Old 27-07-2008, 16:53   #1
Drives: Project Nova GLF
Advice on engine bay "tidy up"..
Engine is from my pink courtenay turbo nova, but now running on stand alone management!
Im better now and ready to make this look presentable for what shows there are left.
Heres how it looks now..
The messy boost pipe is due to my DIY coilbraket not leaving much room between it and the pedal box! Need a new place to mount my coil and a new pipe! Whats the best place and way to do it (Ford Coil)?
Shall i leave Longlife make me a bit of pipe or buy a TX Autosport type item?
Obvious one is cam covor colours, opinions please? (Im at Black, O.E Style Silver, or Red?)
Distributor Blank, which one shall i get and from where?
Nova GLF 2006... Coming Soon
elgan is offline   Reply With Quote
Old 27-07-2008, 17:18   #2
donvaux's Avatar
Drives: Corsa GSI c20let WIP
Re: Advice on engine bay "tidy up"..
sbd do a blank for £26.80 and seal 60p
If in doubt give it a klout
donvaux is online now   Reply With Quote
Old 27-07-2008, 17:40   #3
Mark_F's Avatar
Drives: Snae a vaux.
Get rid of the plug cover, makes the bay look extremely messy. I'll buy it.
Mark_F is offline   Reply With Quote
Old 28-07-2008, 09:31   #4
Drives: Astra GSI 1.8 16v
What you doing with the pink Courtenay Nova? I was thinking about buying it years ago but for the colour .
DeXx250 is offline   Reply With Quote
Old 28-07-2008, 10:15   #5
Drives: 118d,G1.8SE2,C1.2SXi
If your head doesnt rotate 90 degrees.
Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts.
MarkyG is offline   Reply With Quote
Old 28-07-2008, 10:20   #6
Looks pretty mint to me, only needs a quick clean and it would be immaculate.
I would.
1) Peek polish, all the shiny bits. Only do the large open surfaces or the polish gets trapped in crevices and its a bas tard to get out, plus you won't notice it anyway.
2) Hammerite the matte silver thing in bottom right (my picture) and anything else looking grubby (gubbins under master cylinder reservoirs etc?)
3) Dashboard wipes all the other stuff including plastics and hoses (Shell garages sell these dashboard wipes in yellow packaging, they leave a satin finish and are great for engine bays).
4) Spray the engine cover a proper colour, matte/satin black would be nice.
Old 28-07-2008, 10:26   #7
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Rocker cover in OE look metallic Silver. Replace plug cover with a minty Red OE look one.
Strut brace, header tank & wiper motor & plate etc all done in satin black powder coat.
Polish/wax up the inner wings etc. Clean hoses as replied earlier. Its just a matter of simplifying all the colours & making sure whatever is there is clean.
V8 blender FTW
Old 28-07-2008, 10:50   #8
QED for the dizzy blank. £ 16 odd pounds! 01509 412317
Old 28-07-2008, 11:35   #9
Benn's Avatar
Drives: A shineeeey Nova
What going on on the scuttle?
Sort out and hide the water pipe from guessing the turbo wit that nasty joiner bit in, run it under the slam pannel,
Repaint the wiper motor and backing plate, maybe get a scuttle cover that fits abit better,
Clean/paint any other bits, inner wings clean and wax them up and so on..
Benn is online now   Reply With Quote
Old 28-07-2008, 11:40   #10
CraigGreen's Avatar
Silver wing bolts are an eye sore too. Take them out & flame Red them.
Old 28-07-2008, 11:51   #11
Drives: 13.4 Champ LET
I did it on mine. still got bits to do though. had to pull it all out again to try and cure a misfire before Billing I've polished up as much as possible just need a few bits like boost pipes, a bracket for the AFM, new battery bag and bigger heat shield for the turbo. alls left to do is try and find a company that'll build me an alloy header tank
BazW is online now   Reply With Quote
Old 28-07-2008, 12:11   #12
Rick Draper's Avatar
Drives: 2.2bar = 500bhp :-)
Move to remote brake reservoirs on the pedal box.
Losers and cheats do win, just ask Lewis Hamilton and mclaren
Rick Draper is offline   Reply With Quote
Old 28-07-2008, 12:46   #13
Drives: 2 seat 2.2 vxl
or get properly integrated MC's that are fairly subtle
http://www.slindborg.host.sk/index.php Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, nova build guide, coming soon z22se build guide
cambridge is offline   Reply With Quote
Old 31-07-2008, 19:24   #14
ok heres where i am tonight.
QED dizzy blank, re positioned coil bracket, new boost pipe and silicon hose!
Engine covers are to be picked up 2mro morning, this ones just temporary.
Re fitted battery tray cover
Turbo cover is out for a scrub down and some plastic care.
Next on the list
Paint: Wing bolts, wiper motor (all black) and Brake Pedal Box
Gearbox de greased and steam cleaned
Detail clean pass side of cylinder head
Re do radiator hoses around the T Piece Area
Polish all S/Steel and Paint work
Re fit S/Steel Manifold Cover and Carbon Plug Cover!
Old 31-07-2008, 19:26   #15
Oh also, any one recommend steps to polishing the stainless pipe that the boost pipe is made of? Materials and Polishes etc
Old 31-07-2008, 19:28   #16
Drives: 200TS REP.VEC GSi
I take it the engines in E1GAN mate,what you gonna do with the other million shell's you got?
That's bloody brilliant that is!
gwillzy is offline   Reply With Quote
Old 31-07-2008, 19:42   #17
Fow16v's Avatar
Drives: Astra Coupe Turbo
looks so much better with just the dizzy blanked etc. depending how polished you wnat the stainless, i got a good finish on a cover i made a few days back just by using a very fine grade wire wool and some brasso, not a mirror finish but one that i was more than happy with for the cost
WELSH Member
Fow16v is offline   Reply With Quote
Old 31-07-2008, 20:29   #18
Benn's Avatar
Originally Posted by elgan View Post
Much better all ready.
If you can take the boost pipe off and get it polished propperly on a wheel with a good soap
Or on a drill with some auto sol..lol
Old 04-08-2008, 16:36   #19
had it all tidy and ready for USC show and shine on Sunday
On my way up saturday, engine died while motorway cruising.
Pulled up, checked fuel and spark. AA came out, 50 PSi compression across the board : (
Pulled the top timing cover bolt off and pulled it back, cranked it over, can get one cam to line up to the marking and one is about a tooth out. Havnt had a chance to strip down yet, but im guessing the belt has jumped a tooth. Hope its not terminal.Once its all apart and i can survey the damage i will then decide what bits to spend my money on.
Old 04-08-2008, 17:12   #20
Benn's Avatar
Ah bugger, hope the damage is not too bad
Old 05-08-2008, 10:14   #21
CraigGreen's Avatar
Should be OK at 1 tooth, but odd that is broke down. Fingers crossed for you mate, its not too bad.
Old 05-08-2008, 12:52   #22
i had the base map tweeked during the week to better the driveability.
its only running std actuator pressure for the moment.
pic shows how empty the engine bay is (compared to most LET's ive seen)
Old 05-08-2008, 16:30   #23
Also dont T piece the rad hose, just have another outlet welded on the bailey header tank, it looks mines better.
Old 05-08-2008, 17:51   #24
Benn's Avatar
Looks alot better, as rick said on the water pipe..
Just noticed that this is the engine from mr pink, what happened to the tb'ed lump?
Old 05-08-2008, 17:54   #25
Drives: 12.8 Nova LET
I'd personnally get the boost pipe equal size all the way through if it was me, bend looks like a cheap knock up to me and probably restricts air flow. What management are you running?
Dave.
Vauxhall's breaking and wanted for breaking pm me.
Nova GTE LET 12.841 @ 110.99
DaveMarshall is online now   Reply With Quote
Members: 42,547
Threads: 308,198
Top Poster: LEE69 (42,904)
Welcome to our newest member, angelillo
