Page 9 of 41 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... LastLast
Results 201 to 225 of 1004
Thread: Corsa Maxi rally car
  1. #201
    Jul 2003
    Istanbul, Turkey
    TerranoII & Corsakit
    Re: Corsa Maxi rally car
    yes mate, thank you for reply,
    I have a number of pics of the cars progress. I don't want to mess Rob's area but if he execuses me here some of my clutch pics.
    I have three of used clutch disc to be choosen and restored. With the tought of six pad disc is more lasting.
    http://www.elk.itu.edu.tr/~azzmi/pics/DSC00002.JPG
    After new friction pads riveted, complete clutch,
    http://www.elk.itu.edu.tr/~azzmi/pics/SANY1279.JPG
    Flywheel surface conditioned and bolted,
    http://www.elk.itu.edu.tr/~azzmi/pics/SANY1288.JPG
    positioning clutch disc by a "specially broken" tool
    http://www.elk.itu.edu.tr/~azzmi/pics/SANY1290.JPG
    finally clutch is in-place
    http://www.elk.itu.edu.tr/~azzmi/pics/SANY1295.JPG
    my new and ex grN corsas
    cheers,
    Azmi
    I am a happy and speedy tortoise
    Jul 2003
    Istanbul, Turkey
    Quote Originally Posted by Rallycorsa View Post
    I use a sprung Helix plate as its less shock on the transmisson, i assume thats why Rob has too.
    Azmi have you any pics of your rebuild?
    I am afraid you are indeed right about the shock on the transmission. But in short term I don't have the time enough to order and change the disc. I also think as "there must be something positive about solid hub that because of it is produced." Unfortunately there was so many problems with the car and sometimes I had to ignore some drawbacks to get the car ready at the time. So I believe a second evolution is necessary after a test drive in coming rally.
  4. #203
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Hi azzmi,
    Yeah Kev is right about the clutch. Plus i was also told that the sprung clutch gives you a bit of slip on the clutch rather than it being like 'on or off'.
    Which for me was a bit of a plus as ive never driven a car with a paddle clutch before.
    Nice looking corsa you have. You have any more pictures?
    Rob
    If I ain't earning it - I'm spending it!!
  5. #204
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Quote Originally Posted by robertkassner View Post
    Hi azzmi,
    Rob
    hmm, have to disagree with the 'slip' comments, having driven both now i didnt notice any difference pulling away tbh and find a solid clutch to be no grief at all
    SHoNkyOpELs.de
  6. #205
    Jul 2003
    Istanbul, Turkey
    Hi Rob,
    I have been driving in rallies for a while, My first car was a Renault 11 TXE GrN with three pads cerametalic clutch disc with spring hub. Then I made some machining and adapted it to my GrN Corsa. When I brought this kit car, the solid hub discs came with it as an "used spares" - the guy who sold the car call them like this-. I agreed with lee about clutch feeling of engagement practically there is no difference, both engagement and disengagement are very sudden for both types of hubs. Since there is no need to soft engagement in rallies,that is improving gear chenge speed and of course heat resistance of clutch disc. I think the weight of spring type hub is a bit more heavy. But the difference is not so dramatic. I was hoping an answer like "there is something this type hub which gives you extra horses .
    I have many pictures and also some videos about rebuild of the car I will be happy to share them. But unfortunately there is no pics in the super special. If you like to watch my other GrN corsa (totally standard) in the forrest action you can click the link. http://www.elk.itu.edu.tr/~azzmi/clip00.wmv
    Here is the last picture of her
    I can upload here a few more if it is not a problem.
    Cheers,
    Azmi
  7. #206
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    No problem mate, get them on here!
  8. #207
    Jul 2003
    Istanbul, Turkey
    Eh, the car was not so mint condition when arrived. Me and my wife (also my navigator) started to dismantle everything we touch.
    Firstly I liked to check gearbox (6 speed dog quaife with plate LSD). Unfortunately 1-2, 3-4 dogs and selectors heavily worn.
    But the real drama was inside of the LSD unit. two of the friction plates was fractuated eight pieces.
    Since there is no time to get originals I have drawn it by auto cad then laser cutted and surface grinded them.
    Then got LSD together.
    I hope to make a full rebuild to the gearbox with original parts to next coming spring.
    Hope you'll like them,
    Cheers,
    Azmi
  9. #208
    Jul 2003
    Istanbul, Turkey
    By the way,
    As you can see I like to work at home
  10. #209
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Great work, its good to see you can do most of the stuff youself.
    What kind of suspension setup do you have on the front? Do you have pictures?
    Wanting to see what the struts are like as using standard suspension strut gives you too much camber.
    rob
  11. #210
    Jul 2003
    Istanbul, Turkey
    Thank you Rob,
    Front and rear suspensions are proflex two way adjustables, front with 40kg/cm progressive, rear with 33 kg/cm springs.
    I will put the pictures as soon as resized them. Much camber is a result of wide track kit. if you use proper strut, camber will stay reasonable limits. The mounting holes of standard struts are very close to the strut body, that is resulting very much negative camber. Maybe to drill new holes or widen the standard holes can help.
  12. #211
    Jul 2003
    Istanbul, Turkey
    Here they are,
  13. #212
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    you rally guys have some pretty dam impressive bits if kit
  14. #213
    Jul 2003
    Istanbul, Turkey
    side effects of working at home.
  15. #214
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    hi guys putting the turret onto my quaife 6 speed dog box as above tomorrow. do you know the bolt thread size??? As i dont have any until i but some tomorrow
  16. #215
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    hi mate, just use the standard ones.
    rob
  17. #216
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    hi rob i dont know what the standard ones are in size as i havent got any lol
  18. #217
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    oh by the way is there any torque settings for attaching the turret? not sure if there were. thanks again
  19. #218
    Jul 2003
    Istanbul, Turkey
    I think ( I will check them tomorrow) they are metric type M6X1mm bolts approx 20mm long, 8.8 grade, 1kg.m tightening torque will be enough. Do not over tighten them otherwise you will destroy the aluminium threads of the gearbox.
  20. #219
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    guys sorry for all the posts, can you tell me how you put the gearbox into neutral before you started setting up the gear linkage??
  21. #220
    Jul 2003
    Istanbul, Turkey
    sorry mate,
    I think you better consult a local mechanic about this gearbox installation process.
  22. #221
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    to put the box in to neutral, align the three selectors you can see through the turret opening so they are central and there is a gap in the middle of them for the finger on the turret to fit through, and the bolt size for the turret is actually M7, if you dont have any then you can use clutch plate bolts as they are the same thread
    SHoNkyOpELs.de
  23. #222
    Jan 2009
    Danmark
    opel corsa b ki
  24. #223
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    looking good Donlop, Is that the one at Protec at the moment?
    Rob
  25. #224
    Jan 2009
    Danmark
    opel corsa b ki
    hey
    my car at Protec at the moment? i can not see it make a link
    I have many pictures i cant get them on here!
  26. #225
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    You could email them to me and ill put some up?
    There is a white Corsa Kit car that looks like yours at protec motorsport in the north west - i thought it was yours.
    Or did you get some parts from them as im sure they have shown me pictures of it.
    Im sure it was from Denmark to.
    rob
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
