06-08-2008, 22:19
#26 | | MIGWeb User
Join Date: Sep 2001 Location: SW Wales Drives: Project Nova GLF
| Re: Advice on engine bay "tidy up".. Omex 600. The bend is made on a regular exhaust bendin machine. surface area is the same, but the shape changes. i want an enlarged top hat which retains the std "TURBO" cover too if anyones got one up for grabs!
__________________ Nova GLF 2006... Coming Soon |
07-08-2008, 16:13
#27 | | MIGWeb User
Join Date: Jan 2002 Location: southampton Drives: sm2'd, T3'd let nova
| Re: Advice on engine bay "tidy up".. surface area changes, need it mandrell bent
__________________ [quote]The Simps;
If you find the water leak and its a hole that needs welding up gimme a shout[quote] |
07-08-2008, 16:43
#28 | | MIGWeb User
| Re: Advice on engine bay "tidy up".. im not quite sure how to explain it. but am i right in saying the volume stays the same? i know its not ideal tho, only thing for it at the moment is the smooth airflow. |
07-08-2008, 17:05
#29 | | MIGWeb User
at this stage today tho, good news is all the valves are seated perfectly with the cams off. going for a check over and pressure test 2moro anyway tho.
will get the inlet manifold off and cleaned/painted next. |
08-08-2008, 00:20
#30 | | MIGWeb User
| Re: Advice on engine bay "tidy up".. will do the job for now!, as you say mandrell bent will look nicer though! out of intrest, why did you put the engine in this car and not leave it in the pink one? that car is awsome! |
08-08-2008, 10:13
#31 | | MIGWeb User
| Re: Advice on engine bay "tidy up".. the omex was all in place in the red one after the throttle body engine came out. the pink one i want to completley overhaul at some point anyway, back to concourse(ish). maybe this winter now. so to get the red one back on its feet i stuck the engine in here, and plan to make the most of the stand alone management oppertunity. |
Members: 43,216
Threads: 310,618
Top Poster: LEE69 (43,150) | | Welcome to our newest member, kaytee_lou | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
