Old 19-10-2008, 17:47   #451
Drives: Corsa 1.4 Corsa 2.0T
Re: Project Deathtrap: Jack's 1.2 Corsa
chavs motor??
Gaz86 is offline   Reply With Quote
Old 19-10-2008, 18:52   #452
Jack's Avatar
Drives: Cavalier 1.7 TD
Been to Looooooooooms!
Jack is online now   Reply With Quote
Old 20-10-2008, 12:34   #453
Drives: V8 Senator
coming along nicely there!
Agent Kellerman is offline   Reply With Quote
Old 22-10-2008, 17:02   #454
Jack's Avatar
Originally Posted by Steve! View Post
low on fuel?
Put a splash of fuel in it and still nothing.
I don't even know where to start looking to solve this. The motivation boost I got when it started up has well and truly run out.
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Old 22-10-2008, 17:33   #455
Fow16v's Avatar
Drives: Astra Coupe Turbo
does it just refuse point blank to start or is it trying? first thing id be looking for is fuel and spark, the only thing you have changed is the exhaust yea? is it blocked? did you do anywelding to the exhaust with the battery connected?
WELSH Member
Fow16v is offline   Reply With Quote
Old 22-10-2008, 17:37   #456
Drives: Cav 3 1600
Don't give up yet jack, you've done an awesome job so far, the best is yet to come when you get to drive it.
Good luck!
Man who walk through airport turnstile sideways going to Bangkok
l337 calibra is offline   Reply With Quote
Old 22-10-2008, 17:49   #457
Jack's Avatar
OK, here's the full story:
- I ran few new earths last weekend and it started and ran.
- It ran with the exhaust on.
- It ran with the exhaust off.
- The exhaust needed lengthening so that it would join together properly.
- Dad took it to work and lengthened it using an offcut from the 1.2 exhaust.
- Exhaust on.
- Same starting problem as the weekend before.
It turns over, it coughs a bit, sometimes almost goes... but nothing. Not a sausage.
I need a proper screw-in compression tester I think. I've only got a poxy rubber-ended one at the moment. I also needs some new leads as these ones are covered in oil from when the rocker cover was leaky before.
I just can't believe that it ran last weekend absolutely fine and now is back to square one.
I need to have a serious look at it this weekend. I'm sure it's something fundamental and will be obvious after I've found it, but at the moment I'm just not feeling it at all.
Old 22-10-2008, 17:49   #458
Jack's Avatar
Good luck!
Cheers for all your comments though guys, at least you haven't given up on it!
Old 22-10-2008, 21:29   #459
Administrator
Astra Dan's Avatar
Drives: 1.3L GTE 16V SXi Est
Check for fuel. Take the fuel inlet pipe off and see if a big squirt of fuel comes out on cranking. Or, lift the back seat and listen for the pump whilst cranking. Fuel pump fuse OK?
Check for all 4 sparks.
Put the kettle on.
Click for info: GTE16V Mk2 SXi Estate
Astra Dan is offline   Reply With Quote
Old 22-10-2008, 23:26   #460
Drives: V8 Senator
FYI a screw in comp tester is about 15 quid at Halfords
As Dan says check for fuel (although pump whirring or rail pressurised does not necessarily mean injectors are pulsing)
Old 23-10-2008, 21:16   #461
tommychimp's Avatar
Drives: Astra Mk3/Mk4 Cabrio
Have you blanked off every hole, it sounded like it was drawing a lot of air last time it running
1.8 Mk4 Astra Cabrio rolling on 18s
1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns
tommychimp is offline   Reply With Quote
Old 24-10-2008, 08:49   #462
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Jack mine did this, turned out a host of fuses had blown.
Are you able to flash up any fault codes?
V8 blender FTW
Old 24-10-2008, 09:16   #463
Jack's Avatar
Yes, that's why I was mouthing at you to squeeze that hose around that bolt you were holding!
I might check the fuses, seems an obvious thing to do!
I went through the wiring diagram last night and traced a load of wires so I've got a fairly comprehensive list of things to check with my multi-meter over the weekend. I'm 95% sure it's an electrical problem as it started up and ran not two weeks ago.
My one other thought it that maybe the fuel pump isn't 100%, so I'll have the hoses off over the weekend and see if I can pump some fuel into a 2 litre bottle. Aside from that I really am stumped, and I don't have the space to do any serious stripping down.
Old 25-10-2008, 12:35   #464
Jack's Avatar
Took this photo a few days ago and have to put it up here. Someone's stolen both of my cars!
Did some messing around today. Gave the Cavalier a quick once over and finally got round to test-fitting the centre caps that have lived in the car since Billing. They fit really well, better than the current caps actually.
Looks alright, and a lot tidier than having some random caps missing. I'm almost tempted to have the wheels off and give them a quick going over with some silver, they are starting to look a bit scruffy.
Right, onto the Corsa! I decided to go back to basics this morning. Forget about wiring diagrams, wire colours and sensors and just do some basic checks. First thing was to check for fuel. I took both hoses off the rail and stuck them both into bottles. Gave it a quick crank and then checked.
Right, so at least the pump is playing ball.
Took the plugs out... and this is where things get interesting.
Number one was as black as your hat.
But number two looked fine.
Number three was black too. What the deuce?
Number four was fine.
I cleaned them all up with a bit of emery tape and then had a closer look at the leads. I followed them all the way along to the dispack where I noticed something very strange. Number 1 is at the top, but they are not numbered sequentially! Could it be that I've had the leads on wrong the entire time?
I put it all back together and it fired up first time. It revved right up so I knocked it off. I found another MAP sensor and plugged a hose straight from the manifold to the sensor. When I started it up after that it did that stupid revving up and down thing. Didn't stop me going for a drive in it though!
Old 25-10-2008, 12:38   #465
Jack's Avatar
I got my trusty lighter and screwdriver out and bent the corner of the throttle cable thingy over as well, I don't fancy chafing through the throttle cable. This stupid manifold has a really lame angle that the TB sits on and it screws the cable over.
Put the bonnet back on as well. Starting to look a bit more like a car again!
Old 25-10-2008, 15:21   #466
Drives: 78 Kadett C
omg, i was about to suggest plugs on the wrong way - very easily done, took me hours to spot
Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me!
djivesp is online now   Reply With Quote
Old 25-10-2008, 15:31   #467
Jack's Avatar
I'm such an idiot.
Managed to get it to idle, but it's idling high and there's a massive air leak on it somewhere. Can hear air being drawn in somewhere. Whipped the powerbox off and to my surprise was sealed all the way round. Looked fine, actually! Might have the bottom half of the manifold off. There's definitely a massive air leak somewhere.
Sounds alright though, I'm pleased it sounds as well as it does.
Old 25-10-2008, 16:02   #468
Drives: 16v Nova, Astra TD
Aye, the dispak is numbered for the leads
Check the brake servo pipe, and all the vacuum hoses for air leaks.
Also, the tb to inlet join
LongLiveTheNova is offline   Reply With Quote
Old 25-10-2008, 16:15   #469
Jack's Avatar
What are the brakes on these like without servos? I've driven a few cars without them and not noticed much difference.
Old 25-10-2008, 16:31   #470
No idea, but i drove my nova without the servo piped up and nearly didn't stop for the first corner i met
Old 27-10-2008, 18:13   #471
Jack's Avatar
Did some messing around on sunday. Went to the scrapyard to hunt for random alternator brackets. Didn't find much, but did see this rather interesting hydraulic setup on a Daewoo. Looks like the standard VX cable system with a different arm and a funky slave cylinder. Could be an easy way to convert cable boxes to hydraulic?
Also messed around extending the wires to my EGR valve. Hopefully this should knock the ECU light off!
Old 27-10-2008, 18:15   #472
Jack's Avatar
Today's purchases from Megaspares!
Winner, might as well double up to make absolutely sure that it's sealed!
Old 27-10-2008, 18:37   #473
Drives: around looking Cool!
at that sticker
Old 27-10-2008, 18:45   #474
Drives: Cavalier SRi
That daewoo thing is a pretty sweet find!
The cake is a lie :(
SteveM is offline   Reply With Quote
Old 27-10-2008, 18:50   #475
Benn's Avatar
Drives: A shineeeey Nova
Love the sticker dude!
Tags
corsa, rusty, sexy
Members: 43,216
Threads: 310,618
Top Poster: LEE69 (43,150)
Welcome to our newest member, kaytee_lou
