LinkBack (8) Thread Tools
Old 31-08-2008, 22:15   #51
Drives: corsa 4x4
Re: My Corsa Turbo 4x4
Originally Posted by GBE86 View Post
shouldnt it have a boot on it to stop ****e getting in and chewing it to pieces?
also do you have any pics of the reinforcement for the rear subframe, correct me if im wrong but it looks simply bolted to sheet metal??
loving the ghetto twin exit
it did have one on but fell of a few weeks ago iv got to put one back on,
trust me mate its far from being bolted to a sheet of metal there is a frame welder up from 6mm tubing and bars, then i box's it all in with sheet metal , if sum one ran in to the back of me its going to kill the front of there car lol.
as for the pics i had them on my camera but they were deleted by an accident... thats wot she said lol
rickya130 is offline   Reply With Quote
Old 01-09-2008, 20:50   #52
Drives: corsa 4x4
im putting this post on hear cuz im getting loads of emails asking how i did it
i used the complete back axle of a calibra hence the reason for the wide arches, but with doing this i had to fit calibra front hubs to match the 5 stud axle, so the hubs had to be machined down with different wheel bearings fitted to fit on the corsa.
i did cut the complete floor from the back of the calibra to behind the front seat, i was going to cut the corsa one out and fit the calibra one in, but that seemed a lot of work, so i welded new mounting points for the calibra axle to fit to, this alone took a lot of time and measuring cuz they had to be bang on. i had to have a smaller tank made up to fit under the car i didn't want a tank in the boot. the prop shaft has to be shortened i got hold of one already done. the engine has to set lower so that the prop shaft can connect to the transfer box, but not to low cuz the gear box will hit the tie bars, you have to make up your own mount and mounting point for the rear mount. the wiring for the 4wd that is the easy part to do, as long as you get a calibra below a l reg i think it is, anything above that it would be a lot more difficult cuz the speed sensor run of the abs, you have to use the calibra brake switch cuz its a make and brake circuit switch, or you can just buy a locked transfer box then you dont need the 4x4 ecu
Old 01-09-2008, 21:52   #53
Drives: Omega & 1.8 Corsa B
Can I ask, if you did all the work yourself why is the welding so piss poor on the exhaust? surely if you have the skills you wouldnt have given it to some monkey to weld it for you?
The home of miserable bastids!
http://www.grumpyc*nt.com
Davey is offline   Reply With Quote
Old 02-09-2008, 06:58   #54
Gagged
Drives: it like i stole it
wow...very impressed mate. i can only hope one day im capable of doing that kinda work myself... but then im probably too lazy to try such a big job anyways!lol
the styling is a bit 2 fast 2 furious stylee for me, but thats what modification is all about, its making the car how YOU want it, only a fool would spend all their hard earned making a car look how someone else wanted! besides, il bet with that styling you get all the 17yr olds in their mums cars tryin to race u at the lights...haha
top work fella
Pikey Motorsports is offline   Reply With Quote
Old 02-09-2008, 07:53   #55
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Great work, shouldnt the exhaust system have at least one hanger on it tho.. I know you said it was a bodge but..
Old 02-09-2008, 16:00   #56
Drives: corsa 4x4
like i said the exhaust was put on just to get the car on the road, cuz it had to go for a respray and to be mot'd then i was going to send it in to have a brand new system built, but i got very busy with work coming in so i left it.
i am rebuilding the engine in a few months, big turbo steel con rods and all the rest so it going to wait to then so i can have a 3'' system built for it.
the car only does about 1 mile a day just to get me to the gym thats way im happy to wait
Old 02-09-2008, 16:04   #57
Damn even if I only had 5 minutes to weld that I could do a better job with my hands up my own arse hole! So who did it then? Looks like its been done with a gasless mig and someone who's never touched a welder in their life.
Old 02-09-2008, 16:09   #58
Drives: corsa 4x4
top work fella
well said mate i do like it, dont worry mate i dont give a **** wot anybody thinks about it.
it is funny when u get sum dick in Subaru at the side of you, he thinks ha 1.4 then i just hammer him of the lights.
Old 02-09-2008, 16:36   #59
Drives: corsa 4x4
it as mate its got 3 2 at the back for the back box's 1 in the middle
Old 02-09-2008, 16:51   #60
Drives: corsa 4x4
**** me would u stop going on about the ****ing exhaust its pissing me off i dont care wot u can do with your hands in your arse to be honest u should keep that to your self!!!!!
if u want me to go in to detail about a ****ing exhaust it was done with a mig not a gas less one but it had ran out of gas, as for the exhaust its made up from steal, stainless steal and aluminum, bits and bobs laying around like i said, the wire that we had in the welder is for mild steal not stainless or alloy, none of the exhaust was cleaned up before welding!
Old 02-09-2008, 17:29   #61
jav786's Avatar
Drives: Vec GSI/Evo IV/Cav T
Like the 4x4 set up but not sure about body work
If you always tell the truth, people will stop believing you!
Migweb Approved Seller!
www.Vox-All.com - Vauxhall Specialist
jav786 is offline   Reply With Quote
Old 03-09-2008, 05:48   #62
Drives: c20let corsa gsi
It looks mint mate a least you have the balls to 4X4 a corsa, very nice work i bet you love it.
digidashcorsa is offline   Reply With Quote
Old 03-09-2008, 10:07   #63
MSG
Drives: Calibra 16V 2L P Reg
the only problem now is it won't wheel spin!! hence no smoke and melted tarmac!!! thats sad!!!even uphill!!
Calibra simply Calibra
I blessed Nemesis's Calibra and he got gagged, anybody else wants their Calibra blessed?
MSG is online now   Reply With Quote
Old 03-09-2008, 10:14   #64
Drives: Astra G Gsi Turbo
I luagh at this,...
Many time I've come on MIG to see people asking about 4x4 corsas and users teling them it's too much work, better off doing something else,.
Someone has come on, who has built a 4x4 turbo corsa, which to me looks like he's put a lot of time and effort into ans all people can do is bitch about it,
Who cares if the exhaust isn't perfect? It's been explained
The bodywork isn't to everybodies taste, but thats also been explained to be functional.
IMO he's done an amazing job,
Credit where credit is due, and stop moaning about the welding on the bloody echaust.
Corsa_shep is offline   Reply With Quote
Old 03-09-2008, 12:17   #65
Drives: corsa 4x4
thanks mate yea its good fun to drive
Old 03-09-2008, 12:22   #66
Drives: corsa 4x4
lol if i want it to spin mate all i have to do is pull the fuse out for the transfer box then its in front wheel drive
then u can get wheel spin happy
Old 03-09-2008, 12:24   #67
Drives: corsa 4x4
Originally Posted by Corsa_shep View Post
I luagh at this,...
lol lol well said mate
thanks mate!
Old 03-09-2008, 16:22   #68
thats a lot of work.
good luck
Rob
djrobski99 is offline   Reply With Quote
Old 03-09-2008, 17:49   #69
jav786's Avatar
Any Engine spec gen??
Old 03-09-2008, 18:33   #70
Drives: corsa 4x4
good luck
Rob
thanks mate
Old 03-09-2008, 18:46   #71
Drives: corsa 4x4
engine is still standard at the min, but in the next few months the engines coming out and being rebuilt, when its out im going to clean up the engine bay
Old 04-09-2008, 13:12   #72
nice pice of kit mate
liam1234 is offline   Reply With Quote
Old 04-09-2008, 17:55   #73
Drives: corsa 4x4
thanks mate
Old 08-09-2008, 20:22   #74
gra11's Avatar
Drives: Vectra / Corsa
good going mate must of been a lot of work
Team Ecowrek all the way!!!
http://www.bebo.com/Profile.jsp?MemberId=7738292687
gra11 is offline   Reply With Quote
Old 08-09-2008, 20:35   #75
It's called a stepping stone, one person has done it so another person can learn and better it, I agree with the above post in his defence.
WheelyBigCheese is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/359076-my-corsa-turbo-4x4.html
Posted By For Type Date
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:57
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 18:18
Lanos club -> Мастерская -Roger-а This thread Refback 02-01-2009 13:47
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 26-08-2008 08:36
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 24-08-2008 18:09
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 24-08-2008 14:09
Corsa Sport - for Vauxhall, Opel and Holden Corsa and Barina This thread Refback 24-08-2008 14:05
Members: 43,212
Threads: 310,608
Top Poster: LEE69 (43,149)
