Page 5 of 41 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 ... LastLast
Results 101 to 125 of 1004
Thread: Corsa Maxi rally car
  1. #101
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Re: Corsa Maxi rally car
    The red one is now in Ireland and is being used as a gravel car so im pretty sure its not that pretty now.
    Ill get some more pictures when the engine is in and i can push it outside.
    Still waiting on ECU, loom, clutch plate and fuel pump. Oh someday....................
    bux
    bux is offline
    Jul 2006
    Northants
    12.1 sec Corsa..@120
    wot arches are they, i love em!! top car mate
    12 second corsa....12.1 @ 120mph
    vauxsport.com
    Total Vauxhall Cover Car Jan 2009
  4. #103
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by bux View Post
    Thanks mate,
    Its the Kit car body kit that Wizard motorsport developed
    cheers
    rob
  5. #104
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by robertkassner View Post
    They do look the nuts Rick! The cheapest place for the kit ive found is Pro-tec.
    The only problem ive found is the back wheel cant tuck under the arch as there is no lip so it gives the impression its riding high (if you know what i mean). I think you do need to run widetrack aswel so the wheels fill the arches otherwise it dont look right.
    I have a pic somewhere of the kit with standard track if you interested?
    cheers
    rob
    Thanks, the only way i would do it is to wide track the car. Seems little point leaving it standard track but fitting wider arches.
    Back in the scene
  6. #105
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    I know of a Front wide track pilbeam type set up for sale.
    Rob
    If I ain't earning it - I'm spending it!!
  7. #106
    Macclesfield
    www.Retrobike.c
    I do as well and i am very tempted. Just depends on shafts etc that i would need? Also how is your rear track made wider? I guess its done via moving the stub axle out rather than loading up the bearing via spacers or large offset wheels?
    Back in the scene
  8. #107
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Do it mate!!!!
    You'd have to get some shafts made up by measuring plunge and what not.
    I had to get a set of Astra shafts and cut them in half, then put a tube over the two halfs so that the shaft is extendable. Then mount the box, shafts and hubs. I think an F20 cv has about 30mm of plunge (15mm in 15mm out). I got the plunge right by extended the shaft then welding the tube to keep the shaft in place. Measure the length then got GKN to make them up to length with F20 cv splines.
    Also you have to change your strut bodies to something more suitable or you'll run drastic camber. I used the bottom bolt hole on a standard body and then got 0 camber on the hub and worked out i need the top hole 10mm further out.
    Sent Proflex a diagram and they made them up for me.
    The rear beam was done by Walden (now Clark motorsport) but basically they are a waste of time (false promises).
    Yeah it has a piece of box section between the beam and stub axle. I can take some close up pictures if you want?
    Its alot of ball ache - i just hope its all worth it when i eventually get it out on a stage!
    Rob
  9. #108
    Dec 2004
    Colne
    TT 225/Track nova
    Have to agree with you about clarke motorsport. Bought my kit from them sent it back due to it looking like the secretary had made it lmao
    The second kit i recieved was of a better quality just took 6 months to long.
    Think theres a kit in a eurorallye at the moment.
    Do you still have a copy of the diagrams you sent to proflex?
  10. #109
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Yeah Ste - not the best - wont deal with them again.
    Ill have to look for the diagrams, although you would be better getting the measurements of your car as there might be slightly different.
    Thinking back it was around 10mm for 0 camber. The Proflex runs camber washers on each bolt hole so i can adjust it from that. If you run a strut which doesn't have camber washers then you could make one of the hole elongated or check how much camber you want and then make it permenant.
    Its bloody hard to put into words...............lmao
    Rob
  11. #110
    Dec 2007
    West Yorkshire
    MG ZR
    Any new piccies?
  12. #111
    Jan 2006
    kent
    updates updates?!!
  13. #112
    Macclesfield
    www.Retrobike.c
    If you get chance please can you measure me the open length on your rear shocks, and the tube length if possible.
    Back in the scene
  14. #113
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by Rick Draper View Post
    Rick,
    The length on the extended strut is 46cm to the top of the spring cup and the body is 23cm. All lengths taken from the very bottom of the strut.
    Why, what you thinking?
    rob
  15. #114
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Little update:
    Looked what arrived today!!! Finally!!!
    Can Finally get the clutch on and gearbox mounted to the engine.
    Then when i get a weekend free ill be able to get the engine into the car.
    Also fitted the oil catch tank but will have to come back out so i can fit the inner arches (when i get them)
  16. #115
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    those remote resevoirs are dead sexy, liking the catch tank too, you running a pro tec style breather?
    SHoNkyOpELs.de
  17. #116
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Yeah the system was from Pro Tec through Martin as it was part of the engine spec, dont care what it does - just looks funking cool!!lmao........... But hopefully it'll make sure no.3 will stay inside the block
  18. #117
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah it solves the oil starvation of the crank at high revs, nice bit of kit
    SHoNkyOpELs.de
  19. #118
    Dec 2007
    West Yorkshire
    MG ZR
    Looking goor mate. I may have missed it on the thread Rob, but are you running a heated front screen? Are you having any other form of ventilation in the car, as i see the standard heater box has gone...
    Loving the car! keep up the good work!
    John
  20. #119
    May 2006
    Northumberland
    Clicky Corsa
    Good work Rob, ive removed my Protec breather and replaced with Bill Falconers , bit less hose work and very cheap just hope it works ok.
  21. #120
    Dec 2004
    Colne
    TT 225/Track nova
    Looking good. As lee said, loving the suspension
  22. #121
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by Rallycorsa View Post
    Hows the engine coming on Kev? Are you having one of his exhausts? As im tempted......rather than a Tony Law, to try and save some £££££.
    Forestfighter, Yeah ill be running a heated screen as the heater matrix has now retired. Plus all the ducting in the dash has been removed.
    Rob
  23. #122
    MIGClub Member fennyLET's Avatar
    Aug 2007
    Kings Lynn
    Astra mk3/4 Turbo
    Im in love with the body kit (Prob wrong words)
  24. #123
    May 2006
    Northumberland
    Clicky Corsa
    Hi Rob engine is sitting on stand ready to go in
    Not getting the exhaust as i have a very good system already but if i dont get the results it could be changed.
    Plan on putting a few pics on my thread when i get a min.
  25. #124
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    looking forward to it mate!
  26. #125
    Sep 2005
    belfast
    hi robert very good project do u know the price of the manifold from bowyer. cheers
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
