07-09-2008, 16:25
#401 | | MIGClub Member
Join Date: Apr 2006 Location: Telford Drives: Astra Mk3/Mk4 SRi1.8
| Re: Project Deathtrap: Jack's 1.2 Corsa come on....
you don't need an exhaust!
__________________ 1.8 Mk4 Astra SRi 1.4 Mk3 Astra Rattletrap! Soon to be XE Rattletrap!
Too close for missiles; switching to guns |
08-09-2008, 12:34
#402 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Good progress Jack. Corsa's sure do rot like Novas though.
12-10-2008, 15:00
#403 | | MIGClub Member
Found a stray wire in the loom that had been chopped and replaced with a different colour, a quick look through the book found that it was the earth for the fuel pump relay!
Earthed it to the bulkhead which helped a bit! Then ran a new earth straight from the battery to the bulkhead and a new one straight from the battery, along the scuttle and straight to where the brown and black one is earthed. Hey presto.
__________________ Cavalier: Going strong, 158'900 miles and 169ftlbs. Corsa: Never get any daylight to work on it! |
12-10-2008, 15:08
#404 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Grounds are a must... Glad it running, ready for combe in the newyear then.. Good work.
__________________ Quote: |
12-10-2008, 15:10
#405 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Needs the exhaust sorting out (it falls off in the video!), suspension and brakes doing and a lot of random bits tidying up and then it's ready for an MOT.  |
12-10-2008, 16:26
#406 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa It was satisfying to hear the corsa running at long last  |
12-10-2008, 16:34
#407 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: White 1.6 16v Nova
| Re: Project Deathtrap: Jack's 1.2 Corsa Good to hear it running mate. |
12-10-2008, 18:37
#408 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Cheers guys, I'd be stuck without you!  |
12-10-2008, 19:15
#409 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by leigh 2.0 16v go for a c20xe you wont regret it not too much work either |
We've just got the bloody 1.6 running! cheeky git   |
12-10-2008, 19:22
#410 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa |
12-10-2008, 21:45
#411 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
Originally Posted by Jack | whoah cowboy, some huge steps your taking there  |
12-10-2008, 21:48
#412 | | MIGClub Member
I just hope I can move my hands and feet fast enough to keep up with it! |
12-10-2008, 22:01
#413 | | Regional Co-ordinator
Join Date: Dec 2006 Location: KEITH (N.E. SCOTLAND Drives: mk3 astra sport 1.8
| Re: Project Deathtrap: Jack's 1.2 Corsa I'm sure you wil be fine Jack. If you can handle the Cav on boost you can handle anything
What do you reckon the corsa has cost you so far? If you dont mind me asking that is. I fancy a corsa project next but have a few things to consider. |
12-10-2008, 22:08
#414 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Let's do some sums!
Corsa 1.2
£125
Engine, box, shafts...etc
£150
Inlet manifold
£125
Tyres
£175
Valves and head-gasket
£75
-60mm Spax kit
£100
Spent a lot on odds and sods, but it's not cost me an awful lot so far. In hindsight I should have bought a running 1.6 Corsa and stripped it out, but this has been much more fun!
In total I'd guess somewhere around the £700 mark, but some of it was un-necessary (inlet manifold, 8v flywheel...etc).  All I really need to buy now is some discs and pads for the front and I've got everything I need to finish it. |
12-10-2008, 23:02
#415 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa cheers. Fun budget car. I like!
WHat brakes are you coing for? Astra GSi / XE Cav ones? |
12-10-2008, 23:09
#416 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Off topic - if you go on google earth you can see the car this engine was ripped out of still parked on the driveway  |
13-10-2008, 07:28
#417 | | MIGClub Member
Originally Posted by Melv WHat brakes are you coing for? Astra GSi / XE Cav ones? |
256mm x 24mm. Calipers are from a 2.0 Calibra I think, just need some new discs and pads.  |
13-10-2008, 10:50
#418 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa Good stuff. They wont be that expensive on TC |
13-10-2008, 11:07
#419 | | MIGClub Member
Join Date: Dec 2005 Location: **** off. Drives: Recovery truck!
Originally Posted by Jack Let's do some sums!
Corsa 1.2
£125
£150
Inlet manifold
£125
Tyres
£175
£75
-60mm Spax kit
£100
Plus you've had the added bonus of being able to say you mostly did it yourself. Far more kudos in that than just buying one already built. |
13-10-2008, 12:05
#420 | | Regional Co-ordinator
Originally Posted by Melv Good stuff. They wont be that expensive on TC | Valver brakes arent that cheap from Vauxhall. Its the Vectra 288 stuff thats a bargain.
Motor factors discs & some Mintex pads or similar FTW. |
13-10-2008, 12:23
#421 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: Project Deathtrap: Jack's 1.2 Corsa good to see you got it going.
__________________ MIG Performance Vauxhalls WELSH Member |
13-10-2008, 13:50
#422 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Just ordered some Mintex discs and pads.
Unsure of whether to use the Mintex on the Cavalier and put the Cav's old stuff on the Corsa or put the Mintex on the Corsa.
Hmmmmm! I use the Cavalier every day, seems a shame to waste a set of good stuff on a shonky Corsa.  |
13-10-2008, 13:53
#423 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa £8 for a pair of new front hoses too, so I've had some.  |
13-10-2008, 13:56
#424 | | MIGWeb User
Join Date: Jun 2006 Location: Suffolk/Staffs Drives: 78 Kadett C
| Re: Project Deathtrap: Jack's 1.2 Corsa sounds awesome
it'll feel wicked  it's a nice change - chucking a little car about, after driving bigger boatyer cars, especially with the extra poke  every time i need to use my dads passat to get bits for my car, i cant wait to get back in mine again!.. Then sit there and think to my self "i've broken it again. but i LOVE it"
__________________ Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me! |
13-10-2008, 14:33
#425 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Just getting a few quotes for insurance.  Greenlight won't touch me as I have no no claims.  |
Members: 42,547
Threads: 308,182
Top Poster: LEE69 (42,903) | | Welcome to our newest member, angelillo | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
