Page 14 of 41 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... LastLast
Results 326 to 350 of 1004
Thread: Corsa Maxi rally car
  1. #326
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Re: Corsa Maxi rally car
    Fantastic video Azmi.
    Shame about all the problems! Im sure you'll get there eventually.
    I can remember my nova (corsa A) had around 1-2 degree toe in on the back end with a little more toe out on the front. Cant remember exactly but 6 degree toe out is definitely a bit wrong.
    All the best mate
    Rob
    If I ain't earning it - I'm spending it!!
    Feb 2009
    Finland
    Opel Corsa B GSI
    Just starting to build up a Corsa kit car for national rally purposes. The spec should be (in addition to the welded safety cage); 1,6 / 16V with 220 hp, F-20 dogbox with plate lsd and Astra GSI axles, big brakes, reiger or öhlins suspension with coilovers, front trailing arms from pipe and rear suspension reinforced just to start with I've been looking throught the photos shown here; the cars do look good and give me some idea to build mine as well.
    Do you have any photos / dimension / drawings (other than homologation paper) concerning the kit car changes in wheel arches front / rear ? There is some space made for the wheels as well as the upper ends of the suspension has been changed ? The safety cage is already under process, but the other modifications to the chassis need still to be made.
    How much wider the car is with Astra axles fitted in front ? How much longer the lower trailing arm needs to be ? This is the same value as need to be done to the upper end.
    Any comments and advices would be appreciated
    Best regards
    Esa
  4. #328
    May 2006
    Northumberland
    Clicky Corsa
    Setup for mine is (from Alan at Protec)
    Front
    Tow out 1mm each side
    1.5 deg neg camber (1 to 1.5)
    Rear
    1 mm tow out (Upto 6 mm tow out was used on works cars anymore on mine and it was nervous)
    .5 deg neg camber
    Hurry up Rob get it finished before the little one lands
  5. #329
    Jul 2003
    Istanbul, Turkey
    TerranoII & Corsakit
    hello Esa,
    I'll get my camera tomorrow for wheel arches, hope the photos will be helpful. Front suspension turret doesn't need any constructional modification. Rear turrets has to be reconstructed to gain space and reinforced to carry that the load comes from coilover suspension if you make the change.
    Regs.
    Azmi
    I am a happy and speedy tortoise
  6. #330
    Feb 2009
    Finland
    Opel Corsa B GSI
    Thanks a lot, I look forward to see those photos.
    I was intending to move the upper end in front outwards a bit, so that the suspension stays in correct position. The movement should be the same amount which the lenght of the lower arm lenghtens.
    For the wheels, I used my previous car (FWD 220 hp rallycar) in gravel following setup. Front Camber 0,75-1°, Caster 2,5-3°, toe from 0 to -5 mm (front open) Rear Camber 1,5, toe from 2 mm to 5 mm (front end closed/shorter). If you leave the rear end toe open the car will slide very easily and is very nervous from the back.
    Esa
  7. #331
    Jul 2003
    Istanbul, Turkey
    Hello,
    I hope that'll be helpful a bit.
    you also have to replace refuelling cap and its pipe to make a space to the right side coilover,
    Cheers,
    Azmi
  8. #332
    Feb 2009
    Finland
    Opel Corsa B GSI
    Hi Azzmi,
    thanks for the photos
    How about the front end; have you got some modifications in there ?
    Esa
  9. #333
    Jul 2003
    Istanbul, Turkey
    Hello Esa,
    Actually, there is no additional modifications on the front end more than denoted in homologation form. just some MIG welding to reinforce some spot welded junctions. I have wide track kit with proflex struts and aluminium strut tops with rose joints and of course a strut brace. If you like to see I can take an another camera trip to my garden.
    By the way,
    a video from my first finish with this car. After fifteen years of group N driving with standard engine/gearbox, as you could see, I have a little hesitated to gearing down and make some high RPMs. And I experienced a real 1. gear issue, three times it engaged reverse instead of first. After that, I stopped first then shift to first gear. I hope it is an alignment issue. In addition, my first impression with this car is, my sixth gear will be never worn outlmao.
    here,
    http://www.elk.itu.edu.tr/~azzmi/pics/clip2008.avi
    Cheers,
    Azmi
  10. #334
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Started to fit the SPA wing mirrors i got off ebay.
    Dont know how legal they are but hey ho!
  11. #335
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Quote Originally Posted by azzmi View Post
    Hello Esa,
    Azmi
    if you are having problems engaging reverse by mistake, you can remove the reverse light switch, and fit a sprung loaded rod to engage with the flat on the reverse gear shaft, as the switch does, and then run a bowden cable back to a bike lever or similar on the gear lever shaft, which you would have to pull to enable reverse to be selected, as the plunger would stop the shaft moving unless the lever has been pulled, got one up the garage somewhere, will get some pics
    sorry for the hijack robert, nice mirrors, same as me and i get an mot, did you go for convex lenses? as the flat ones are pretty rubbish to see out of ime
    SHoNkyOpELs.de
  12. #336
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    No problems Lee, Im picking up tips all the time from everyone - so quite glad of it really!
    No flat ones mate (wish the were convex as i cant really see out of them)
    But on the plus it wont be doing many road sections so wont need them.
    rob
  13. #337
    Dec 2004
    Colne
    TT 225/Track nova
    Mirrors look good. Looking back is overated lmao
    Hows the loom coming on?
    Are you having a look at the NW stages in a couple of weeks?
  14. #338
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Think Kev is competing mate, dont recon ill be venturing up as its a little far.
    Are you?
    One day though.................ill be doing it in the corsa.................one day!
  15. #339
    Dec 2004
    Colne
    TT 225/Track nova
    Hopefully you will be next year!
    Im marshalling there (just a good excuse to get up close lmao), always makes for a good day/night.
  16. #340
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Good good, also its free to marshall!lmao
    How did you get on with those sill mounts?
    rob
  17. #341
    Dec 2004
    Colne
    TT 225/Track nova
    True true
    Iv started on a set, hard work trying to fit in between jobs though. Once ive finished a set i will let you know. Hopefully wont be to long.
  18. #342
    May 2006
    Northumberland
    Clicky Corsa
    Rob stop fannying about with mirrors and get the important jobs done Doesnt matter whos behind anyway as you will be to quick for them in your kit Corsa
    T45 give me a wave at NW cars just about sorted fitted a new Racetech rev counter just waiting on my mate to wire it up and the Tom Tom for my speedo as the one that was fitted decided not to work anymore, drop the oil and away we go just hope to finish this time as we retired in 2007.
  19. #343
    Dec 2004
    Colne
    TT 225/Track nova
    Will do mr rallycorsa, look forward to hearing the 1600 scream.
  20. #344
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by Rallycorsa View Post
    Cheers Ste.
    Decieded to fit the mirrors to give me a break from the chuffing arse of a job of the wiring!
    Might need them for the first couple of events as ive fogetten how to drive - its been that long!
    Take it you sold the engine mate? Whats the exhaust like?
  21. #345
    May 2006
    Northumberland
    Clicky Corsa
    You will
    Do you know where you marshalling yet?
  22. #346
    May 2006
    Northumberland
    Clicky Corsa
    Exhaust is sold SBD manifold with 2 2/12 twin box system, going onto my mates Tigra with Sadev sequential box (bastard i hate him)
    Im going to save up for a Sadev box with the bit i made off the Corsa, plus mate with Tigra has the pain of fitting and any problems should be sorted by the time i get mine and copy his box mounts
  23. #347
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Arse! need an exhaust.........
    Looks like ill keep looking. Sadev ummmm. Have to sell a kidney to buy one though and as one of mine is knackered ive sh!t out!
    Got someone to make my bells and brakets so should be on the car by the end of the month.
  24. #348
    May 2006
    Northumberland
    Clicky Corsa
    In all honesty i will probably not get a Sadev but its on my wish list, keep pushing to get the car done once the youngster comes that will be the job stopped for a while.
  25. #349
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    I know kev,
    Seen a pair of seats that im after, trying to persuade our lass to let me have them but got to sell my old motordrive first!
  26. #350
    Jul 2003
    Istanbul, Turkey
    [quote=Rallycorsa;3925818]Rob stop fannying about with mirrors and get the important jobs done Doesnt matter whos behind anyway as you will be to quick for them in your kit Corsa quote]
    I think, I agree with rallycorsa. It will be great to see your car on the stage. (By the way the good looking side mirrors don't last so long, it is all about a little tree in a forrest stage... I am just joking mate.)
    Best wishes.
    Thanks Lee, pictures would be great.
    Azmi
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
