Old 01-07-2008, 07:51   #1
Drives: cavi,nova,astra,325i
eco-spec
hi hears a couple of pics of my mates car that i built. Engine started off as a vec x20xev but has now been in 4 cars and has been fluffed about with that much it now needs some direct to head bodies as every thing to do on the cheap has been done "and some not so cheap stuff"
spec:-
early eco inlet man (no p**s flaps)
fse set at 3.5bar (now 4.25bar)
bosch purples(new)
egr removed and blanked internaly
secondery air injection removed
knife edged body and cut down spindle
k+n
stage 2 porting and polish with cut back stems and knife edging
2 angle valves (home made)
mega road / trackday cams ground from solids
head skimmed down to exhaust seats
flowed water ways in head
mirror polished piston crowns
xe 4 branch
lightened and balanced bottom end
balanced rods
up-rated oil pump
balance shafts removed-
8v steel sump (baffled)
straight through exhaust with no cat
air con and belt tensinor all removed
45amp alt and single small belt
and loads more i just need to remember it all
dream project lotus carlton lump in a viva
eggman is offline   Reply With Quote
Old 01-07-2008, 08:04   #2
Drives: like its a hire car
Re: eco-spec
any gen on power as it stands?
I assume its on mappable management?
alistairolsen is offline   Reply With Quote
Old 02-07-2008, 23:56   #3
Re: eco-spec
simtec 70 standard management but it is mapable i have been playing with a couple of maps but thay are not that good its needing set up on a dyno when it is it will be a fast car for a mk4 astra
Old 03-07-2008, 06:35   #4
Re: eco-spec
simtec 70? whats that off? I think all ours are on 56.5?
How do you go about mapping the simtec? Can you increase the rev limiter too?
Any idea what power youre making?
Old 03-07-2008, 12:20   #5
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Re: eco-spec
Simtec is the OE management on mk4 Astras IIRC.
Didnt realise an XE 4 branch manifold fits an Eco either?
V8 blender FTW
Old 03-07-2008, 14:17   #6
Re: eco-spec
everything ecotec uses simtec, justa question fo which version. everything ive ever worked on was 56.5, never even ehard of 70!
the xe 4 branch doesnt fit, you have o cut and weld it to a new flange like 200sx let manifolds
Old 04-07-2008, 16:17   #7
Re: eco-spec
correct xe branch port spacing is spot on so i cut the top and bottom off the flange and got a xev flange lazer cut and welded it all round and in the ports wee buff back and it was minted but u need to run a xe or 8v sump so the 4 branch goes the right way under the block but this is a good mod as u can remove the balance shafts aswell!!!
and astra and vectra use simtec 70 and 90 altho thay are very similar and u can set rev limit to whatever u like the rods/crank is the limit!!
pics soon of port work etc
Old 04-07-2008, 16:25   #8
Re: eco-spec
and when this engine was in my car (cav) it felt a wee bit pokier than my pals gsi cav
and when we had a bit sport thay were the same to about 125 then i started to pull away but that was befor i fitted the 4 branch or put it in a heavie mk4 astra belive power is around 150 but would think it will be alot more when set up on rolling road power delivery is smothe but it realy comes alive at 4500-5000 then hit rev limit at 6200
very soon to be rev limit at 7225 when i get the next map back
Old 04-07-2008, 16:39   #9
Re: eco-spec
some pics of the porting and one of the bodys its got to get!! and one of the last car it was in rip mk3 astra
this is the old astra
direct to head bodys
[/IMG]
porting standard
porting 10 hours later
porting before and after
Old 05-07-2008, 11:48   #10
Re: eco-spec
double post
Old 05-07-2008, 11:49   #11
Re: eco-spec
the xe 4 branch doesnt fit, you have o cut and weld it to a new flange like 200sx let manifolds[/quote]
click this and u can see the flange when u zoom in
Old 06-07-2008, 22:15   #12
Re: eco-spec
How do you go about mapping the simtec software?
Old 06-07-2008, 23:06   #13
Drives: Corsa 1.4 Corsa 2.0T
Re: eco-spec
as above?
Gaz86 is offline   Reply With Quote
Old 07-07-2008, 15:52   #14
Re: eco-spec
i read the standard map with a kwp2000plus flasher. send the map to a tuner with a list of mods and it comes back and i rewright the ecu and jobs a good one
i will look in to my software and see if it covers the 56.5 i know it does the simtec 70 and 90 as i have done both with it with good results but for this engine i think its needing done on a dyno to moniter the a/f better as its a pain driving it as hard as poss while lookin at my j.a.w.
i had a look at a standard map agenst a mod file with a hex editor but u realy need to know what u are doing to f**k about with it u can see changes but u dont have a clue what thay are
Old 07-07-2008, 15:54   #15
Re: eco-spec
ps how do i post pics rather than links??????
i tryed and it just showed a little red cross so i removed it and put the link in instead?
Old 07-07-2008, 16:02   #16
Lugy's Avatar
Drives: Saab 9000 2.3T
Re: eco-spec
This looks quite an interesting wee project
I'm about to dabble in a bit DIY mapping this week. Should be fun.
If you click this little icon and insert the URL into the box
MIG Performance Saabs
Lugy is offline   Reply With Quote
Old 09-07-2008, 22:42   #17
Re: eco-spec
this is the flasher i use
and this is the vauxhalls it does
Vivaro 1.9 16V DI Bosch EDC15C2
Astra F (4) 1.7 16V DTI Bosch EDC15M
Astra F (4) 2.0 16V DI Bosch EDC15M
Astra F (4) 2.2 16V DI Bosch EDC15M
Astra G 1.7 16V DI Bosch EDC15M
Astra G 2.0 16V DI Bosch EDC15M
Frontera 2.2 DTI Bosch EDC15M
Vectra B 1.7 16V DI Bosch EDC15M
Vectra B 2.0 16V DI Bosch EDC15M
Vectra C 2.0 16V DI Bosch EDC15M
Vectra C 2.0 16V DTI Bosch EDC15M
Zafira 2.0 16V DI Bosch EDC15M
Coupe Turbo --- ME1.5.5
Astra F (4) 1.8 16V Siemens Simtec70
Astra F (4) 2.0 16V Siemens Simtec70
Astra G 1.8 16V Siemens Simtec70
Astra G 2.0 16V Siemens Simtec70
Omega B 2.0 16V Siemens Simtec70
Vectra B 1.8 16V Siemens Simtec70
Vectra B 2.0 16V Siemens Simtec70
Vectra C 1.8 16V Siemens Simtec70
Vectra C 2.0 16V Siemens Simtec70
Zafira 1.8 16V Siemens Simtec70
Zafira 2.0 16V Siemens Simtec70
Astra F (4) 1.7 16V DTI Delco Y17DT
Corsa B 1.7 16V Delco Y17DT
Zafira 1.7 16V Delco Y17DT
Astra G 1.2 16V Bosch M1.5.5
Corsa B 1.0 12V Bosch M1.5.5
Corsa B 1.2 16V Bosch M1.5.5
Corsa C 1.0 12V Bosch M1.5.5
Corsa C 1.2 16V Bosch M1.5.5
Astra F (4) 1.8 16V Siemens Simtec90
Astra F (4) 2.0 16V Siemens Simtec90
Astra G 1.8 16V Siemens Simtec90
Astra G 2.0 16V Siemens Simtec90
Omega B 2.0 16V Siemens Simtec90
Vectra B 1.8 16V Siemens Simtec90
Vectra B 2.0 16V Siemens Simtec90
Vectra C 1.8 16V Siemens Simtec90
Vectra C 2.0 16V Siemens Simtec90
Zafira 1.8 16V Siemens Simtec90
Zafira 2.0 16V Siemens Simtec90
Astra F (4) 1.4 16V Delco
Astra F (4) 1.6 16V Delco
Vectra B 1.4 16V Delco
Vectra B 1.6 16V Delco
Old 19-08-2008, 17:24   #18
Re: eco-spec
just away to be fitting some sexy pullys behind my timing cover has anyone one put verniers on a ecotec? what is a rough setting for it? have to wait a month before rolling road setup
Old 09-09-2008, 19:14   #19
Re: eco-spec
pullys on and undredrive bottom pully ordered cant wait for dyno setup
Old 09-09-2008, 19:34   #20
Gagged
Drives: astra 888 nova xe
Re: eco-spec
ahve a look at my old posts had a ecotec up to 185bhp (whilst still detting) on throttle boddies but still needed mapping to set up correctly.
had adjustable pullys on mine set them up to the cam spec then fine tuned on the rollers.
BEN LEE is offline   Reply With Quote
Members: 43,214
Threads: 310,615
Top Poster: LEE69 (43,150)
Welcome to our newest member, chrismessenger
