01-05-2008, 17:06
#26 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Why not fit a 2lt ecotec?
You can pick them up for funk all...
__________________ Quote: |
01-05-2008, 17:07
#27 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Because I would have the same problem. Mounts, gearbox, shafts...etc, it all adds up.
__________________ Cavalier: Going strong, 158'900 miles and 169ftlbs. Corsa: Never get any daylight to work on it! |
01-05-2008, 17:08
#28 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa K funk it then. Fit a 1.6 8v on carbs... |
01-05-2008, 17:09
#29 | | Regional Co-ordinator
Join Date: Sep 2005 Location: Midlothian, Scotland Drives: Saab 9000 2.3T
| Re: Project Deathtrap: Jack's 1.2 Corsa DERV powered track car FTW!
__________________ MIG Performance Saabs |
01-05-2008, 20:50
#30 | | MIGClub Member
Join Date: Feb 2005 Location: Forres, Nr Inverness Drives: Cheap sheds
| Re: Project Deathtrap: Jack's 1.2 Corsa Should be a cool wee project.
Kinda makes me wish I kept that £10 Pea green POS and do the same thing  .
EDIT- Wonder if you remember this...... Quote:
Originally Posted by Jack Could this be the beginning of No Spec 2?
Strip it, put some decent springs on it and whack an Ecotec 2.0l in it and you're away.  | Dooo It!
01-05-2008, 21:12
#31 | | MIGClub Member
Join Date: Apr 2006 Location: Telford Drives: Astra Mk3/Mk4 SRi1.8
| Re: Project Deathtrap: Jack's 1.2 Corsa awesome Jack, just awesome
does the SPI of doom not tickle your fancy?
__________________ 1.8 Mk4 Astra SRi 1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns |
02-05-2008, 08:14
#32 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa As much as I love the ****ty SPI engine, I need 16v power. |
02-05-2008, 08:47
#33 | | Regional Co-ordinator
Join Date: Sep 2001 Location: Somerset Drives: '88 Astra GTE 16v
| Re: Project Deathtrap: Jack's 1.2 Corsa 1.6 16v is the way to go! Good to see you joining the ranks of track slags Jack. |
02-05-2008, 10:50
#34 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by Jack Because I would have the same problem. Mounts, gearbox, shafts...etc, it all adds up. |
Put it in on smallblock F15 box.
02-05-2008, 10:55
#35 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa You can do that? I thought that smallblocks and bigblocks... everything was incompatible.  |
02-05-2008, 11:02
#36 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa No, the issue is to find a small block flywheel & clutch that will bolt to the 2.0 crank's bolt pattern. Do that & you can retain the smallblck box & shafts aswell as leave the gear linkage untouched etc. Its only 1 engine mount to change aswell then.
Maybe not so sensible on an XE but the ecotec seems a tad less torquey, so will be fine. |
02-05-2008, 11:08
#37 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Wow, that's cool.
I think I'm really going to need advice and stuff like this throughout the build. I'm alright doing stuff, but I need gen like this.  |
02-05-2008, 11:48
#38 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Hurry up & drop the 1.2 off at the metal merchants, clean the bay, get it ready for some power!
I'd be keeping an eye on the bay for decent fr shocks & springs. Maybe a cheap XEV too to start a mini resto on.. belts, gaskets, tensioners etc. |
02-05-2008, 11:56
#39 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa 2.0 ecotec gets my vote
Easy conversion, cheap as chips to buy stuff - Just make sure and do the sensors before fitting it !!
Dont bother with the 1.4 16v - If anything go with the (Early i think) 1.6 16v engines
BRING ON THE TRUMPETS ! |
02-05-2008, 13:03
#40 | | MIGClub Member
Join Date: Dec 2005 Location: **** off. Drives: Recovery truck!
| Re: Project Deathtrap: Jack's 1.2 Corsa Hey, don't be chucking the old engine away me old fruitbat, I'll have that off you! |
02-05-2008, 13:45
#41 | | Regional Co-ordinator
Originally Posted by Rubix_Cube
Dont bother with the 1.4 16v - If anything go with the (Early i think) 1.6 16v engines  |
C16XE... not X16XE  |
02-05-2008, 14:38
#42 | | MIGClub Member
Originally Posted by Allvaux Hey, don't be chucking the old engine away me old fruitbat, I'll have that off you! | Really?
It's probably not even worth the fuel to come down here and grab it!  |
02-05-2008, 14:48
#43 | | MIGWeb User
Join Date: Oct 2003 Location: glasgow/oban Drives: like its a hire car
| Re: Project Deathtrap: Jack's 1.2 Corsa dont dick about, 1.6 16v corsas are slow, and you wont spend the money on tuning it properly.
Find a calibra/cav, break it to recover your funds and fit an xe.
Youll need hubs, bearings, mounts and an ecotec plate and not a lot else. donor car will give you box, shafts, brakes..............
I did mine for 700 quid including buying the corsa! (and it got new everything)
__________________ Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!" |
02-05-2008, 14:59
#44 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa The 1.6 engines are really restricted by the poxy inlet manifold. Getting one made up isn't an issue, and should be fast enough to keep me quiet.
I may have just sourced an engine, box, loom, ECU and shafts for £150, so watch this space.  |
02-05-2008, 15:08
#45 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Im well aware of the 1.6 engine and its tuning options, sadly with a box plenum and no remap/cams you wont see more than 130bhp ish, you simply cannot beat the xe for cheap thrills IMO |
02-05-2008, 15:09
#46 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa I'm sure a 130bhp 1.6 in a stripped out Corsa will be plenty fast enough for me when you bear in mind that my previous three cars have been a N/A diesel land rover, a 1.4 astra and a TD cavalier.  |
02-05-2008, 15:11
#47 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa  , possibly!
Nothing is ever "enough" for long   |
02-05-2008, 15:25
#48 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa |
02-05-2008, 17:31
#49 | | Regional Co-ordinator
Join Date: Dec 2006 Location: KEITH (N.E. SCOTLAND Drives: mk3 astra sport 1.8
02-05-2008, 17:57
#50 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: White 1.6 16v Nova
| Re: Project Deathtrap: Jack's 1.2 Corsa Cool project.
Dont got for a 1400, just as much work as a 1600, and the 1600 has more power/torque.
Id give an ancient 2L 8v a miss too.
20xe is best option for cheapness vs power, but your going need decent suspension etc for it.
A 1600 16v with an inlet box on is cool, but for a track car, more power/bigger engine is needed IMO And to get over the 125/130hp mark on the 1600 16v is when prices start to rise. |
Members: 42,547
Threads: 308,185
Top Poster: LEE69 (42,904) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
