Page 11 of 41 FirstFirst ... 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... LastLast
Results 251 to 275 of 1004
Thread: Corsa Maxi rally car
  1. #251
    Jan 2009
    Oud Gastel
    Astra G SW, nova 1.3
    Re: Corsa Maxi rally car
    Because of changing plans we are going to sell our Corsa B kitcar. For further details see our website: www.p-a-rallysport.nl
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Why the change? How much will the corsa be?
    rob
    If I ain't earning it - I'm spending it!!
  4. #253
    Jan 2009
    Oud Gastel
    Quote Originally Posted by robertkassner View Post
    rob
    My driver is going to build a new home and workshop for himself. And after that he would like to buy someting with seq. gearbox like S1600 or c2r2.
    But when the car isn't sold we drive still the Dutch championship.
    Marcel
  5. #254
    Jul 2003
    Istanbul, Turkey
    TerranoII & Corsakit
    Hi Mates,
    Here a picture after a 90 degrees right turn (just before we stood still in superspecial).
    I also like to know your opinions about why both sides of driveshafts had broken instantly after a little fly off over a bump. I am suspicious about driveshafts length doesn't match with suspension travel or my limited slip differential is a bit tight.
    Any comments will be appreciated.
    I am a happy and speedy tortoise
  6. #255
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    Looking fantastic!
    Do you know how much plunge in the shaft you have? You need to measure it on full extenstion of the suspension as well as when there is weight on the car. This could be wrong and would cause the shaft to break. If there is too much then a spacer between the cv and hub will do - if there is too less then you'll have to shorten the shaft (somehow)
    hope this helps mate
    Rob
  7. #256
    Jul 2003
    Istanbul, Turkey
    thank you Rob,
    I'll check them on friday night then I'll post the result here. I like to point that my shafts have modified production type (of opel vectra) CV joints. I will take the pictures all modification and repair process to send here.
    best wishes,
    Azmi
  8. #257
    Jan 2009
    Oud Gastel
    Quote Originally Posted by azzmi View Post
    thank you Rob,
    best wishes,
    Azmi
    Hello Azmi,
    We use always driveshafts from a Astra F Gsi, we don't have any problems with breaking at all.
    Greetings Marcel
  9. #258
    Jan 2009
    Danmark
    opel corsa b ki
    vill the length of the driveshafts from a Astra F Gsi fit a kitcar
    have foto cant opload it
    my driveshafts a made like thes
    out. CV joints. spidan 20183
    in. joints. spidan 21561
    output flanges
    driveshafts
  10. #259
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    I dont think they will. I know Astra GTE/GSI shafts fit a standard track corsa with the pilbeam/hhms bottom arms but if its wide tracked i dont think they'll fit.
    If you send the pic again ill upload it Donlop
    Rob
  11. #260
    Jul 2003
    Istanbul, Turkey
    Hello Marcel,
    Do you use them without any modifications? if so, what kind of surface you use them? gravel or tarmac or both?
    Hello Donlop, can you Email the pictures to me? my Email address is a.d@elk.itu.edu.tr
    mates I have just received a picture from a spectator,
  12. #261
    Jul 2003
    Istanbul, Turkey
    pardon me Rob, I wrote nearly same thing with you at the same time.
  13. #262
    Apr 2007
    Doncaster
    A4 + Corsa kit car
    lmao Great minds and all that lmao
  14. #263
    Jan 2009
    Danmark
    opel corsa b ki
    the driveshafts a ca + 50mm as the pilbeam/hhms wide tracked
  15. #264
    Jan 2009
    Oud Gastel
    Hello Marcel,
    Hello Azmi,
    Yes we use them without modifications. And we do most drive on tarmac but they are also very good on gravel.
    Greetings Marcel
  16. #265
    Jan 2009
    Danmark
    opel corsa b ki
    Quote Originally Posted by BKitcar View Post
    Hello Azmi,
    Greetings Marcel
    standard driveshafts fit pilbeam/hhms bottom arms if its wide tracked without modifications.
  17. #266
    Jan 2009
    Danmark
    opel corsa b ki
    Ive read that project thread again Kev and it just says 'customer' but the way i read it, i thought he built the car!
    How big was the trophy then mate? Im sure they'll be many more!
    rob
    project thread can you make a link to it
  18. #267
    Jan 2009
    Oud Gastel
    Hello,
    If someone knows a good F20 dogbox let me know. A friend of mine is searching for it.
    Marcel
  19. #268
    Dec 2008
    Milton Keynes
    Corsa Rally Car
    Guys im considering to go wide track the same as you later on this year but wanted to understand what modifications and parts etc i would need to do it?
    I guess the body kit is from harry hockleys and is fia approved? do the drive shafts, suspension, bottom arms etc all have to be replaced?
    also how is the back arches fitted to the shell and how much cutting of the original arch is there?
    sorry for all the questions but just want to make sure that if i do it i have the funds for the whole lot!
  20. #269
    Jul 2003
    Istanbul, Turkey
    Hello Mates,
    I have removed the driveshafts with the believe of the CV joints are broken. But I have hugely suprised when I saw both shafts are sheared from solid steel shaft section.
    Since the shafts are custom made and there is no time to machining new ones, I think I will try astra Fs shafts. Thanks again Marcel.
    cheers,
    Azmi
  21. #270
    Dec 2007
    West Yorkshire
    MG ZR
    Ouch!!!!
  22. #271
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    that looks nasty! what material are they made from? and what sort of heat treating process was used?
    SHoNkyOpELs.de
  23. #272
    Jul 2003
    Istanbul, Turkey
    Hello Lee,
    I think it is clear that the long shaft is over harden and short one seems a little more soft. As I mentioned before, I have bought the car few months ago and unfortunately not much information about its history. I have to admit that, I have never suspected about solid steel bars to shear instead of CV joints, I have checked them superficially (for any bending, slackness etc.) then I put back them to they places. My problem is there is the last rally of the winter season this weekend. I hope the standard shafts will be ok. otherwise I will have much time to think what has gone wrong.
    waiting the comments,
    regards,
    Azmi
  24. #273
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    yeah i think you're right from the photos, i'm with you though, it seems odd, must really be down to material defect or simply wrong choice of steel for the shafts, as even a plunge problem wont cause shearing like that!
    hope you get it sorted anyway
    SHoNkyOpELs.de
  25. #274
    Jul 2003
    Istanbul, Turkey
    thank you mate, if I make some progress I will let you know.
    Best Regards,
    Azmi
  26. #275
    Jan 2009
    Danmark
    opel corsa b ki
    Azmi you can call me
  1. 27-01-2012, 00:32
  2. 23-12-2011, 22:35
  3. 29-11-2011, 16:22
  4. 29-11-2011, 14:46
  5. 27-10-2011, 18:34
  6. 23-10-2011, 11:20
  7. 04-09-2011, 21:24
  8. 08-06-2011, 00:58
  9. 31-05-2011, 20:22
  10. 15-05-2011, 20:29
  11. 01-05-2011, 19:49
  12. 29-03-2011, 14:08
  13. 29-03-2011, 14:08
  14. 01-03-2011, 22:24
  15. 22-02-2011, 16:13
  16. 19-01-2011, 16:43
  17. 06-01-2011, 09:18
  18. 01-12-2010, 14:57
  19. 28-10-2010, 10:45
  20. 20-10-2010, 21:40
  21. 06-07-2010, 21:31
  22. 06-07-2010, 19:56
  23. 25-03-2010, 21:49
  24. 30-10-2009, 01:30
  25. 21-11-2008, 17:16
