02-05-2008, 20:30
#51 | | MIGClub Member
Join Date: Apr 2006 Location: Telford Drives: Astra Mk3/Mk4 SRi1.8
| Re: Project Deathtrap: Jack's 1.2 Corsa I'll be going straight for an XE come christmas in the ashtray Jack, it just makes sense.
What's your budget towards the engine?
__________________ 1.8 Mk4 Astra SRi 1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns |
05-05-2008, 08:40
#52 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by tommychimp What's your budget towards the engine? | Well, last payday I got £330 over and above, so I'm spending that on car bits and pretending I never had it.
Rolled it out yesterday to swap the wheels around (as I'd borrowed some steels).
Managed to twist my wheelbrace they were on that funking tight.
A quick shot of how everything is now before hell breaks loose.
What could be under this sheet?  Is it an elephant? A stack of money? A flower arrangement?
Palletised. Needs the head whipping off as I strongly suspect it has bent valves. Might be time to replace it with a C16XE head with bigger valves?
Also saw this: the Biggest Engine Crane Ever. It's taller than me!
__________________ Cavalier: Going strong, 158'900 miles and 169ftlbs. Corsa: Never get any daylight to work on it! |
05-05-2008, 13:48
#53 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Nice work lining up an engine already mate....
05-05-2008, 14:36
#54 | | MIGWeb User
Join Date: Oct 2003 Location: glasgow/oban Drives: like its a hire car
| Re: Project Deathtrap: Jack's 1.2 Corsa unless you want more than 150bhp, Id say which head you use is largely irelevant.
__________________ Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!" |
05-05-2008, 16:23
#55 | | MIGClub Member
Originally Posted by alistairolsen unless you want more than 150bhp, Id say which head you use is largely irelevant. | Fair comment.
I'll see what turns up. If I find one for much cheapness, might be worth just lobbing it on. If I can't find one, I'll repair this one.
Anyone got any immobiliser gen? I forgot to grab the key and the thingy around the barrel for this ECU. If I get the key, can I use any sensor ringy thing?
Or can I get this ECU chipped, or use a C16XE one? |
05-05-2008, 16:26
#56 | | Regional Co-ordinator
Join Date: Sep 2005 Location: Midlothian, Scotland Drives: Saab 9000 2.3T
Originally Posted by alistairolsen Nothing is ever "enough" for long   | Correct.
Jack, what you need is the "how to build a sports car on a budget" book.
Then, down to your local metal suppliers and trawl ebay for a damaged CBR1000. Add in a year or so and........
__________________ MIG Performance Saabs |
05-05-2008, 16:28
#57 | | MIGWeb User
Then, down to your local metal suppliers and trawl ebay for a damaged CBR1000. Add in a year or so and........ | http://www.vauxhall-sport-forum.com/...ect-t5848.html
Jack, go and get them, asap, as far as I am aware you cannot get round them! |
05-05-2008, 16:35
#58 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa ****. |
05-05-2008, 16:37
#59 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Its all matches up
Transponder in key / ECU & pickup barrel for around the Ignition
Save yourself allot of hassle & get it if you can !!
Ortherwise its a case of finding another ECU / Transponder key chip & ignition barrel sensor thingy that matches !
BRING ON THE TRUMPETS ! |
05-05-2008, 16:39
#60 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa What does the immobiliser actually immobilise? The power to the fuel pump relay? If so that's not a problem... |
05-05-2008, 16:46
#61 | | Regional Co-ordinator
Originally Posted by Jack What does the immobiliser actually immobilise? The power to the fuel pump relay? If so that's not a problem... | When the immobiliser went on my corsa, we just ran a live to the fuel pump. It went after that  |
05-05-2008, 16:57
#62 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Seriously? That's all it does? I want going to replace all the wiring to the fuel pump anyway and have a kill switch somewhere.  |
05-05-2008, 17:27
#63 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: White 1.6 16v Nova
| Re: Project Deathtrap: Jack's 1.2 Corsa ECU lamp will be permanently on without the immobiliser disabled.
And yeah the pickup barrel is coded too, it matches the key and ecu. |
05-05-2008, 17:41
#64 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Right. So, basically, what I need to do is:
- Put the fuel pump on it's own circuit. Easy enough, was going to do that anyway.
- Put a switch in the EML wire so I don't have it on all the time.
- Put the diagnostics wire on a switched ground so when I need to check the codes I can just flick the EML on and then flash the codes. |
05-05-2008, 17:46
#65 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Im not sure if it only immobilises the fuel pump, as i have wired the system into mine and can turn it on and off manually.
When i turn the immob on and turn the key the engine just turns over and over, with just a pump immobilised youd expect the engine to run for a few seconds until the rail pressure was too little to supply enough fuel. |
05-05-2008, 17:57
#66 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Nah, not at all. The rail would be pressurised for those few turns of the engine. You probably wouldn't even get it trying to start, tbh. |
05-05-2008, 18:09
#67 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa When i start the engine with just the clifford immobiliser immobilising the fuel pump the engine starts and runs for 2/3secs, and then dies  |
05-05-2008, 18:10
#68 | | Administrator
Join Date: Feb 2002 Location: Fareham, Hants. Drives: 1.3L GTE 16V SXi Est
| Re: Project Deathtrap: Jack's 1.2 Corsa No Jack. The ECU immobiliser is built in and stops it from doing anything. I think the above is about a 3rd party one. When, on the legendary No-Spec (TM) I changed the fuel filter at Combe (long story) I unplugged the fuel pump and started it. It not only ran for 2-3 seconds, but also started and re-started many times, and then still coughed and spluttered after that. The immobiliser won't let it start at all.
Anyway, cool project. I often have dirty thoughts of a Corsa of some description with a slutty lack of interior and a 20XEV engine. No-Spec was quick, a Corsa has got to be fuuun. Son of No-Spec? |
05-05-2008, 18:13
#69 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Exactly my point/\
Id put money on the immobiliser built into the ecu being wired into something else too, maybe the ign live to the dispak as it totally disables the engine, it doesn't even fire.
Whereas my clifford, just cutting power to the pump, the engine runs for a few seconds then dies down |
05-05-2008, 18:14
#70 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Fanny.  |
05-05-2008, 18:17
#71 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: Project Deathtrap: Jack's 1.2 Corsa as said try and get it if posible but if not it is posible to use a c16xe ecu, you will need ecu, loom, lambda, afm tho so could be costly. if the immobilser doesnt switch off on an x16 engine it will run for a few seconds then cut out.
__________________ MIG Performance Vauxhalls WELSH Member |
05-05-2008, 18:18
#72 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa If the immobiliser doesn't switch off, the engine doesn't run, at all.
It doesn't even fire |
05-05-2008, 18:26
#73 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa my old one definatly started then cut out when i used a spare key with no chip, make sence what everyone is saying tho that there would be more than one circuit protected if it matched with ecu |
05-05-2008, 18:29
#74 | | Administrator
| Re: Project Deathtrap: Jack's 1.2 Corsa Yeah there's more than one type; one which doesn't let the engine fire, and one which lets it start, but then cuts out, mostly V6s I think. |
05-05-2008, 18:45
#75 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Poo face. Looks like I'll be on the lookout for a key/sensor ring/ECU.  |
Members: 42,547
Threads: 308,200
Top Poster: LEE69 (42,904) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
