Page 13 of 41 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... LastLast
Results 301 to 325 of 1004
Thread: Corsa Maxi rally car
  1. #301
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Re: Corsa Maxi rally car
    Cheers mate, ill see how it goes!
    If I ain't earning it - I'm spending it!!
    Dec 2004
    Colne
    TT 225/Track nova
    Noticed your after some sill stands. Im going to be making a set in the next couple of weeks. If you want a set making let me know. They will be fully tigged and load tested.
  4. #303
    Jan 2009
    Danmark
    opel corsa b ki
    i got a efi euro 4 and a D2 dash for my car and i have a E 48 EXP Engine Management System and loom
    forsale
  5. #304
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Quote Originally Posted by t45_ste View Post
    How much mate?
    Currently sat on tubes on axle stands!!
  6. #305
    Dec 2004
    Colne
    TT 225/Track nova
    My time wont cost anything as i will be doing them at work and may be able to get the material through work also. I should know by the end of nexy week
  7. #306
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Fantastic!!!!!
  8. #307
    Dec 2008
    Isle of Man
    Hope this works!!
    Just a picture of the car im building. hope you like!!
    Finally painted her Rob!!
  9. #308
    Dec 2008
    Isle of Man
    [/IMG]
    Try again!!??
  10. #309
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    No picture mate.
    Coming together now. Whats left to do?
    Rob
  11. #310
    Dec 2008
    Isle of Man
    Hi Rob.
    Picture should be up now....spot the newby on the forum!!
    Shell finished. just got to put it all together. Making our own bottom arms which should be fun. Borrowed a mates jig to do them so see how they turn out. Also got to make a loom....hours of fun....not!!
    Looking for a sequential box for it....holly grail springs to mind.
    got 70% of bits needed, the last 30% are the dear bits, throttle bodies etc.
    Should be ready in a couple of months.
    I was going to order screen from Ricky Evans but price is not good. I notice its only the corsa b screen thats shot up in price...the other vauxhall screens only went up slightly!! Theres a guy in Northern Ireland selling screens, might email him for a price.
    Hows yours getting on?
    Not giving up yet i hope?
    Tony
  12. #311
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Not given up yet Tony,
    started on the loom today, well....... started to strip the old one by trying work out whats what.
    Where did you get the pods from - shell is looking spanking!!
    If its any use - my tie rods and brackets are from Harry Hockly as they mounted in the same place on the Walden bottom arms. So if you can just make the bottom arms longer and use hockly stuff.....May make life easier.
    rob
  13. #312
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Oh and you'll have to let me know how you get on with the heated screen. I think £190+ is a bit of a joke!!
  14. #313
    Dec 2008
    Isle of Man
    Main pod is from Clarks (Walden...sorry guys!!) and the corners are from Magnum.
    Going to do the whole lot bottom arm wise. If they work out ok then may do a few sets. They'll have rosejoints on inner end of the arm so fully adjustable rather than Hockly fixed.
    Let you know when theyre done.
    Good luck with loom.
    Tony
  15. #314
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Cheers,
    good luck with the rest of the build
    rob
  16. #315
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Ok time for another update.
    Being playing with the rear mount as i wasn't entirely happy with it. Got in spot on now and its given my enough clearance between box and bulkhead. Also gear linkage nearly works now and no clearance problems!!
    Also made a start on the loom - armed with sidecuts, a haynes manual and fuse box cover. Ive been putting this job off for a while, but once i got stuck in its not so bad. Ive started to remove everything i don't need like heated rear screen etc....
    Next is to replace and move the fuse box. Also im going to have a push start and front heated screen (if i can get one at a reasonable price!). Also need to make a lamp pod loom from scratch.
    Also bought one of these, a electric cut off by ETA - no pull cables need as it uses an electrical switch instead.
    Thats it for now.
    Rob
  17. #316
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Cutting looms sucks There's probably a fair bit left in mine, but after removing 5kg worth I got fed up and called it a day lol
  18. #317
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    I'm mainly tidying it up. Removing all the huge block connectors, like the one in the picture.
    So far ive gotten rid of the MFD, heater controls, side repeater wiring, rear heated screen and wiper, all the instrument wiring and even the brake fluid sensor.
    Then got to move the fuse box and relays to the center of the dash. Might go for circuit breakers instead of fuses if i can get them at reasonable price.
    Your right mate - its a right ball ache!!
  19. #318
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    You've taken it past the MOT point, lol. I had to stay within that boundary
  20. #319
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    So should have i!!!!!!lmaolmao
    The only problem i can see is the side repeaters....... but its a good job i know a Rally car friendly mot place.
  21. #320
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    I need side repeaters, otherwise people won't see me at the side of the road waiting for the RAC lmao
  22. #321
    Jul 2003
    Istanbul, Turkey
    TerranoII & Corsakit
    Hello Mates,
    I would like to know that the measurements of your wheel alignments. I felt the back very tricky on the mud and trying to figure out why.
    My alignment values are,
    front camber: -1.3 degrees
    front caster: 4 degrees
    front toe: 0.5 millimeters out (total toe)
    back camber: -2.5 degrees
    back toe: 6 millimeters out ( I think that is the main cause that I can't hold the back as I want) But it is symmetrical (2.8mm left 3.2 mm right side)
    I would like to know your comments on that.
    cheers,
    Azmi
    I am a happy and speedy tortoise
  23. #322
    Jan 2009
    Oud Gastel
    Astra G SW, nova 1.3
    Quote Originally Posted by azzmi View Post
    a little competition from this weekend.
    http://www.elk.itu.edu.tr/~azzmi/pics/ss.avi
    By the way Astras driveshafts worked well. Thanks again marcel.
    Great to hear that Azmi. Hope it will work the whole year for you. But we refresh the shafts over 3 rallies.
    Gr. Marcel
  24. #323
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Hello Mates,
    cheers,
    Azmi
    toe out on the rear will make it oversteer more, and make the car more 'snappy' so if you're finding you cant hold a slide then this maybe the issue, fairly easy to shim the hub off the rear beam to correct it
    SHoNkyOpELs.de
  25. #324
    Sep 2008
    Hello Mates,
    cheers,
    Azmi
    The back wheels should have 1mm to 2mm toe IN. That will make a massive difference to the handling of the car, much easier to drive.
  26. #325
    Jul 2003
    Istanbul, Turkey
    Thank you for your comments, I think I will correct it by shims.
    Last three months were like a year to me. I worked days and nights to get the car together. Still have issues with power steering (I will change it to electric PS), A blown front suspension from last rally and a misterious electrical fault which leads seriously misfiring for 15-20 minutes after any deep watersplash. (car can't even moves, no power at all but idling. I think water in tps sensor to blame). I have some time to inspect them all to the next rally about 3 months away.
    I made a slideshow with music to summarize this three months and like to share with you.
    http://www.elk.itu.edu.tr/~azzmi/pics/toplama.avi
    cheers.
    Azmi
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
