06-07-2008, 20:36
#276 | | MIGWeb User
Join Date: Jun 2006 Location: Suffolk/Staffs Drives: 78 Kadett C
| Re: Project Deathtrap: Jack's 1.2 Corsa dude, just pile on some silicon gasket stuff, let it harden halfway then bolt it down, it will squish the excess out of the sides and the highest point should hold out a bit of vacuum
__________________ Stripped Kadett C + 2l 8v turbo + welded diff = 8-) .. Selling c20xe turbo engine, F20, exhaust, corsa/tigra PAS gear, pm me! |
06-07-2008, 20:55
#277 | | MIGWeb User
Join Date: Jul 2006 Location: north pole Drives: Corsa 1.4 Corsa 2.0T
| Re: Project Deathtrap: Jack's 1.2 Corsa truly shocking workmanship, your work however A+
how come you helicoiled the flange why not just tap it? would have been cheaper.
if you take the box to an engine builder they should be able to skim that flat for you for about £20 |
07-07-2008, 10:18
#278 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Quote:
Originally Posted by GBE86 how come you helicoiled the flange why not just tap it? would have been cheaper. | Because I didn't explain myself properly to the guy that made the flange for me, and he drilled the holes to 6.5mm so we could put bolts through.
__________________ Cavalier TD: Going strong, 160'000 miles and 169ftlbs. Corsa 1.6 16v: New inlet manifold! |
07-07-2008, 10:41
#279 | | Regional Co-ordinator
Originally Posted by djivesp dude, just pile on some silicon gasket stuff, let it harden halfway then bolt it down, it will squish the excess out of the sides and the highest point should hold out a bit of vacuum  | Sounds like normal practice tbh. My Mantzel isnt much better.
07-07-2008, 16:13
#280 | | Regional Co-ordinator
Join Date: Sep 2005 Location: Midlothian, Scotland Drives: Saab 9000 2.3T
| Re: Project Deathtrap: Jack's 1.2 Corsa Them power boxes = something like the pikies outside my work would create out of stolen ally
Top stuff for making it work though
__________________ MIG Performance Saabs |
07-07-2008, 16:25
#281 | | MIGWeb User
Join Date: Mar 2004 Location: Stoke Drives: 16v Nova, Astra TD
Originally Posted by Lugy Them power boxes = something like the pikies outside my work would create out of stolen ally  | They do, but they get the gains  |
07-07-2008, 16:36
#282 | | Regional Co-ordinator
Originally Posted by LongLiveTheNova They do, but they get the gains  | Obviously I don't know how they have been made, but if they were jigged a bit better and maybe some thicker material for the base then they could be so much easier to fit.
IMO something that works is something that is user friendly and is fit for purpose.  |
07-07-2008, 17:02
#283 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Aye, thicker plate would help, as if you bolt them down to tight, it bends down the top plate, with it only being thin alloy.
Ive had no trouble with mine though, and my engine made 127bhp in this months TV RR feature  |
07-07-2008, 17:10
#284 | | MIGClub Member
Originally Posted by Lugy IMO something that works is something that is user friendly and is fit for purpose.  | I agree to a point. I mean... he's gone to the trouble of including nuts, bolts, jubilee clips, bit of hose...etc, everything I'd need to fit it. So why not make sure the manifold fits properly?
Having said that, it's a lot cheaper than buying a Mantzel or branded powerbox. It's not the prettiest thing in the world, but it's a lot less restrictive than the standard inlet system.
LLTN, what have you done to your engine besides the inlet? I'm thinking the inlet and the flywheel might be enough for me for now, but I don't know any other cheap and easy ways of improving these engines without getting serious.
After the inlet is on properly, we can go over the engine and make sure everything's all there and cool, then we can crack on with fitting it. I can't wait to pull the old 1.2 out and get this new engine in and mounted up.  As soon as the big stuff is in and finished, I can crack on with the fiddly jobs like the wiring, gear linkage, throttle cable...etc. At the moment I feel like there's not really a lot I can do.
Hopefully Mr. Racer will be at Billing so I can collect my suspension off him.
And as soon as I get paid I'm getting the front brakes sorted and my sexy wheels on!  |
07-07-2008, 17:11
#285 | | MIGClub Member
Originally Posted by LongLiveTheNova Aye, thicker plate would help, as if you bolt them down to tight, it bends down the top plate, with it only being thin alloy. | Mine came with some lengths of tube to support the inside of the manifold and stop it squashing.
Well, I say tube... some rough lengths of copper pipe....  |
07-07-2008, 17:23
#286 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa My engine had Mild kent cams(pretty much std lift/duration), de-cat, straight through exhaust, and the inlet box, and made 127bhp@ 6662rpm(the limiter), At Jamsport in March.
A Corsa Gsi with JUST a inlet box made 120bhp on the same RR.
Full writeup in this months tv.
Mine now has a 4-1 manifold and 2.25 SS system, but i now really need a higher rev limit, as it was peaking at the limiter even with the standard exhaust manifold/downpipe/ |
07-07-2008, 17:32
#287 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Cool stuff! If mine makes 120bhp I'll be chuffed.
I think trying to get much more out of it is going to be too expensive. I'll run the 1.6 for a bit and see how I get on with it. Hopefully it'll be fast enough so that I don't get bored of it, but we'll see.  |
07-07-2008, 17:38
#288 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Just strip the fook out the car
Plenty of fun on track  |
07-07-2008, 17:40
#289 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa I've still got all that black **** to get out, but I want to get the engine in and running and everything else sorted and get it actually on the road!
Can't wait to get driving it about. All the finishing touches can come afterwards!
Had a wage increase so I'm already dreaming about Monzas and Carltons!  |
07-07-2008, 17:42
#290 | | Regional Co-ordinator
| Re: Project Deathtrap: Jack's 1.2 Corsa What LongLiveTheNova said. Make it go round corners and stop brilliantly. Light/well balanced cars = much win. |
07-07-2008, 20:39
#291 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Though stripping it you have to really think about. I wouldn't suggest it if you do any more miles than a quick drive to work every day tbh.
Its gonna be a little flyer
brace, new bushes and arb's front&back will make it a lot 'sharper' too |
07-07-2008, 20:44
#292 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa for a brace on the cheap check out my thread  |
19-07-2008, 13:43
#293 | | MIGClub Member
1.6 8v flywheel and clutch gubbins on the left, 1.6 16v on the right.
Dad wouldn't take my word for it that we could use my good pressure plate with the 8v stuff.
TB going on.
Ooooh, very nice.
Some blobs of sealant under the manifold.
That's about it for today. My shopping list for this week:
- A complete set of water hoses. Not sure what I've got or what I haven't got, so going to just buy a whole lot.
- Some new spark plugs
- Big oil breather from the rocker cover
We're getting to that stage where there really aren't a lot more jobs to do before we've got no excuse to get the engine in.  |
19-07-2008, 14:21
#294 | | MIGWeb User
Join Date: May 2007 Location: ............ Drives: ....................
| Re: Project Deathtrap: Jack's 1.2 Corsa Doesn>t look like that power box is gonna have any air leaks now!
looks a tidy fit  |
19-07-2008, 17:37
#295 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa glad your dad told you about the pressure plate, youd have been sat in the car not being able to depress the clutch if you used the 16v one on the 8v fly
friction plates are interchangeable however. |
19-07-2008, 17:52
#296 | | MIGWeb User
| Re: Project Deathtrap: Jack's 1.2 Corsa Aye, the friction ones are identical.
But the 16v pressure cover/plate is different to suit the POT fly.... |
20-07-2008, 08:01
#297 | | MIGClub Member
Originally Posted by GBE86 glad your dad told you about the pressure plate, youd have been sat in the car not being able to depress the clutch if you used the 16v one on the 8v fly
friction plates are interchangeable however. | I meant friction plate, actually.
The one I got with the 8v stuff is knackered, but I knew that when I bought it. The 16v one slips in a treat though.
Does anyone know how similar the water pipework is to the 1.2? Some of the hoses I'm missing or we've cut taking them off.  |
20-07-2008, 08:09
#298 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: Project Deathtrap: Jack's 1.2 Corsa i think you should be ok with most of the hoses you got on the 1.2, the way id go about it is stick it in and then see what ones you need and what you can make fit.
__________________ MIG Performance Vauxhalls WELSH Member |
20-07-2008, 08:20
#299 | | MIGClub Member
| Re: Project Deathtrap: Jack's 1.2 Corsa Yeah, that might be what we end up doing. Although the current saying is "we might as well do this, because it will never be as easy as it is now with the engine on a stand."
My wallet dives for cover every time anyone says that! |
22-07-2008, 17:59
#300 | | MIGClub Member
Jackpot.
Found in a box in my garage.  |
Members: 43,214
Threads: 310,615
Top Poster: LEE69 (43,150) | | Welcome to our newest member, chrismessenger | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
