Page 7 of 41 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 151 to 175 of 1004
Thread: Corsa Maxi rally car
  1. #151
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Re: Corsa Maxi rally car
    Quote Originally Posted by robertkassner View Post
    Cheers mate, think i'd still be staring at it scatching my head!!!!lmao
    Really cant wait to get out in it - bet you know the feeling!
    Rob
    no worries mate, gald to be of help, and yes, that feeling is all too familiar unfortunately, stiil, there's light at the end of the tunnel
    SHoNkyOpELs.de
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    Here are some detailed pictures of the shell.
    Does anyone know how do i resize images? Ive got them on fotopic and when i add them they are huge!!
    rob
    Hi Rob,
    I have bought the quaife gear lever and turret for my corsa rally car.
    Has your exhaust tunnel been strengthened for the lever?? Also does the lever bolt into the original holes left from the previous gear lever?
    Just wondering how much of a nightmare it is to get it in!! lol.
    Ive got the linkage rods from hockleys and i've got a feeling they may not reach the turret! How many rods do you have on yours?
  4. #153
    Jun 2007
    Fife
    Rob, thats a cracking spec. car your building. Love the attention to detail, will be good to see it out on the stages hopefully soon.
    On the top picture, the black metal bar that goes from one side of the car to the other did you keep it in? Was looking to see if i needed to keep it or not when rebuilding my car as only appeared to be something to cable tie the loom onto.
  5. #154
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by mattyd81 View Post
    Hi Rob,
    There are three rods, a short one from gear lever to adjuster (part of the lever - not seperate), a long one to bulk head and a medium one from bulk head to turret top. The tunnel wont be strengthened and it bolts just in front of the original holes. It goes through the bulk head to the left of the original hole. Im yet to start fitting it yet but ill get pictures on here as soon as i do.
    Quote Originally Posted by cshrally View Post
    Thanks!! Don't think ill be out soon My first son is due to be born in April and my job is also at risk as the company is getting rid of 530 jobs!!! Ill not be selling it as it don't cost me owt sat in the garage.....but who knows.
    I see you are cracking on with yours and doing a good job!
    Yeah the black bar can be removed but I'm keeping it as it has had extra mounts welded on the it for the steering column (not necessary though).
    All the best
    Rob
    If I ain't earning it - I'm spending it!!
  6. #155
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Gonna say, I ditched the black bar of mine in favour of the weight loss lol
    Congratulations on your son Robert, you didn't mention it when I saw you
  7. #156
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Cheers Dave. I didn't know mate! Found out a couple of weeks later!!
    I was going to say, look at your build diary as i knew you have removed it and had some good pictures.
    You are quite good at taking pictures - you should do it as a job!lmao
    Rob
  8. #157
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    I'm just the bitch for my wife mate; she's the pro photographer, not me. I'd rather sit at a desk all day and play on MIG lmao
    I'd like to pop over in my trackshed once some better weather comes in, let you have a go and see what you think of the setup etc. I'm sure you can recommend me some ways to improve things on it
  9. #158
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Oh right i see.
    Yes mate, get yourself over. Although decent roads round here are a little unknown!!
    Looks like you have yourself a quality trackslag.
    Rob
  10. #159
    Dec 2008
    Thetford
    1998 Vectra x16xel
    Bloody awsome car mate. gives me lots of ideas. keep it up mate.
    WANTED: C20LET. PLEASE PM ME IF URE SELLIN 1.
  11. #160
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Got one side built up today. Cant do the other as ive got to send off my hub to get the brake kit made up.
  12. #161
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Then had a go at fitting up the gear linkage.
    Got all bolted up and then found out i couldn't get gears. It turns out one bolt is too long and catches on the steering rack mount and another bolt catches on the gearbox case. One can be cut shorter but the other is gonna cause problems. Any way got fed up and ill have another look another day......
  13. #162
    Macclesfield
    www.Retrobike.c
    Can you not run roll pins instead of the bolts like neo (iirc) has done.
    Back in the scene
  14. #163
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Yeah i was just going to have a look at his build thingy, i knew i had seen another way somewhere - cheers Rick
  15. #164
    Aug 2003
    Durham
    Rob if its any consolation i used the roll pins as rick mentions and it helps but if your using a F20 with the gear rods that hocley supplies your in for a rough ride as i tried about 40 combinations and could'nt get all the gears and ended up making a rod of my own lenth for the engine bay side, hockly told me there aint a kit for the F18/F20 box so i had to improvise and try a few things, idid take the measurements though if you need them...
  16. #165
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by neo1 View Post
    Oh heck, i never knew that!!! Im running a F20.
    The problem i have is that the bolt head catches the diff casing. So could take 2-3 off the head but how long will the bolt last when the car eventually gets used in anger!
    How did you get around it?
    Thanks
    Rob
  17. #166
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    you could re drill the rods and joints 90 degrees to where they are now, or possibly use button headed bolts instead, depends how much clearance you need
    SHoNkyOpELs.de
  18. #167
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Im going to try a few things tomorrow Lee. It doesn't need much clearence.
    Rob
  19. #168
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    button heads may be the way forward then, ime you do have to get those bolts fairly tight to avoid any slop in the linkage, so if you grind the heads make sure you leave enough to get some good torque into them, i'm sure you'll sort it though, teething problems suck!
    SHoNkyOpELs.de
  20. #169
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    eeek im runnign an f20 dog box too and my rods are from hockleys. there is an f20 rods on his site now. rob youll have to let me know where you finally position the lever? do you push it forward until it cant go forward no more or whats the crack? lol
  21. #170
    Aug 2003
    Durham
    I never had the problem of catching bolt heads and stuff as i used roll pins from the off set, what i found was i used the standard rod kit from hockly's and they wont work 100% with the F20 box in a corsa, as the last rod section is too short, which stopped me getting all the gears, i would get say 1,2,3,4 but no 5th or rev, with adjustment i i got reverse but lost 1st and 2nd etc, then i rang them and they said it will have to be a custom rod lenth, so i bought some rod and ends andd made my own up, and it worked spot on, the turret is in a different place slightly or something, my rod ended up being longer than the standard one mine was 120mm shoulder to shoulder or 161mm end to end, which if i remember is 20mm or so longer than the one supplied in the kit...
    i also ended up extending the rod in the car as the lever was too far forward for me to reach for my seat position, i could hardly reach the gear knob when strapped in the car another 100mm went on directly in front of the lever in mine... so i might of well made my own rods up in the end Rob,,,
    But now ive got a nice shift and all the gears so i am happy, hope yours is plug and play but mine was'nt mate... might help you out if its not with what i have done though..
  22. #171
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    its weird because when i swapped from a f13 to the f20 i thought i would have to mod the rods, but i havent had to, it just works
    SHoNkyOpELs.de
  23. #172
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Thanks for all the replies, ill have a go tomorrow to get it to clear first. Then take it from there.
    Thanks again
    Rob
  24. #173
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    ooh strange ill let you know how i get on with mine....thanks for the pics rob these are much help!
  25. #174
    Aug 2003
    Durham
    Yeah weird that, mine on solid mounts as well so not sure if that makes a difference
  26. #175
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Ok then, had another go today.
    Got the bolts undone and then got busy with the hacksaw. Bolted them all back up but one as i think ill definitely need a roll pin.
    Cant get any gears... I can only pull the gear stick backwards, so i wondered if it was a gearbox problem. I took the turret off had a look, all ok. Put the turret back on and tried to select a gear by hand without the linkage attached and got them all.
    so back to the linkage.
    Measured the short rod and its 145mm total length and 103mm shoulder to shoulder. So im guessing its too short. Having a longer one would also solve a clearance problem.
    Hockly does sell a F20 linkage rod. Dont suppose you have any rod left over Rob?
    Thanks
    Rob
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
