27-05-2008, 13:28
#201 | | MIGWeb User
Join Date: Nov 2007 Location: Chesterfield Drives: Astra+CorsaLET, 306d
| Re: Project Deathtrap: Jack's 1.2 Corsa The early corsa gsi had C16xe,Late corsa gsi had X16xe. C16xe has same valves as X16 but bigger ports.  |
27-05-2008, 14:07
#202 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Would you not have saved by using Auto Vaux for some parts?
I assume you used your MIG card for trade prices? Just to confirm, that engine is a late GSi X16XE
27-05-2008, 14:40
#203 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
| Re: Project Deathtrap: Jack's 1.2 Corsa To make it easier when ordering parts, i just order everything for a 1.6 16v Tigra...
As they only have X16xe's fitted
No confusion then. |
27-05-2008, 14:56
#204 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by CraigGreen Would you not have saved by using Auto Vaux for some parts?
I assume you used your MIG card for trade prices? Just to confirm, that engine is a late GSi X16XE | Possibly, but I'm only ordering silly little things, and postage would have to go on top of Autovaux stuff.
Plus, at a dealer, I can look at the screen, point out what bits I want...etc. I get cheapness anyway as I'm a regular.  I think they can tell I'm going to be annoying buying bits for this engine.
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
29-05-2008, 14:27
#205 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Inlet manifold in the post, courtesy of Flame from CS.  Top bloke and very helpful.
My bits have arrived at the dealer too. Does anyone know if the big end bolts are stretch bolts? I want this piston out to clean up the bore, but I can only buy big end bolts in bags of ten, and apparently there are two sorts.  If they're not stretch bolts I can just re-use them.  |
29-05-2008, 16:30
#206 | | Administrator
Join Date: Feb 2002 Location: Fareham, Hants. Drives: 1.3L GTE 16V SXi Est
| Re: Project Deathtrap: Jack's 1.2 Corsa I think they are, but re-use them anyway. You'd be surprised how many bolts are stretched ones on an engine that get re-used regularly. |
29-05-2008, 16:44
#207 | | Regional Co-ordinator
Join Date: Oct 2002 Location: South London/ Surrey Drives: ACT Nova TBs & less
Originally Posted by Astra Dan I think they are, but re-use them anyway. You'd be surprised how many bolts are stretched ones on an engine that get re-used regularly. | Agreed! How many people change cam and crank bolts  |
29-05-2008, 18:47
#208 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa  Fair enough!
My manifold has arrived.  And I picked up some very nice 256mm callipers from Mr. Ives.  |
29-05-2008, 19:48
#209 | | Administrator
| Re: Project Deathtrap: Jack's 1.2 Corsa FT and a dab of threadlock will see you roight. |
30-05-2008, 14:26
#210 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa |
30-05-2008, 14:37
#211 | | MIGWeb User
Join Date: Jun 2006 Location: Suffolk/Staffs Drives: 78 Kadett C
| Re: Project Deathtrap: Jack's 1.2 Corsa yay! hope you get some good use out of them calipers, you saved them from a slow horrible death
That's not bad for discs&pads ^^
__________________ Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me! |
30-05-2008, 14:42
#212 | | MIGClub Member
Originally Posted by djivesp yay! hope you get some good use out of them calipers, you saved them from a slow horrible death  |
I really appreciate it man, and your directions were spot on. Quote:
Originally Posted by djivesp That's not bad for discs&pads ^^   | I thought that too, although I'm tempted to treat the Cav to new discs and pads and put the old stuff on the Corsa, considering the light use it's going to get.  Both 256mm x 20mm I think. |
30-05-2008, 14:58
#213 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: Project Deathtrap: Jack's 1.2 Corsa if they are 2.0 calipers youve got im sure they are 24mm rather than the 20mm ones
__________________ MIG Performance Vauxhalls WELSH Member |
30-05-2008, 15:04
#214 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa oh ****, yes that's dead right ^, i remember the calibra discs being thicker than the corsa's of same size!! Are you sure the cav's arent 24mm too jack ? It would make sense for a bigger car! |
30-05-2008, 20:01
#215 | | MIGClub Member
Join Date: Apr 2006 Location: Telford Drives: Astra Mk3/Mk4 Cabrio
| Re: Project Deathtrap: Jack's 1.2 Corsa I'll have a scout around for them 256mm discs Jack, I'm off to bedford tomorrow so I can drop them off en-route
__________________ 1.8 Mk4 Astra Cabrio rolling on 18s 1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns |
30-05-2008, 20:51
#216 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa I'm unsure of the cav TD BUT 2.0 8v's still use the 24mm width! Does your cav use BB outer CV's? |
30-05-2008, 20:54
#217 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa I'll get the tape measure out tomorrow.
I've no idea Rob!  I've never even had the discs off the Cav!  |
30-05-2008, 20:55
#218 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Double post. |
30-05-2008, 21:02
#219 | | Regional Co-ordinator
30-05-2008, 21:20
#220 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Had it two years and done almost 30'000 miles in it. Never touched the front brakes.  Still loads of life left in them! |
30-05-2008, 21:25
#221 | | MIGWeb User
Join Date: May 2007 Location: ............ Drives: ....................
Originally Posted by Jack Had it two years and done almost 30'000 miles in it. Never touched the front brakes.  Still loads of life left in them! | You must drive slooooooooow or brake soooooft
i avg 20k from most , but i blitzed a pair in 10k with greenstuff pads once  |
30-05-2008, 21:30
#222 | | MIGClub Member
Originally Posted by chrisscirocco You must drive slooooooooow or brake soooooft  |  Both! I'm not heavy on brakes at all, usually because I've got heavy stuff in the boot!
In fact, they squeak something terrible because I never use them properly. They've probably glazed over and I've never braked hard enough to clear them up again.
They looked good when I got the car, and there's still a fair bit of pad left. |
30-05-2008, 21:36
#223 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa My dads brakes always squeek on his car till i drive it for a few miles and actually remove the rust lol  |
02-06-2008, 09:09
#224 | | MIGClub Member
02-06-2008, 09:15
#225 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa What you gonna do, hone it out or look for another block? |
Members: 43,215
Threads: 310,618
Top Poster: LEE69 (43,150) | | Welcome to our newest member, nick3733 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
