15 bhp more than the c20ne , their 130bhp as the ne has 115 , just thought id let you know
    MIGWeb User neil105's Avatar
    Oct 2004
    cullen NE scotland
    astra gte turbo
    you still on mini fount hubs,how did you manage the engine mounts
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    Quote Originally Posted by rwdmad View Post
    their is no such engine as a c20seh and the engine he has fitted is a c20ne which is 115BHP when new to be honest if you are gonna keep this engine i would look for a 20seh cam as this will make it run a bit stronger but not much you could fit the rest of the 20seh stuff but you could pick up a whole engine for 」100 without loom and then just get the ECU and fit that and would then have 130BHP
    some handy links for you
    20seh and c20ne differences
    tuning a 2.0 8v 20seh
    sorry to hijack a little bit but other than that looks like a good build my mate has just done a rover 216 engine(honda one) conversion with subframe and flipfront on his mini then sold the whole conversion afterwards and has gone back to 1275
    Feb 2008
    weston-super-mare
    just to update you all yes the subrames is made strong enough and there a 3 others on the road with the same subframe
    yes its got mini suspension and hubs so i still have mini handling charachteristics but with a heavever front end
    my plans are to firstly strip all unnessasary weight ie persex windows
    and im in the process of trieing to sourse se block or pistons as there higher compression
    a spare head to have skimmed and ported and polished
    and a kent cam
    but will drive with the stock ne for a while still hass 122 fp or torque and 113 bhp
    bear in mind i will have no cat and a 4 branch manifold
    cheers for the advice and links astra-nige
    Feb 2008
    weston-super-mare
    heres pic of the custom 4 branch
    Feb 2008
    weston-super-mare
    had a leaking sump so had to be welded because im to tight to buy a new one lol
    Dec 2007
    corsa xe gsi rep
    Quote Originally Posted by astra-nige View Post
    well 20seh then and i think evryone knows that it still wont be 115 now, and i had a calibra which had a 20SEH so i should think thats what in his.
    Dec 2007
    corsa xe gsi rep
    but he looks like he knows his stuff so perhaps im wrong lol
    Oct 2003
    glasgow/oban
    like its a hire car
    tbh Id have gone for a dispak 1600 8v with a four branch and a cam for preference, if youre going to suffer the weight of the big block andgine and box you make as well have the 20xe.
    minis are cool tho!!
    Feb 2008
    weston-super-mare
    ive gone for a 8v as it fits under a standard length front 16v need a extended one
    and my engine is deff a c20ne as its got it stamped on the block its just a seh without the higer comp pistons, ecu and cam
    but im deff after a seh
    this is it be4 i sprayed the front
    Feb 2008
    weston-super-mare
    thats it all sprayed up
    Jan 2005
    saab astra mk3
    look ace man, where about in the world are you as my 20seh might be getting replaced at some point so could sell you that in a few months time, if you do find a kent cam mate dont bother as the differnece between that and a 20seh one is minimal apparently
    it looks like a tight squeeze down the front of the block and manifold looks ace
    Jul 2007
    aberdeen
    mk3 astra gsi c20let
    look good man.
    i was think ing about that too last year but now im led to beleive that the 16vminishop run by matt has shut its doors.
    thats the easyest place for parts.
    Mar 2002
    Norwich
    Corsa 1.2 & 08 YamR6
    Looks sweet and fookin tight lol
    I hope you're going to stick with the mk1 grille as in the 1st pic
    Mar 2008
    Weston-super-mare
    nova 2.0
    awsome
    Dec 2005
    Solihull, W.Midlands
    118d,G1.8SE2,C1
    nice, wierd how the engine just looks so "right" in a mini!
    Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
    Aug 2008
    Sale Victoria Austra
    Calibra Turbo
    thats awesome. Great Project got a mate here in Aus thinking about doing the same to his MINI. Have you got it running yet?
    Sep 2003
    Johannesburg
    Now that's shoehorning in an engine.
  26. #25
    Sep 2004
    Devon
    Cav V6
    Good work mate. Good old 8v, cracking engine.
  1. 03-03-2011, 14:19
  2. 11-12-2010, 12:53
  3. 04-12-2010, 22:40
  4. 05-11-2010, 04:11
  5. 05-11-2010, 01:38
  6. 21-10-2010, 07:49
  7. 22-08-2010, 16:57
  8. 25-03-2010, 01:11
  9. 11-01-2010, 09:22
  10. 10-03-2009, 16:04
  11. 08-03-2009, 13:31
  12. 20-11-2008, 13:02
  13. 24-09-2008, 09:59
  14. 22-09-2008, 13:06
  15. 18-09-2008, 12:06
  16. 17-09-2008, 18:08
  17. 17-09-2008, 11:35
  18. 17-09-2008, 08:05
