Old 19-05-2008, 14:42   #151
Drives: Corsa 1.4 Corsa 2.0T
Re: Project Deathtrap: Jack's 1.2 Corsa
ROTFPMSL @ vauxhall prices, hope you laughed when they quoted that, i know i laughed when they quoted £21 for a downpipe sealing ring, which is £2 in the factors.
www.autovaux.com gets my vote, they are usually genuine and under half dealer price.
Gaz86 is offline   Reply With Quote
Old 19-05-2008, 14:48   #152
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Great mincing Jake!
I'd imagine all that coking is normal on these engines as they are plagued with crappy valve guide issues & EGR blocking problems from new. Junk the std ECU & fit some budget Megasquirt with either bike TB's or a Mantzel inlet IMO.
V8 blender FTW
Old 19-05-2008, 15:12   #153
Jack's Avatar
Drives: Cavalier 1.7 TD
Does anyone know definitively if the guides are replaceable?
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Jack is offline   Reply With Quote
Old 19-05-2008, 19:08   #154
Fow16v's Avatar
Drives: Astra Coupe Turbo
the guides are replaceable yea but i found it hard to get hold of them when i needed some, could only find brass ones, in the end i took it to an engine builders as they need to be heated up and pressed out
WELSH Member
Fow16v is offline   Reply With Quote
Old 20-05-2008, 20:48   #155
Jack's Avatar
I'll let the photos speak for themselves.
Caps are numbered! Ultimate sex!
As bent as Stu_CDX.
The test to see if valves are bent. Roll them down the side of a bench! Clever dad!
While we were mincing about, we had a visit from Uncle Andy, who told us his lad has finished making his 4x4, apparently called "Mitsimog". I've just Googled for it and it's bloody everywhere!
http://www.pirate4x4.com/forum/showthread.php?t=661186
Some photos of it!
Old 20-05-2008, 20:59   #156
Lugy's Avatar
Drives: Saab 9000 2.3T
Thats some serious axle articulation
MIG Performance Saabs
Lugy is offline   Reply With Quote
Old 20-05-2008, 21:12   #157
MIGWeb Moderator
RobJenko's Avatar
Drives: mk3 astra
did you really need to roll them to see if they were bent?
Wales Regional Co-ordinator
Buy a mig calender! - MIGclub Calendar 2009 - click to order
RobJenko is offline   Reply With Quote
Old 20-05-2008, 21:12   #158
Jack's Avatar
No, but we did the straighter ones just out of curiosity.
Old 20-05-2008, 21:14   #159
MIGWeb Moderator
RobJenko's Avatar
Drives: mk3 astra
so were any straight or did ben bend them all?
Old 20-05-2008, 21:16   #160
Jack's Avatar
Nah, they're all ****ed.
We were going to have the exhaust valves out too but we ran out of daylight. I need a proper spring compressor anyway, ours wasn't long enough. Had to improvise with a socket and a magnetised screwdriver to fish the collets out with.
Old 20-05-2008, 21:16   #161
looks like you may have gotten away with the guides by the looks of it, get the magnifying goggles out!
Old 20-05-2008, 21:27   #162
Benn's Avatar
Drives: A shineeeey Nova
That jeep things abit hardcore!
What the funk did ben do to that?!
Old 20-05-2008, 21:45   #163
Drives: ....................
I saw the belt damage but didnt realise it had fasiled!
Is it a good idea to use some grinding compound on the new valves and spin them in the guides, to help seat them better in the holes/guides,
ive seen this done on a little 2 stroke engine, not sure if its a good idea though
chrisscirocco is offline   Reply With Quote
Old 20-05-2008, 21:47   #164
Jack's Avatar
It's just slipped a few teeth I think.
Old 20-05-2008, 21:53   #165
Rubix_Cube's Avatar
Drives: Subaru Impreza WRX
bent as STU_CDX
Are you not better off just going for a complete low mileage head to save you from buying new Guides / Valves & keeping the cost down ??
Rubix_Cube is offline   Reply With Quote
Old 20-05-2008, 21:55   #166
Jack's Avatar
Yeah, but then there's the feeling that a second hand head is an unknown, whereas a head we've built up, I'll know it's good.
I was tempted with another head, but now we've started taking this one apart, I am really enjoying it and looking forward to getting it all back together. Guides look alright!
Old 20-05-2008, 22:02   #167
Rubix_Cube's Avatar
Fair enough mate
However those valves have take a bit of a hit so I would really think about changing the guides just to be on the safe side - then you know it'll be 100% ok
Old 20-05-2008, 22:29   #168
Drives: Suzuki SJ410 WV
yeh its good to grind the valves on any 4-stroke engine rebuild, course 1st then work your way down to fine, are you sure it was a 2-stroke u seen some1 grinding the valves on, sorry to seem a bit off but as far as i know 2-stokes dont have valves.
btw jack nice project, when are you going to check the exhaust valves?, is there any visable damage to them while in the head?
wascool2 is offline   Reply With Quote
Old 20-05-2008, 22:40   #169
Yeah your right
It was a lawnmower so i just assumed,, must`ve been a 4 stroke, i shouldve concentrated more when the chap was teaching me lol,,
ive never pulled apart a 2 stroke actually(hmm maybe an old bike project
Old 21-05-2008, 07:50   #170
Jack's Avatar
We ran out of daylight last night, it'll probably be the weekend now.
Old 22-05-2008, 09:38   #171
CraigGreen's Avatar
Atleast its hands on stuff anyway. Makes a good read.
Old 22-05-2008, 09:53   #172
Gagged
Drives: Corsa Sport C20XE
done a good job on the valves lol
Corsa Sport c20xe soon!
chris_16v is offline   Reply With Quote
Old 22-05-2008, 10:26   #173
Jack's Avatar
Valves and a complete top-end gasket set on the way!
Old 22-05-2008, 16:37   #174
Jack's Avatar
Anyone ever been stupid/brave enough to use pattern valves?
Jack is.
Old 22-05-2008, 16:47   #175
Drives: 16v Nova, Astra TD
"Just slipped a few teeth"
Thats a fooking understatement and a half, every valves f**ked?
Edit-All that damage from a cam sensor bolt falling into the belt
"Runs out to check tightness of the ones on mine"
LongLiveTheNova is offline   Reply With Quote
Tags
corsa, rusty, sexy
Members: 43,215
Threads: 310,615
Top Poster: LEE69 (43,150)
Welcome to our newest member, nick3733
