Page 17 of 41 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 401 to 425 of 1004
Thread: Corsa Maxi rally car
  1. #401
    rc
    rc is online now
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    Re: Corsa Maxi rally car
    good to see a bit more progress there should see a bit jump when you send it off by the sounds of it! looking forward to it!
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Just cant wait to drive it in anger!!
    it'll get there - hopefully before the bank manager catches up with me
    If I ain't earning it - I'm spending it!!
  4. #403
    Jul 2003
    Istanbul, Turkey
    TerranoII & Corsakit
    Glad to hear that, we wish your baby a long and happy life. Sorry for your car keys, at least you still have the car that is much better than vice versa. Nice pictures that you send, waiting for more. by the way, what is the cost of a wiring for a corsa in England?
    Best wishes you all,
    Azmi
    I am a happy and speedy tortoise
  5. #404
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Thanks azzmi!
    Prices vary i think on the quailty of parts used. I know someone has spent 20k on connectors alone but he's using fly by wire everything -awseome bit of kit!
    I think around 2000 would be the going rate for a proper rally wiring bloke to do it - im sure you could get this a lot cheaper from a autoelctrician.
    Byron, who will be doing my is doing it as a favour so itll be a little cheaper. he'll be using circuit breakers vice fuses and proper aircraft spec wiring and connectors. Cant wait!!
    All the best
    Rob
  6. #405
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Pisser about the keys; although after what you told me when I was last at your house I'm surprised your back door wasn't locked?
    I didn't think you'd get the rear windows in with the seals, absolute tw@ of a job IMO lmao
    New wing mirrors look big
  7. #406
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    looking good mate, nice to see some pics, keep up the good work!
    SHoNkyOpELs.de
  8. #407
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by DaveB View Post
    Its always locked now!!!!
    i think with a little more patience they might have gone in with seals but im not very patient!!lmao
    Cheers Lee hope you get yours all sorted out again - ready for Germany.
    Rob
  9. #408
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    cheers pal, looking forward to seeing yours done and out being used too!
    SHoNkyOpELs.de
  10. #409
    Jul 2003
    Istanbul, Turkey
    Hello Mates,
    I am a little bit in trouble,
    do anyone hear about BJ motorsports ever?
    best wishes,
    azmi
  11. #410
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Hi Azzmi,
    What trouble you having? Are they the ones on ebay?
    rob
  12. #411
    Jul 2003
    Istanbul, Turkey
    Hello Rob,
    my trouble is my camshafts comes from BJ motorsports, I followed the KCBJ (23 and 24) prefix and reached to kent cams. they said they did grind the cams for BJ motorsports, and gave their duration and lift values (I mentioned here before 280ex 284in about 11.7 mm max lift) but there is no lobe seperation angle and lift @ tdc values which are necessary to make timing the cams. I have marked the verniers in case of I could't find any data but I like to check their correctness also.
    all the best,
    azmi
  13. #412
    Mar 2003
    Manchester
    Corsa C / RWD Nova
    Not sure if this is the place your looking for ?
    http://www.newen.co.uk/racing/
    They tend to specialise in Vauxhall engines
    Might be worth a call
    Dave
  14. #413
    Feb 2009
    Finland
    Opel Corsa B GSI
    Hi Azzmi,
    in order to get it running the cams you have could be timed in 3,5 +/- 0,5 mm open in inlet and 2,5 +/-0,5 in exhaust. You should check how much space you have for the valve to be opened at TDC, this is to make sure your pistons no not hit with the valves when running. The initial set-up for the timing needs dyno drive in my opinion. We have found remarkable differences with few degree changes.
  15. #414
    Jul 2003
    Istanbul, Turkey
    Hello mates,
    thank you for your replies,
    since I am not such a social person I don't prefer make overseas telephone calls. Besides I believe I can express myself and situation more easy as writing. (of course somebody should read alsolmao) Anyway, thank you dave I posted a mail to their info. Corsa-finn, I actually have a starting point that I recorded the timing values before remove the cams. I am just curious about the exact values. After all I'll make a dyno test as you pointed.
    Between topics,
    which compression ratio do you use calculated or actual (smaller than calculated value because of inlet cam timing). I made a computer simulation for my engine, 1:12.5 CR (calculated) reduced to 1:10.4 (actual CR).
    thank you for your valuable opinions.
  16. #415
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Credit crunch arch fillers!!
    Was going to get kevlar ones but could do with saving some money so i thought i give it a go making some myself.
    First i tried the standard ones but as its got widetrack wings they didn't fit right.
  17. #416
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Also fitted my rear pins in the tailgate - also another picture of the rear screen fitted in.
    And front windows!
  18. #417
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    lmao lmao lmao at Golden Nuggets
    IMO pins would be better at the bottom where I've got mine as it holds the boot down better
  19. #418
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    i knew you'd like that! they make the best templates!!lmao
  20. #419
    Dec 2008
    South West Scotland
    This has got to be one of the best home made rally cars I have ever seen. Attention to detail and quality of the products used are amazing. Cant wait to see it finished!
    Well done mate
  21. #420
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Thanks mate!! Just hope ill be able to do it justice out on the stages!!
    rob
  22. #421
    May 2006
    Northumberland
    Clicky Corsa
    We will see looks far to pretty to scratch it if you ask me ;-)
  23. #422
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Give it a few events to get 'on it' then ill go really fast, knock the wing mirrors off, smash the front bumper and put a few tyres marks down the side!!!
  24. #423
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by robertkassner View Post
    Quoted so you can't pussy out at a later date lmao
  25. #424
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    lmao
  26. #425
    Dec 2007
    West Yorkshire
    MG ZR
    Looking very good. Perspex windows look lovley!
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
