update time !
got the fans on - i had to thin down the edges of the housings slightly to get them to fit, but now they fit and look neat !! Stuck them on a relay - so the original fan plug powers the relay - and this relay powers the fans straight from the battery.
So now there's 2 relays doing the job of one, but it's a neat installation and puts less strain on the wiring. Also made a takeoff for a switch in the dash for ON or AUTO, which ill fit later on.
I cable tied these through the rad. There's plenty of clearance gearbox-side, but could only get about 5mm between the wastegate bracket and the cambelt-side fanrocked the engine and it cleared fine so not going to bother any further.
Also you can see the exhaust mani shieldAint exactly pretty but it will help !..
here's said relay:
And battery connectors:
It works a treat !! Both of them come on, and don't seem to affect the voltage like the old fan used to. With the old fan, the lights used to dip every time it comes on, with the new ones you cant even tell they're on, only by the warm breeze coming from the engine bay lol!.
For the **** news - my bottom end has had enough. When it's warm it sounds fine like it always did, but when its started from cold you can hear it pretty clearly. ****. I guess the oil-less few seconds bashed a few more nails in it's coffin lol.
Any ideas how long i have till it goes ?! Will it give me plenty of warning or should i just rip it out and stick the spare in ?? I really cant be arsed with it tbh.
. I hear the 2l 8v engines are very turbo-able though
.. I doubt anyone will want to buy a LHD car in the uk lol!
. And the coolest thing - the Manifold Absolute Temp was 32*C even after i left it stand for 10 minutes to get the coolant up to temp (and get rid of the "klink klink klink" lol) which means the chargecooler is doing the biz
maybe i'll give it an oil change and see what happens!
