27-10-2008, 21:26
#476 | | MIGClub Member
Join Date: Feb 2005 Location: Forres, Nr Inverness Drives: Cheap sheds
| Re: Project Deathtrap: Jack's 1.2 Corsa  @ the plug leads.
I'd just look at as a learning curve tbh. Half of the point of having a project car, i'd love to have a project like that. |
27-10-2008, 22:56
#477 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by SteveM That daewoo thing is a pretty sweet find! | Might be useful to someone.  Looked like a standard VX gearbox with a different arm.
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
27-10-2008, 22:58
#478 | | MIGClub Member
Exactly man, I never claimed to be an expert, I just like doing this sort of stuff.  |
28-10-2008, 09:56
#479 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Jack, the Mantzel boxes suffer the same throttle cable angle & I had leaks on my inlet.
Best bet is get the engine running & then spray brake or carb cleaner about the inlet tract, listen for the change in engine note & that will pin point the leak. Mine actually made a squealing/sucking sound where it leaked under the inlet box.
Keep at it.
28-10-2008, 11:27
#480 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Access to the alternator is fantastic with the powerbox off so I'll get a bracket on there and get that sorted then stick it all back together.
I've got a horrible feeling I've got the brake servo valve the wrong way round.  |
28-10-2008, 11:35
#481 | | MIGWeb User
Join Date: Jun 2006 Location: Suffolk/Staffs Drives: 78 Kadett C
| Re: Project Deathtrap: Jack's 1.2 Corsa damn, that throttle cable position looks a bit naff  . You could make a bracket for the throttle cable and looks like there are 2 convenient mounting holes under the tb pulley mech thing
brake servo valve being opposite way round would give exactly the symptoms youre having, coming to think of it !! swap it and see
__________________ Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me! |
30-10-2008, 13:44
#482 | | Regional Co-ordinator
Originally Posted by Jack
I've got a horrible feeling I've got the brake servo valve the wrong way round.  | Undo the pipe at the inlet box end, you should be able to suck air from the servo, but not blow into the servo. Anything else is wrong or 1-way valve has failed.  |
22-11-2008, 15:04
#483 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa |
22-11-2008, 15:12
#484 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa  FIT !! and the chest aint looking too shabby  that waffle sandwich looks wrong  |
22-11-2008, 15:20
#485 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa  In retrospect, probably not the best idea to show my bits to the world!
Make one and tell me it's wrong. Tell me, when you've got sweet sweet waffle goodness and melty kit-kat in your mouth that it's wrong.  |
22-11-2008, 15:26
#486 | | Regional Co-ordinator
Join Date: Sep 2005 Location: Midlothian, Scotland Drives: Saab 9000 2.3T
Originally Posted by Jack  In retrospect, probably not the best idea to show my bits to the world!
Make one and tell me it's wrong. Tell me, when you've got sweet sweet waffle goodness and melty kit-kat in your mouth that it's wrong.  | But they aren't even potato waffles.....
Well if they are then they are pitiful excuses for waffles.
__________________ MIG Performance Saabs |
22-11-2008, 15:38
#487 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Potato waffles? You're a mad man.  |
22-11-2008, 15:53
#488 | | Regional Co-ordinator
Originally Posted by Jack Potato waffles? You're a mad man.  | You clearly don't know what you're missing
Waffling aside (see what I did there? No? I'll get my coat) the little beezer's getting there  |
22-11-2008, 15:59
#489 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Potato waffles are for sausages and beans breakfast!
Aye, it's pretty slow though. As soon as I've sorted this poxy air leak then the engine is finished. Then it's onto the suspension, brakes and moving the battery. Then it's finishing touches! I don't think I can afford to put it on the road much before the summer. At the moment I'm paying rent on two houses and running the Cavalier.  |
22-11-2008, 16:04
#490 | | Regional Co-ordinator
Originally Posted by Jack Potato waffles are for sausages and beans breakfast!
Aye, it's pretty slow though. As soon as I've sorted this poxy air leak then the engine is finished. Then it's onto the suspension, brakes and moving the battery. Then it's finishing touches! I don't think I can afford to put it on the road much before the summer. At the moment I'm paying rent on two houses and running the Cavalier.  | At least you can sit in it and go brrrrrrrrrrrrrrrrrrrrrrrbwapbwap-brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrbwapbwap-brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr-rrrr-rrrrr  |
22-11-2008, 16:25
#491 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
| Re: Project Deathtrap: Jack's 1.2 Corsa Waffle and kit kat? Thats actually made me feel sicker than i already did.  |
22-11-2008, 16:27
#492 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Christ, something wrong with you guys.
Oooh, my extended wiring meant no ECU light too!  |
22-11-2008, 17:08
#493 | | MIGWeb User
Originally Posted by Lugy At least you can sit in it and go brrrrrrrrrrrrrrrrrrrrrrrbwapbwap-brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrbwapbwap-brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr-rrrr-rrrrr  | hahahaa!! It's much much cheaper  |
21-12-2008, 17:40
#494 | | MIGClub Member
Getting fed up of doing this now.  Had the manifold off again and had a play with it. Put it all back together and still air leak.  Had it all off again and tested it against a stanley knife blade, it's as bent as a £9 note!
Fed up to the back teeth of this ****ing manifold. Serves me right for buying a cheap nasty one.  I've emailed the seller and asked him if he'll consider sending me a proper one or refunding me. I paid more for this manifold than I did for the car and so far all it was good for was the random hoses and pipes that came with it.
In the mean time I've put a bid on a proper one on ebay!  This engine is going to run properly, dammit!  |
21-12-2008, 17:43
#495 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| Re: Project Deathtrap: Jack's 1.2 Corsa why not get it skimmed? or even ask Lee303 if he can do it for ya. |
21-12-2008, 17:50
#496 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa I don't think it's thick enough to skim. It's only about 3mm thick, and you'd need to take more off to get it flat. I had the same problem with the TB flange; the whole thing has been made far too thin and it's all distorted as he's welded it together.
The TB flange was replaced with a 10mm thick piece, but I'm sick of this manifold, it's a piece of ****. It'll end up more patches than cloth and I just want something that bolts on and works with no leaks!  |
21-12-2008, 20:33
#497 | | MIGClub Member
Originally Posted by Jack | Can't really see in this photo, but I tested the contact area using patented Contour and Undulation Navigation Technology (C.U.N.T), which involved greasing up the lower half of the manifold and seeing how much grease ended up on the **** top half when I pressed the two together.
The fit is truly wank, and I can't wait to get a proper one on there.
Enthusiasm is way up now! Can't wait to get it running nicely with no air leaks and get the Spax kit and the 256mm brakes on!  |
21-12-2008, 20:41
#498 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Shame about the inlet. Ive had no probs at all with my copy box.
Bolted the f**ker right on, and aint touched it since(a year ago)  |
21-12-2008, 21:00
#499 | | MIGWeb User
Join Date: Aug 2006 Location: huntingdon Drives: 11secNova+GTR+CDTI
Originally Posted by Jack Contour and Undulation Navigation Technology (C.U.N.T), |    |
22-12-2008, 15:43
#500 | | Administrator
Join Date: Jun 2006 Location: Caerphilly S.Wales Drives: Cavalier 1.8
| Re: Project Deathtrap: Jack's 1.2 Corsa Get a tractor spec one on there.............. |
Members: 43,214
Threads: 310,613
Top Poster: LEE69 (43,150) | | Welcome to our newest member, chrismessenger | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
