Page 2 of 64 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 52 ... LastLast
Results 26 to 50 of 1599
Thread: Workers workshop (nova/corsa turbo in progress)
  1. #26
    Rs1
    Rs1 is offline
    Dec 2004
    Newcastle
    C20LET
    Re: Turbo Gavs Nova turbo rebuild thread!
    Quote Originally Posted by turbo gav View Post
    Thanks for nice coments
    I knew this would come up. i wanted to but was advised not to.
    More gen on that please
    Was gonna have mine flushed aswell.
    "THE ROB"
    Jun 2007
    leeds
    vectra 2.6 v6
    stunning car pal
  4. #28
    Sep 2006
    West Yorkshire
    Looks awesome with that turbo on it
  5. #29
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by Rs1 View Post
    Well how is he going to fill it up with oil? I will get my coat...
    Back in the scene
  6. #30
    Jan 2003
    SHEFFIELD
    GT35R 1.2 LS
    mincer. think im dreading your aeroquip bill too
    6 SPEED, LSD, MINT GREEN BALLISTIC BOGEY. TOTB 09 FWD SHOOTOUT WINNER
    10.9 @ 132 ON TREADS
    MAPPING AND SETUP BY RICKY @ www.race-tech.net
  7. #31
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    forgotten about my thread just been really busy at work and waiting for all the parts to arrive, started ordering parts in Feb and have ordered a fair amount every week since then....well as much as i can afford msl:
    Gearbox looks very clean now
    Clutch did arrive at last after 5 1/2 weeks and flywheel was skimmed
    All the bottom end is built up but it took 4 days of chasing to find the correct torque seeting for ARP L19 big end bolts which are 55 lbt/ft if anyone ever needs to know
    Inlet is back and looks huge out of the car Welding looks good to me
    Hope it all works ok just got to mount the solenoids and distribution blocks where i want them and make the support bars from back of block, soo much room underneath now!!
    Tomorrows job is to fit up the Tigra PAS rack and see how much it needs machining, i have been told the pipes are a total arse so i will get it all in before the engine goes back in later this week. All the new bolts for everything turned up today from Autovaux on time i may add just need to fit all the pulleys and pumps etc, torque all the big ends and head down and thats the engine ready.
    Slam panel is back from powder coaters and now matches my colour scheme (oh how Bux is that msl: ) and should take the heat from the turbo better too
    Updates when i get time later in the week
  8. #32
    Feb 2002
    West Yorks
    Vectra 3.2 GSI
    The inlet looks promising, what throttle body are you going to use?
    Oh and the colour scheme rock too
  9. #33
    Aug 2006
    huntingdon
    Quote Originally Posted by wazpaz View Post
    Mustang 75mm one, its abit over kill but should work ok.
  10. #34
    Dec 2004
    willingham near camb
    corsa xe, vectra 3.0
    Nice work. What box is that ?
    ASTRA TURBO PROJECT:http://www.migweb.co.uk/forums/projects-restorations/418177-ashtals-astra-mk4.html
  11. #35
    Is looking good, inlet looks hard core.
    How come you have the sump pump mounted to the front?
  12. #36
    Aug 2006
    huntingdon
    Have not tried it on the back as i was told it would hit on the driveshaft
    It does fit where it is however
  13. #37
    Ah cool, just wonder as lee has is mounted on the back...
    Come on fast.
  14. #38
    Aug 2006
    huntingdon
    Quote Originally Posted by ashtal View Post
    Ash which one do you think? the only ones that dont seem to break lmaolmaolmao
    F28 FTW
  15. #39
    Dec 2004
    Nice, all starting to come together now.
  16. #40
    Dec 2004
    By the way, i need to know where you got your slicks and how you widened the steel rims Got to make a shopping list from my next project.
  17. #41
    Aug 2006
    huntingdon
    Had a good day on it today, enlarged the hole in bulkhead for the PAS rack and fitted it up to see how much difference there was (60mm) and got hold of a Paxo pump to get fitted up.
    Engine is built now but could not finish as i didnt have a single pulley for alternator which needs to go on before dry sump pulley DOH left the sump off as it is easier to lock crank for doing the E20 bolt up. had to modify the backing plate quite abit to work with the dry sump takeoff plate but it all fits now.
    Brake lines, power steering rack/pump and servo and its engine back in time :clap: cant wait should be back in this time next week
  18. #42
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    very smart, how come you used a pricey sbd manifold instead of just cutting a C20 one? would have been much cheaper.
  19. #43
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by GBE86 View Post
    Because mine is done that way and he could not be outdone lmaolmao
    Nar its just easier IMHO and looks better.
    Back in the scene
  20. #44
    Aug 2006
    huntingdon
    Inlet ports are oval and the runners on manifold are round, they also need to taper from 50 mm to 42 mm iirc so the sbd manifold was perfect for the job,also comes with a fuel rail which has mountings ect. next manifold will use oval ports and a new flange. I have more money than Rick anyday (NOT), specky has had trouble with his cracking on the join between new and old manifolds too.
  21. #45
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Gav that inlet look s**t hot! Is it going to fit??
    Re your powewr steering. I gave Jonboy plenty of advice about it, I'm just interested what you do re the track rods being too long as I cant get my Nova through the mOT as it is due to my track rods having being sleeved & welded. Its not road legal.
    Let me know what you are going to do or have done? I'm thinking custom track rods next!
  22. #46
    Macclesfield
    www.Retrobike.c
    Quote Originally Posted by CraigGreen View Post
    Why dont you have the track rods re-threaded then cut and shorten them to the desired length? Thats how i would do it.
    Back in the scene
  23. #47
    Jun 2003
    way-out-west
    4 spd 1.2 Nova
    Quote Originally Posted by Rick Draper View Post
    The rods actually taper down in thickness right after the std threads end. Thats the logical thing to do Rick I know, first thing I looked at.
  24. #48
    Aug 2006
    huntingdon
    Waited 4 days to get hold of another bottom pulley as sold the last one (twat)
    Yet more problems as now the pulley and alternator belt clash with the oil gallery fitting ffs :cry:
    Have a few ways round it
    got the inlet sorted last night and got vac/boost feeds in etc and nitrous injectors in place just need to mount solenoids and plumb it up. I know there are loads of fittings but I ****ing hate T pieces. all used except one
    Yes i know they are not facing the correct way but they ended up near middle so i am well happy
    Rack is back together and looks spot on just need to clean the pump and mount it before I get the pipes made on Friday night.
    sent a few bits off to be blasted as I am a into bling these days hahah
    If a can get the pulley sorted before the weekend the engine can go back in as i only get Sundays on the car really.
    NEEEEED a fast car back out soon i am starting to get bored of my work van :lol:
  25. #49
    Dec 2003
    Dartford, Kent
    Corsa 2.0 16v AWOL
    Nice progress gas, just wondering any reason behind not using a corsa c epas system, as i would have thought would have left you more room/been easier
    shonkyopels.de
  26. #50
    Nov 2005
    chester/n.wales
    evo 6 gsr
    looking good gav. gona be nice to see it back on the road. im just waiting for payday to try and finish building my motor, as fed up of my polo lol. but had some probs at home now, so may be a month or two now til back in.(£1200 mortgage) sucks ass.
    you gona be running the strip once built
Tags for this Thread
