Old 28-07-2008, 22:39   #326
Drives: Corsa 1.4 Corsa 2.0T
Re: Project Deathtrap: Jack's 1.2 Corsa
certainly got that the wrong way round
Gaz86 is offline   Reply With Quote
Old 29-07-2008, 07:10   #327
Jack's Avatar
Drives: Cavalier 1.7 TD
Dickhead I are. Didn't realise until I looked at that photo!
Cavalier TD: Going strong, 160'000 miles and 169ftlbs.
Corsa 1.6 16v: New inlet manifold!
Jack is offline   Reply With Quote
Old 29-07-2008, 08:51   #328
Fow16v's Avatar
Drives: Astra Coupe Turbo
good progress with this jack, the wiring becomes alot more obvious when its in the bay lol. you planning on have it runnning ready for combe?
WELSH Member
Fow16v is offline   Reply With Quote
Old 29-07-2008, 09:35   #329
Jack's Avatar
When's Combe?
Old 29-07-2008, 09:39   #330
ANDYRACER's Avatar
Drives: Jap Crap wit Booost!
Suspension on yet mofo?
ANDYRACER is offline   Reply With Quote
Old 29-07-2008, 09:43   #331
Jack's Avatar
Not yet matey. I want to get the engine running before any other bits go on.
Old 29-07-2008, 10:09   #332
Fow16v's Avatar
Originally Posted by Jack View Post
When's Combe?
6th of sept @ combe for eurofest and then 7th @ silverstone for trax
Old 29-07-2008, 10:18   #333
Jack's Avatar
Hmmmmm, not sure, but we'll see!
Old 29-07-2008, 15:14   #334
Drives: 16v Nova, Astra TD
Yes thats the black plug that you use to join it to the car loom
LongLiveTheNova is offline   Reply With Quote
Old 29-07-2008, 15:24   #335
Jack's Avatar
Awesome, let the wire-hackage commence!
Old 02-08-2008, 15:34   #336
Jack's Avatar
Had a few little presents in the post.
A snake!
My Spax kit from Andy.
Spent ages slipping my loom into the tubing. Took ****ing ages, but I've got it down to an art now. Plugged in all the obvious bits (big blue plug and crank sensor ) and now I'm a bit stuck. Not an awful lot else is leaping out at me.
On top of all that, one of my new tyres was ****ing flat when I got there this morning and I've broken my ****ing garage door!
Old 02-08-2008, 16:40   #337
Jack's Avatar
Jobs to do:
- Charging circuit tubed up and installed
- Battery in (just temporarily to test, eventually will be slid in the boot)
- Charging circuit connected to main loom
- Engine loom mated to main loom
- Engine loom attached to the engine
- Sort out all vacuum hoses (I've got two barbs on the TB that I've got no idea what they're for, and I don't know where the servo feed goes either )
- Fit coolant hoses. Double check cooling system and tentatively fill with coolant.
- Fit exhaust manifold and cat. Join to the rest of the system.
- Fill with oil.
- Check clutch.
- Sort out gear linkage.
At some point it needs starting up just to make sure it runs. I think that will be a real motivation booster. At the moment I'm pissed off that my loom wasn't a bit more straightforward and that I haven't really made any progress today. That flat tyre was a real let down as well. ****ing gutted.
Old 02-08-2008, 17:16   #338
Nice neat job on the loom.
I can name where every plug goes from that pic
On the tb, the two 8mm brass barbs are for the coolant connection,its not needed if you have a box inlet fitted as the pipes no longer reach. Just leave the barbs open and put a bolt in the end of the coolant pipe that used to go to them.
Inlet box should have a threaded union on it for the brake servo, and a barb to go to the map sensor.
Old 02-08-2008, 17:29   #339
Jack's Avatar
Any chance you could knock some quick labels up in paint or something? I'm sure it would be helpful to everyone, not just me.
Ah, legend. Thanks muchly.
The tubing is a bastard to start with, but there's a real knack to it.
Old 02-08-2008, 18:07   #340
Its tricky put labels on that pic, but it should go a bit like this(Starting at the ecu end going towards the end of the loom(gearbox end))
This may help
Black fuse holder-Thick wires-For SAI system, not needed, just tie out the way- 1
Blue multiplug-2
Small grey plug-Intake air temp sensor(onto a sensor in the air pipe that you will have make yourself as you no longer have the std inlet)-3
Two 8mm rings-Earths, onto a stud by the alternator-4
Two pin plug, and a small spade plug, on a long bit of loom-Coolant sensor and dash temp sender- Thermostat housing-5
GREEN plug-Map sensor on firewall-map sensor also has a vacuum connection to the inlet-6
Small Ring-Earth-Bolts onto the side of the lower inlet.-7
1/2 Rings-Earths-Bolt to where the TB used to bolt, lower side of bottom inlet(will need a plate to blank off where the tb used to fit the inlet btw)-8 Theres two "8" on the pic
Black plug-Crank sensor plug, which joins the crank sensor wire near the fuel pressure regulator-9
Black plug-DISpak plug-10
Blue plug with red clip-Fuel tank vent valve-11
Thin black wire with single plug on-Lambda sensor-12
Big grey plug-SAI pump(not needed)-13
Smaller two pin plug-SAI changeover valve( should be near to the grey plug mentioned above), again, not needed.-14
Any probs, give me a pm/txt
Old 02-08-2008, 18:14   #341
Jack's Avatar
Thanks muchly!
Need to find my MAP sensor. I've got boxes and boxes of stuff I've removed and forgotten about.
Old 03-08-2008, 16:53   #342
Jack's Avatar
Found the MAP sensor still on the bulkhead. I didn't know the 1.2 had one.
Stuck my exhaust manifold on with a sexy new gasket. I'm missing a couple of studs and a whole crapload of nuts. I might have to start a shopping list.
Lou went for a walk to Morrisons to get me a sammich, so while she was gone I made up the fuel hoses. I went to the scrapyard and got these from an Ecotec Vectra. I've just sleeved them over the top of the existing hoses and jubilee clipped them up. Not sure which way round they go. I'll stick 12v to the fuel pump when I swap it to the MPI pump and see which hose the juice flings out of.
No cutting of the loomage required! Plugs straight in! I was shocked and amazed!
Rolled the corsa out of the garage and almost straight into the side of the cav! Forgot I'd snapped the handbrake cable. Yet another job to put on the list!
I've connected up the charging loom to the alternator, and the starter motor. Connected the three-pin job to the engine loom and the engine loom to the car loom. It's all plugging in sexily.
Look how dreamy I looked last night. Sexy face + Cavalier TD + Deathtrap Corsa = as sexy as Spanishfly?
Old 03-08-2008, 17:30   #343
Drives: 78 Kadett C
It's just they way you look touching that engine
Awesome progress dude wish i had your motivation
Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me!
djivesp is online now   Reply With Quote
Old 03-08-2008, 17:33   #344
Jack's Avatar
I don't have any. All of these little fiddly ****ty jobs are pissing me off, and I've got no idea which wires are which or which bits go where.
At the moment I'm trying to do all the obvious things and hopefully the small jobs will get a bit clearer then.
Old 03-08-2008, 17:41   #345
Jack's Avatar
Also started on my pikey camera mount using a spare head-rest.
Old 03-08-2008, 19:45   #346
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Better question is whos she? Why are there no more pics of her?
Old 03-08-2008, 19:56   #347
Benns saying what most are thinking
Old 03-08-2008, 20:04   #348
Jack's Avatar
She kept stealing my chips!
A quickie... I've found a small thingy connected to my old bit of inlet manifold. It looks like it takes a vacuum feed. It has two barbs on it, and I've found the bit of loom it connects to. What is it?
I think I need EPC or something. If it was a Land Rover I'd be fine!
Old 03-08-2008, 21:44   #349
you mean the fuel tank vent valve? got a red and blue pug going to it?
Old 03-08-2008, 21:46   #350
Jack's Avatar
Yarp, a little two-pin job.
What the crap does it do? Obviously one of the pipes goes to the inlet manifold.
It all seemed quite straight-forward when we were stripping the car down, but now it's time to put everything back I've suddenly got boxes of random hoses that must go somewhere.
Tags
corsa, rusty, sexy
Members: 43,214
Threads: 310,613
Top Poster: LEE69 (43,150)
Welcome to our newest member, chrismessenger
