Hello miggers!!
After some thought and a severe need for motivation, i decided to make a project thread on here as a way to log everything i've done to the tig, all the megasquirt stuff (as i've noticed there are more and more people interested, but not much info specifically on this) and hopefully get some help from you knowledgeable peeps if/when i get stuck ..
I did have a blog for this but it was too hard to update, so it's all going on here!
A little bit of history..
After seeing the car parked up at the back of my (parents) house for a couple of years with a knackered x14xe, i decided to make something of it and save it from the inevitable death by crushing. It was originally my mums (d'oh), having been imported from ze germany as she wanted a lhd car (d'oh). After a cambelt snappage (recovery pickup #1), it got repaired, soon after which the water pump packed in and another valve-piston mishmash being imminent she decided to get a new car (women ).
Sooo, being 18 and optimistic i decided to take it on as a project! I knew how these things worked but it seemed to be an exciting learning opportunity!! More of a test-bed for some engine fettling.
Since then, i got a 100k mile early c20xe which i inspected measured and refreshed all by the book, stuck it in and enjoyed the ride . It had a hone, new rings, new water pump, cambelt&idlers, shells, sbd's own uprated mains and flywheel bolts, regal's rod bolts, 're-freshed' oil pump, new seals, gaskets, some mild head porting, ran in properly with all the oil changes etc..
Since then, i've had some problems - lost oil pressure due to airlock in the oil cooler - fixed that, porous head fix went a bit sour - some swarf managed to avoid the air hose and block one of the oil galleries in one of the cams, a few oil changes it was all good again and no damage done (thankfully). Fitted an oil pressure gauge - well recommended tbh.
Since then, the head's been off a few times, to check the hone, new valve stem seals, cam cover breather modified (holes drilled in the plate), the throttle wedge came out.
It was quick and taught me a lot, specially after my 1st car - a 1.2 clio .
Recovery pickup #2 and #3 later, it got a late-style alternator bracket (ffs what a **** oe design on the early models!?).. and all was good.
Then a EHPS pump and res went in from a MR2 with a switch in the fag tray (after an epic failure of the original pump's piping ), general improvements like that...
Since then, i got the bug for power, researched the matter and made a clear plan of the things to come.
Being a student, money's a bit of a sore subject, so i gathered bits over the last year part by part, and now undertaking the biggest work since getting a summer job.
So, the plan is - a high comp c20xe turbo with megasquirt and car lappy, touchscreen in the dash for on-the-fly tuning/gauges. Aiming for around 200hp/200lbft untill i can afford a f28 or think of something else (f23 maybe, don't know yet).
some of the pics
JAW wideband assembled calibrated and working...
... In a box under the dash, mounted to the frame that the pedals are on. Also Knocksense velcro'd to the JAW box.
.. some more pics coming up in a moment
its cool, i decided to give the VR sensor a shot again after finding out that i missed a step when configuring the megasquirt board, and it works now for the RPM pickup
hey we'll see how it goes!)
.. (maybe time to start using antifreeze
) There was a notch that had corroded out which was dangerously close to the sealing ring, so i scratched it out, acetone'd it then used some hi temp 2 part glue (i think its basically chemical metal) glued it and flattened it again. It was a tiny notch - it was me being pedantic really but i do want it to seal good. Figured i have to totally wreck this head first before i put my 'good' one on which i have spare..
