Old 18-05-2008, 15:27   #126
Jack's Avatar
Drives: Cavalier 1.7 TD
Re: Project Deathtrap: Jack's 1.2 Corsa
Took all of the old interior down to the tip!
Random little ****er seatbelt bolt was really ****ing tight! Took about six repetitions of WD40, screw it back in, screw it back out, WD40 to get out. ****ing tight little ****!
Handbrake lever pulled out, cleaned and greased. Might as well do all these little poopy jobs while the weather's good!
Got the last little bits of carpet out. Got the seats out and put the little tabs in the pre-tensioners (cheers Tom! I'd forgotten they were there ). Got most of the rear seatbelts out, but got pissed off with a couple of bolts. A job for another day!
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Jack is online now   Reply With Quote
Old 18-05-2008, 19:57   #127
Jack's Avatar
Right, time for some after-dinner mincing on the GSI engine that I picked up. First impressions are that it's a grubby engine that's had a bit of abuse, but nothing we can't salvage.
First problem. Bottom pulley lined up...
Shouldn't they line up too?
And that shouldn't be there! Where has that fallen from?
Ah, it's out of here!
Mmmmmm, chewy!
Apart from the obvious, the rest of the engine appears to be in pretty good shape!
Lovely and clean and no obvious wear.
Nice!
Spot the obvious problem?
Extreeeeeeeme close up! Woooooooooooooaaaaaaaaahh!!
Mashed.
They look a lot better with the dirt cleaned off!
Some very slight bore damage! You can barely feel it. In fact, if you didn't know it was there, I don't think you would feel it. Initial thoughts are to forget we've seen the mark and just replace all the valves.
Awesome!
All packed away again.
Old 18-05-2008, 20:11   #128
Jack's Avatar
Just checked, we've got it lined up with the wrong marker in the photo, but we checked it against both.
Old 18-05-2008, 20:33   #129
Drives: ....................
looks like its missed a few services lol,, was the head gasket on the way out?
looks as if it`ll go back ytogether nicely with a few new bits though
chrisscirocco is offline   Reply With Quote
Old 18-05-2008, 20:41   #130
Jack's Avatar
No idea about the head gasket, but it certainly looks a bit unloved.
Old 18-05-2008, 21:01   #131
tommychimp's Avatar
Drives: Astra Mk3/Mk4 Cabrio
Looks ok apart from the obvious bits, out of interest what was the oil like? It's usually a good indicator to the condition of the engine.
1.8 Mk4 Astra Cabrio rolling on 18s
1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns
tommychimp is offline   Reply With Quote
Old 18-05-2008, 21:11   #132
Drives: around looking Cool!
black no doubt
Old 18-05-2008, 21:47   #133
Jack's Avatar
We've not drained it yet, but the oil I've seen so far has been black but still consistently runny. There's no big lumps or anything floating about in it!
Old 18-05-2008, 21:51   #134
tommychimp's Avatar
Mind you last time i saw it half of the oil was blown over the engine bay which probably means that it was regularly topped up, so the oil would be fairly new.
Old 18-05-2008, 22:22   #135
Drives: Corsa 1.4 Corsa 2.0T
where did you get that lump from, congrats to whoever bust it never seen one with so little damage, they usually go in spectacular form.
Gaz86 is offline   Reply With Quote
Old 18-05-2008, 22:29   #136
Jack's Avatar
It's Chav's old engine out of his white GSI!
Old 18-05-2008, 22:59   #137
Gagged
Drives: Corsa Sport C20XE
loving the thread, get the engine done mate, the damage isn't too bad
Corsa Sport c20xe soon!
chris_16v is offline   Reply With Quote
Old 18-05-2008, 23:40   #138
ad4mb1nns's Avatar
Drives: carefully....
need any spare parts then?
Turbo Nova
ad4mb1nns is offline   Reply With Quote
Old 19-05-2008, 06:50   #139
Jack's Avatar
Only a million valves.
Old 19-05-2008, 08:36   #140
Fow16v's Avatar
Drives: Astra Coupe Turbo
nice and black in there, shame about the bores is it just the one? if you know the engine from before how badly did it smoke if at all? that one valve looks a bit really fooked, pain in the ass to get out like that as the valve spring compressor dont sit straight on there. id say you will need valve guides too as they will be cracked. i have rebuilt one before tho without renewing them as it was just a cheap runabout and it was fine
WELSH Member
Fow16v is offline   Reply With Quote
Old 19-05-2008, 09:13   #141
Jack's Avatar
Just the one bore, but it looks far worse on photos than it actually is.
It didn't smoke at all, to my knowledge. It had a bit of abuse, but you'd be hard pushed to buy a second-hand engine that hadn't!
Yeah, we'll do the valves and guides, although I'm still tempted to try and find a C16XE head with bigger valves...
Old 19-05-2008, 09:43   #142
Jack's Avatar
Just PM'd Stu_22 on CS about a sexy Mantzel-style manifold.
Old 19-05-2008, 09:47   #143
Drives: like its a hire car
So glad you didnt choose to use the really expensive xe in the end, this must be saving you a fortune!
alistairolsen is offline   Reply With Quote
Old 19-05-2008, 10:20   #144
Jack's Avatar
Old 19-05-2008, 10:41   #145
Old 19-05-2008, 11:46   #146
Rubix_Cube's Avatar
Drives: Subaru Impreza WRX
Rubix_Cube is offline   Reply With Quote
Old 19-05-2008, 12:09   #147
can I also have a huge WTF at the state of the chambers, how the hell has a fuel injected engine run so ****ing badly to coke everything up to that extent! TBH I wouldnt be trusting the guides, seats or lifters now so Id be looking for a good complete head.
Given that youre still unsure about the ecu etc that too, so at this point in the project Id personally still bin that POS and get an xe
Old 19-05-2008, 12:18   #148
Jack's Avatar
It's actually the head gasket that flaked apart and broke up as we took the head off. A quick clean made it look beautiful!
A good, complete head would be the easiest solution. ECU isn't a problem either any more, as we have the original sensor ring and key from the car.
Old 19-05-2008, 13:39   #149
Jack's Avatar
Just rang Vauxhall, valves are £30.37 each and guides aren't listed.
Or I can get all 8 for £20 non-genuine.
Old 19-05-2008, 14:02   #150
DaveB's Avatar
Drives: Corsa XE with TBs
www.autovaux.com MIG discount aswell
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is online now   Reply With Quote
Tags
corsa, rusty, sexy
Members: 43,215
Threads: 310,618
Top Poster: LEE69 (43,150)
Welcome to our newest member, nick3733
