Old 16-04-2008, 21:05   #1
1.2 my first rebuild dont laugh lol
hi all,
well im going to re build a 1.2 8v , never done this befor ,
any tips on what to replace would be a good help ,
ill post some pics up as a go along ,
cheers
scott
S700TTT is offline   Reply With Quote
Old 16-04-2008, 21:13   #2
Re: 1.2 rebuild dont laugh lol
hows it going?
what car is the engine in? assume corsa by the engine and the username but maybe a nova?
not so long ago i was rebuilding my 1200. what to replace depends on what condition it is in really, how in-depth you want to go, how much you want to spend and crucially how much space/shelter/tools/knowledge you have available to you.
answer those questions and i reckon there will be half a dozen folk giving you help and ideas.
kenny
competition nova parts needed! see below...
migweb.co.uk/forums/cars-items-wanted/375558-competition-high-end-nova-parts.html
kennybarbour is offline   Reply With Quote
Old 16-04-2008, 21:17   #3
Drives: 2.1 16v corsa gsi
ive got a full rebuilt 1200 8v engine from a h plate nova diamond if you want it? comes with gearbox etc
davie
davie_16v is offline   Reply With Quote
Old 17-04-2008, 08:02   #4
Originally Posted by kennybarbour View Post
hows it going?
kenny
well for a start its out of a 1.2 corsa montana , old carb engine 1996 ,
it wasnt in that bad a condition i will post some pics !
the head and everything is off just cleaning at the moment , i need to buy a spring comressor for the valves get them out and replaced ,
the only reason why im doing it is because it was starting to leak oil and the car its self didnt cost me much at all !
i have a good knowlage i think and a good work area to do it in down in a fully heated utility room (my mums not happy but o well !) lol !
the only reason im doing it it to get experiance im going to start with the head first , because its all off , then ill drop the bottom end out see what its like, piston barels look good and pistons dont look that bad, should i do the rings ?
well hear is the car how a bought it :
were i picked it up from :
the paint condition:
after a little buff of the rear of the car to see what i could get it looking like and i was impressed :
cheers
Old 17-04-2008, 21:23   #5
well as i said its about the engine mainly,
the car had been stood a while !! so was all cloged up and gaskets were buggered ,
so this is how the head and bits are at the moment after the first clean:
first the carb:
then the head bits:
Next week im getting them cleaned with some chemicals by a friend then power washed and dryed ,
This is all after taking the valves out and cleaning them and getting the guides cleaned ect, so its spot on ,
any comments on condition ect are very welcome ,
cheers
scott
Old 17-04-2008, 21:35   #6
EY
EY's Avatar
Drives: to get more petrol.
Good way to learn Keep us posted.
1993 Calibra turbo. Spare engine in the dining room.
EY is offline   Reply With Quote
Old 17-04-2008, 22:07   #7
Drives: Astra G SRi 16v
Wooo Rio Verde..
Nice way to learn building an enigne!
SRimon is offline   Reply With Quote
Old 17-04-2008, 22:13   #8
will do mate, thats why im doing it just to learn that bit more lol
Old 17-04-2008, 22:14   #9
Drives: ....................
as said above great way to learn,
And it`s the single point injection not carb
Tbh i wouldnt bother pulling the bottom end apart, unless you know the rings are funcked.(mainly cos i`m lazy but if you wanna learn)
could clean out the sump and put a new oil pickup waterpump and sump gasket on.
new thermostat for the top end, coolant temp sensor will probably fail if you re-use it, but only cost a couple o quid,(this is located in the inlet)
erm, Dunno what else to say
chrisscirocco is offline   Reply With Quote
Old 17-04-2008, 22:25   #10
the sump is the main gasket that has gone so that will be coming off , lol
if the boars look ok do you recon i should leave the bottom end and whats the best way to check the rings ?? the engine was a runner apart from the leaks lol (i was told! lol ),
i was thinking to do the following ?
water pump ?
timing kit belt ect ?
thermostat?
ill now do the coolent temp sensor lol were abouts on the inlet is this ?
anything else you would do let me know ?
full gasket kit inlet sump and head gaskets and head bolts.
and a full hose kit as the hoses look shot ,
does those valves look ok to any of you just need a clean up ?
Old 17-04-2008, 22:40   #11
water pump ?
thermostat?
The valves look okay from here, just very coked up and needing a clean, you should get a new set of valve stem seals with the head gasket kit,
The CTS is located on the top of the inlet manifold ,towards the left as you look from above, it screws into the manifold and would have a blue wire to it when fitted to the car, from experience when you undo these to bleed the cooling system they seem to fail afterwards so i change em now,
All the other items you mentioned are what you`ll be needing, don`t forget a new rocker cover gasket,
ok i hope that makes sense i`m tired,, i`ll double check it tomorrow lol
i`ll leave the piston boar question to someone else
Old 17-04-2008, 23:04   #12
cheers mate you have been a good help not like these that just say buy a manual lol ,
yeah rockers cover will be done all gaskets ,
yeah please some one let me know how to check if the piston rings need doing or not if not ill leave the bottom end lol
cheers all
Old 17-04-2008, 23:15   #13
i tthink the only way to check the piston and ring n rods properly is to remove them completely, and clean up, or replace any parts that need doing,
obviously you could check by running the engine, but its too late for that now lol.
what is the mileage of the car , cos if it is relatively low there shouldnt be anything wrong with the bottom end,, unless its been severely abused or neglected,
Old 18-04-2008, 07:25   #14
one owner from new 100k on the clock anything was the seals started to go thats what i got told , if there is no markings on the boar should they be ok ?
Old 18-04-2008, 20:51   #15
should be, my friend has a 1200 with 200k on the clock and no rebuilds, its still sweet
Old 20-04-2008, 21:38   #16
well a bit of an update,
finally bought a valve pring comressor
my first ever clamp up
first sring off !
all the springs off lol !
this is how the bits and bobs look not to bad just what i thought ,
well iv heard alot about this gunk stuff ! and i have to say its mint !
only left it for 10mins or so and washed off and they now look like this look above for comparisons
after those pics i gunked them all up again and going to leave them over night ,
comments welcome!
Old 21-04-2008, 20:17   #17
good job!
the throttle body can be dismantled more, the injector in the middle comes out with a twist,(Where the wire used to be plugged at the top),
probably worth sending off for a clean and new seals,as im sure it`ll have lost performance over the years,,
http://www.migweb.co.uk/forums/engin...-cleaning.html
Old 21-04-2008, 21:54   #18
yeah iv taken it apart and given it a good clean up , might do it again just to make sure,
i have more up dates , laptop wont let me put pics on but ill try again tomorrow , keep you updated seen as no one else it watching it lol
Cheers for you help ,
Old 24-04-2008, 08:32   #19
just had a quote for the head skimming and valve's grinding and valveseals fitted, £40 ? is that a good price ?
Old 24-04-2008, 09:35   #20
that sounds like a good price, last time i had a head skim on its own it was £30
Old 24-04-2008, 10:27   #21
sounds good to me then ,
the camra is playing up so i cant post any pics , but everything is oil free now loL !
Old 24-04-2008, 11:43   #22
MSG
Drives: Calibra 16V 2L P Reg
LOL! what does your Mom think of you hijacking her kitchen sink!!!
Calibra simply Calibra
I blessed Nemesis's Calibra and he got gagged, anybody else wants their Calibra blessed?
MSG is offline   Reply With Quote
Old 24-04-2008, 14:59   #23
wow get back ! do you realy think my kitchen is stuck in the 60's !
its a spear room under the house thats just has the washer and some funky wall paper and units in !
i just do all the dirty work down there,
least its warm and dry, the garage is for the car ! lol
Old 24-04-2008, 15:22   #24
MSG
funky 60s wall paper for sure!
Any way, good going on that engun.!
Old 24-04-2008, 16:13   #25
Drives: around looking Cool!
it's njin
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
