HAHAHA!
right, here is teh spec of my car so you know [ btw, sorry for taking ages to reply! ]
Car lada 21057 - riva to us brits!
Engine is a c20xe out of a cav mk3
Gearbox is ford type 9 as fittd to seirra and is 5 speed with tranx gear kit
Bellhousing is a conversion one you can buy from the likes of rally and comp for £160
Clutch is now standard sierrra but is struggling with the power so i have a paddle to fit now
prop is slightly lengthened rs2000 mkii escort
rear axel is 1/2 ford engish with english diff, and 1/2 lada, with lada drums and shafts which fit right into the english diff
its 5 linked as standard
It has adjustible bias brakes threw a pedal box,
front brakes are fiat croma turbo disks, and volvo 240 4 pot calipers [ very simular to pricness 4 pots but a lot cheeper! ]
front is wishbones, billstein shocks [ and rear too ! ] lada 2121 [ niva ] springs front and cut down standard rear springs with another set of rear springs cut down to 5 coild joined to the other springs !!!
Bet you never heard of that before!
car is on 14" compomotive mo's to get over the brake calipers
bulkhead was cut to get the xe in
tunnel was cut to get the type 9 in
apart fromt hat the car is factory 21057
