Is it possible to convert a non power hood mk2 astra convertible to a power hood, is it a straight swap or is there some modification involved
I'm reloaded! Okay? Come on in here, you mother****ers! Come on, I'm waitin' for ya! What, you ain't comin' in? Okay, I'm comin' out! Oh, you up against me now, mother****ers!
IIRR the mounts for the hydraulic rams need creating as the non power hood doesn't have them on the body shell.
i thought they were a str8 swop for the gas struts that are on there?
From what I remember they were different.
The power hood uses beefier rams than the manual hood.
Have a look in the Vauxhall TIS program, at the section for removing the roof.
It shows the mountings for the power hood.
what it is i have access to a power hood version which is ready for the scrap yard, i've also got my eye on a non power hood version.
So basicly what your saying is if i reuse all the old power hood stuff, possibly weld in the power hood mounting points then it should be all good.
If you have access to both, you'll be in a better position to see what's needed and whats not.
At the time I had a cabrio gte, I looked into getting a power hood at one point
After a while of looking at TIS I decided against it, as too much work for not enough gain
(My manual hood was in good condition)
Power hoods quite a big gain in my eyes especially when you can bypass the handbrake switch so you can put the hood up while in motion.
Did the big strip down on my old GTE cabby today so I could put the later spec black interior in my new one.
While both cars were stripped I had a good look at the hydraulic arms for the roof mechanism and it looks lke quite a simple job to convert a non power hood to power hood.
I have taken some pictures of both the roof mechanisms and will post them up asap along with a update with the new black interior
