05-05-2008, 18:48
#76 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: White 1.6 16v Nova
| Re: Project Deathtrap: Jack's 1.2 Corsa It may not actually be an immobilised ecu, some of the very early ones weren't
But all from around 1995 were |
05-05-2008, 19:11
#77 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa I suppose the only way to find out is to whack it all together and see what happens.
__________________ Cavalier: Going strong, 158'900 miles and 169ftlbs. Corsa: Never get any daylight to work on it! |
05-05-2008, 19:19
#78 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Got bored. Walked to the garage. Took one of the door cards off. Broke the ratchet in my screwdriver. Poxy bloody thing. Why can't you buy a torx...etc bit set that comes with just a normal screwdriver to hold the bits? Why does it have to be a poxy ratchet screwdriver?
Door card off. Car away. Me home again. |
05-05-2008, 19:23
#79 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: Project Deathtrap: Jack's 1.2 Corsa b and q fella, do a stanley one with removable ends no ratchet
__________________ MIG Performance Vauxhalls WELSH Member |
05-05-2008, 19:23
#80 | | MIGClub Member
Join Date: Dec 2007 Location: West Yorkshire Drives: carefully....
| Re: Project Deathtrap: Jack's 1.2 Corsa you got c16 or x16?
ive got a breaking x16xe if you want the key, ecu and whatever else for a small fee..
__________________ Turbo Nova |
05-05-2008, 19:33
#81 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by Fow16v b and q fella, do a stanley one with removable ends no ratchet | Legend, I shall mission to B & Q on my lunch break tomorrow. Quote:
Originally Posted by ad4mb1nns ive got a breaking x16xe if you want the key, ecu and whatever else for a small fee.. | An X16XE.
I think I'm right in thinking that I would need the key, the sensor ring and the ECU.  |
05-05-2008, 19:54
#82 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa You need it all !
However without having to change your locks you can just swap the transponer chip into your current key iirc !
BRING ON THE TRUMPETS ! |
05-05-2008, 20:00
#83 | | Regional Co-ordinator
Join Date: Sep 2005 Location: Midlothian, Scotland Drives: Saab 9000 2.3T
Originally Posted by Fow16v my old one definatly started then cut out when i used a spare key with no chip, make sence what everyone is saying tho that there would be more than one circuit protected if it matched with ecu | Same as mines
It was a mid '95 car if that made any odds.
__________________ MIG Performance Saabs |
05-05-2008, 20:01
#84 | | MIGClub Member
Originally Posted by Jack I think I'm right in thinking that I would need the key, the sensor ring and the ECU.  | erm yes
can have the whole car for 400quid lol bit of shed though  |
05-05-2008, 20:56
#85 | | MIGWeb User
Join Date: Dec 2004 Location: Birmingham Drives: Mk4 Astra SRi 2.2
| Re: Project Deathtrap: Jack's 1.2 Corsa Dude, funking R1 carbs or bike tb's on megasquirt - fook off all the ecu etc
Good base for a project - eBay will deffo be your friend on this one I think!
Give me a call if you want a hand doing 'owt - once i'm back on the road i'll be looknig for excuses to go for a thrash
__________________ Mk3 Astra Merit XE
One of the semi-old-school - now living at the only place for Vauxhall Technical Advice & Chat - Vauxsport.com |
06-05-2008, 07:16
#86 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa OK then, let's get the engine in and we'll try starting it up and seeing what happens. Doesn't seem much point buying stuff now if it works anyway.
Cheers Al, you sexy beast of a man. How's the XE coming? |
07-05-2008, 11:42
#87 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Interior stripping done:
- Door cards off
- Headlining down
- Kick panels and trim round the seats is off
To do:
- Rear interior to come out
- Carpet up
- All sound deadening up
Might take a grinder to the doors at some point as there is a crap-load of surplus. Going to make some little brackets to hold the door pin on the passenger side too, but at a bit more of an angle so you can't get to them with a slim-jim...etc. I'll remove the one on the driver's side as it's un-necessary, and the door has already been cracked from being pulled back by thieving types.
Once all the interior is out and down the tip I'll start disconnecting engine bits ready for the lift. Then the bay will be cleaned and tidied up and I'll take stock of the wiring, then get this little 1.6 sneaky thing ready.  |
07-05-2008, 12:31
#88 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa We need pictures ! |
07-05-2008, 13:50
#89 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Jack, in the interests of research... Why not weigh everything you remove & add to keep tabs on the cars supposed speed status.
it'd make a cool eperiment to use one of the 1/4 mile generators to calculate the times or terminal speeds etc & then see what it really does.
A 'Tom Stickland' type picture of the interior being torched would be good too!
07-05-2008, 13:54
#90 | | MIGClub Member
Originally Posted by Rubix_Cube We need pictures ! | Sorry man, I got a bit carried away.
I've taken some pictures of the money I've found in it so I can take it off the total price.
Weighing isn't a bad idea either.
I might have found someone that can make me a cage for nothing too...  |
07-05-2008, 14:05
#91 | | MIGWeb User
Join Date: Jun 2005 Location: West Berks Drives: QED Nova 2.1 16v
| Re: Project Deathtrap: Jack's 1.2 Corsa Cant believe you thing putting an XE in it would be expensive! Doner cars can be had very cheap, and your left with only an adaptor mount and 22 spline Gsi shafts with Cav 1.6 inner CV's to put on the shopping list!
But you have the engine now anyway  Good luck with it, and stop mincing lol
__________________ Best excuses so far....... 'My tyres went off','I was taking it easy','That guy in the skyline obviously cant drive' |
07-05-2008, 14:07
#92 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Pffffffffft, maybe an XE will find it's way in when I'm bored of the 1.6... |
07-05-2008, 15:20
#93 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Nah, you wont get bored of the smallblock. Just keep making it rev higher....... |
07-05-2008, 20:29
#94 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Be warned, cockspins. My dad's just mentioned "flywheel" and "lathe" in the same sentence.
This is going to be one pikey-ass car.
50p better off.
Allvaux's comedy sticker.  |
09-05-2008, 20:52
#95 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa |
09-05-2008, 21:11
#96 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Speakers? Dash? Capet? WFT! get on with the striiping!
__________________ Quote: |
09-05-2008, 21:19
#97 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa All the stuff I've got out is currently in the back of the car! Need to take it down the tip, then can get the back seats, front seats, carpet...etc up.
Don't have much free time, so it's like... walk to garage, roll car out, take something off, throw it in the back, roll car back in, walk home.  |
09-05-2008, 21:40
#98 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Pfft do it the man way.
Drive to the tip.
Remove seats capet and trims and throw it in the bin as you remove it.
Dont you northers get a wheelie bin? |
09-05-2008, 22:39
#99 | | MIGWeb User
Join Date: Oct 2001 Location: Bedfordshire Drives: Cavalier SRi
| Re: Project Deathtrap: Jack's 1.2 Corsa /\  |
10-05-2008, 04:57
#100 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
Originally Posted by CraigGreen Nah, you wont get bored of the smallblock. Just keep making it rev higher....... | im a bigblock man at heart but those smallblock xes dont half make a beutifull scream at full chat, bike bodies gets my vote with a dose of megasquirt  |
Members: 42,547
Threads: 308,185
Top Poster: LEE69 (42,904) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
