Old 15-04-2008, 17:13   #1
Thumbs up XE Nova
Hello everyone,
Im currently undertaking an XE conversion on my nova. Ive owned her over two years now and she started live as a bog standard 1.4 8v luxe. Ive owned a few novas in my times so I already had loads to put on her as soon as I got her home. So she was treated to apex/bilstein shocks with apex 40mm lowering springs, digidash, SR interior, GSi bumpers, Astra GTE alloys in matt black and a full rally spec exhaust system. I drove it around terrorising the local area for about a year and a half. It was a super little car even with the 1.4 8v in. I scanned ebay and eventually found a redtop calibra for £290. I bought the car and the lump was removed and the shell scrapped.
The nova was fine until some dirty scrot bag reversed into me damaging the number plate light. The car was parked at the time and there was no visable damage apart from the light was shorting out causing fire everytime I had my lights on. After loads of messing about I took it off the road. Anyways pictures speak louder the words:
The milage as we fitted the digidash.
These were taken whilst she was still sporting the 8v.
The XE still in the Calibra.
I bought some cav slabs off of Ernie on png and had them refurbed and sprayed in gloss black.
So it begins.
Well getting the old one out was easy enough, lets hope the new one is just as easy...
And so the prepping began.
The XE got stuck in the ford( ) for a couple of days.
I NEED MORE POWER CAPTAIN!
Save hassling about, I bought a couple of new mounts off Chris Astley.
We lifted the car over the engine, it was a mission. Then we used a trolley jack to get the engine in postion before mouting it. Using a Hoist would have been cheating. It only took us about 4 hour and was extremely stressful and loads of hardwork.
We were a bit worried about clearence on the passenger wing and the gearbox. So we rammed a few spacers between the mount and the engine. We also had to cut down the bolt that runs throught the rubber part of the passenger side mount.
We removed the oil cooler sandwich plate.
Assembled the driveshafts (GTE shafts and outer CVs and cav mk2 1.6 inner CVs)
and as it sits today
I got a few more bits to complete; I need a three pipe that sits below the inlet manifold. Then I can get the inlet manifold on. I also need an MPI fuel tank and pump. Then it all need to be wired up, the fun bit Not long now!
Hope you all enjoy!
djshaggeh is offline   Reply With Quote
Old 15-04-2008, 18:27   #2
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Re: XE Nova
Good work dude, looks like quite a clean shell too.
What did you get ya inner cvs from?
Old 15-04-2008, 20:01   #3
Re: XE Nova
Cav mk2 1600 inners mate.
Im really happy with the shell, paid £500 for her a few years back and shes done me proud. I love the colour too.
Im gonna have to redrill the holes for the split pin or find a wider hub nut as the current hole is too far away.
Old 15-04-2008, 20:10   #4
Benn's Avatar
Re: XE Nova
Sorry should read, where did you get the cvs? As i cant find any.
Old 15-04-2008, 22:17   #5
Re: XE Nova
I work for allparts. We sell them there. I get quite a tidy little discount. If your willing to meet I cant get you some.
Old 16-04-2008, 07:24   #6
Benn's Avatar
Re: XE Nova
Where do you live?
Old 16-04-2008, 07:27   #7
Drives: Evo 8 MR FQ320
Re: XE Nova
that welding won't last long it hasn't penetrated both layers of metal
Champion is offline   Reply With Quote
Old 16-04-2008, 07:59   #8
Drives: nova gsi c20let
Re: XE Nova
Very keen I always admire people who do conversions like this outside. Your welds do look poor more heat needed and are you using a shielding gas? Or was it windy?
stevebarker is offline   Reply With Quote
Old 16-04-2008, 17:10   #9
Re: XE Nova
I live in High Wycombe near London about 25 miles east.
Alternatively, they were bought from a company called drivelink. Try your local motor factor.
I come from near Steve, Carlisle.
With regards to the welding mate, I know its pretty poor. Unfortantly it was my first time and I didnt really know what I was up to! I even got arc eye. I used some bagdad special MIG 105 amp welder I got from screw fix for £100. A couple of weeks later I met a local guy willing to lend me his pro welder - gutted. So i cut him a deal, when cracks occur Ill be straight up to his place for a patch up. Expect the worst and you cant go far wrong.
Old 16-04-2008, 17:18   #10
Benn's Avatar
Re: XE Nova
I work for a motorfactors and no where can get them,
any chance you can pm me a part number?
Old 16-04-2008, 20:36   #11
Re: XE Nova
PMed.
It moves. We rolled it foward to clear up some of the mess. It felt so good being in the driving seat!
We put the bonnet on and got abit closer to putting the clutch cable back in. The section that runs through the bulkhead needs a little bit more chopping and angling so it points in the right direction. Ive also sourced a GTE tank which I plan to pick up at the end of the month. I also need some brake pipe union nuts.
Old 06-05-2008, 18:37   #12
Re: XE Nova
I picked up the fueltank (cheers chimp) and my bits from vauxhall and plodded on. Its been 1 step forward, two steps back for a while now so I was determinded to get something done.
Whilst a friend changed his gearbox on his nova, I got on with some wiring.
Armed with the girl friends laptop and a pair of wire strippers I began. I was using the diagram from the novaloads articals section. I kinda started at the bottom, wiring the nova loom to the XE, ie the alternator and oil sensor.
I noticed that one of the sensor at the front for the sump had been damaged. The wires had pulled out of the terminals.
The next step was the fueltank. It already had a pump, bonus!
Unfortunatly I bought the wrong size fuel line so I need to get that sorted. Appart from that everything else was in place.
When we pulled that sensor out we thought the sump had been drained.
Whilst wiring up the ICV (idle control valve) I noticed on the same loom, there is a blue wire with a spade style conector, where does this go?
Cheers for looking
Old 06-05-2008, 19:12   #13
Benn's Avatar
Re: XE Nova
Why does it saw w anker on your ream beam?
and you dont need the sensor on the sump, just cut the wiring off.
Old 06-05-2008, 22:45   #14
Re: XE Nova
It says W anker because the the last mot tester wrote it, he knew I was tracking it after so thought he'd leave me a suprize.
What sensor is it?
Old 06-05-2008, 23:14   #15
Drives: 20xe Cavalier SRI
Re: XE Nova
oil level
wayne85 is offline   Reply With Quote
Old 07-05-2008, 16:30   #16
Re: XE Nova
Right, so why would I want to cut it?!
It will be repaired and stuck back in and wired up.
Old 11-05-2008, 21:45   #17
Re: XE Nova
So the inlet came off *again* getting pretty speedy at taking it off and putting it back on. Was a good job too because I hadnt wired the alternator up properly. So we resolved that.
Whilst the manifold was off I chopped a dirty great hole in the bulkhead for the airbox.
I took a quick photo of the alternator for clearence. Althought the photo is a bit dark.
We cut the hole in the bulkhead and began wiring it all up. I rigged in a push button start and a key switch because I got rid of the ignition barrel after I lost my keys - only to find them a couple of months later dangling on the underside of a chair in the living room. Im gonna have a secret kill switch too.
So close, just missing that fuelline, I ordered 10mm as 8mm does fit over the pump.
Got her to turn over for the first time in a year n a bit
Old 11-05-2008, 21:50   #18
Benn's Avatar
Re: XE Nova
Funk me the alt will rub like funk.
I had more clearance that that and it rubbed really really badly
Old 12-05-2008, 09:50   #19
dearing5's Avatar
Drives: C20LET 5dr corsa
Re: XE Nova
good stuff mate
dearing5 is offline   Reply With Quote
Old 11-06-2008, 22:22   #20
Re: XE Nova
http://s25.photobucket.com/albums/c5...t=MOV00341.flv
It runs now I just have to mod the exhaust to fit the manifold
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
