LinkBack (1) Thread Tools
Old 08-04-2008, 20:11   #1
Gagged
Drives: corsa-c c20let
my corsa-c c20let conversion
this is wat my car looks like
heres wiv the old engine in-----
so work stanted on getting it out ----
new engine ----------------
sprayed inlet, fuel rail and tophat
fitted, lightened + balanced flywheel & uprated clutch
costcast
new head gasket fitted
more pics 2 add
comments welcomed
showcorsa is offline   Reply With Quote
Old 18-04-2008, 21:07   #2
Gagged
Re: my corsa-c c20let conversion
im after abit of help ppz,
Old 18-04-2008, 21:08   #3
Gagged
anybody know where the pipe on the left hand side of the tb go's?
this is my 1st ever conversion so i cud really do wiv a hand lol
Old 18-04-2008, 22:04   #4
Gagged
plz people
Old 18-04-2008, 22:30   #5
Drives: Astra GSi Mk3
Nice one...... You selling old rocker cover lol
**Astra GSi Mk3 ** MVOC.co.uk
*Adz* is offline   Reply With Quote
Old 19-04-2008, 17:25   #6
Gagged
nah im not m8 soz
does any1 know where the 1 way valve go's?
Old 19-04-2008, 17:43   #7
Drives: Corsa LET
Luke85 is offline   Reply With Quote
Old 19-04-2008, 17:44   #8
Drives: Corsa LET
The one way valve it just above and to the right of the oil cap there, should be plumbed in so that when the car is on boost it wont blow into the rocker cover
Old 19-04-2008, 20:14   #9
Gagged
thanx m8, im slowly learning now m8.lol
the 2 pipes out of the heater matrix, where do they go?
and on the header tank, does the pipe at the bottom go into the head on the side.
do i need a tank vent and tank vent valve? wb
Old 19-04-2008, 20:22   #10
Drives: Corsa LET
2 pipes on heater matrix: one goes to the end of the cylinder head and one goes to the big plastic pipe that goes to the back of the water pump.
Pipe at the bottom of the header tank also goes to this big plastic pipe from the bottom of the water pump.
You will need a tank vent vale to keep the ECU happy but I kept the Corsa B one with mine and left it plumbed in the same, not sure about the corsa C though
Old 19-04-2008, 20:25   #11
Gagged
update on pics-
new l/w bottom pulley-
new forge actuator-
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01301.jpg[/IMG]
some roose motorsport hoses and k&n filter-
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01305.jpg[/IMG]
Old 19-04-2008, 20:27   #12
Gagged
my car waiting for engine 2 b fitted lol-
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01324.jpg[/IMG]
engine side-
engine top-
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01329.jpg[/IMG]
Old 19-04-2008, 20:29   #13
Gagged
are the tank vent valves expensive and the tank vent, cus i didnt get 1 with my engine
Old 19-04-2008, 20:30   #14
Gagged
Old 19-04-2008, 20:54   #15
Gagged
and ,do u no on the bottom of the tb, there is 3 pipes, ive sorted out the 2 bottom 1's just need 2 know where the thin 1 at the top go's
Old 19-04-2008, 21:05   #16
Drives: Corsa LET
I think on the vacuum side you have
1) fuel pressure regulator Via hot start valve
2) ECU pipe
3) fuel tank vent valve
If you have any of these T'd into the same pipe then just blank off the spare pipe
Old 19-04-2008, 21:19   #17
Gagged
i mean these soz m8----
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01308.jpg[/IMG]
Old 19-04-2008, 21:19   #18
Gagged
[IMG]i194.photobucket.com/albums/z31/ben951_album/DSC01308.jpg[/IMG][/IMG]
Old 19-04-2008, 21:20   #19
Gagged
Old 19-04-2008, 21:21   #20
Gagged
dunno if them pics r workin tho m8
Old 20-04-2008, 15:25   #21
Gagged
do i need a tank vent? and a tank vent valve?
Old 20-04-2008, 16:25   #22
Drives: Corsa LET
Old 20-04-2008, 16:28   #23
Drives: Corsa LET
Im not sure what they are to be honest, they were already conected when I put my engine in. You need to look up how the corsa C tank vent system works, You should plug a tank vent valve into the LET loom to keep the ECU happy even if you dont pup pipes to it. I know of some people who have done this and just left the pipe to the charcoal cannister open, not sure if you could smell fuel in the summer though
Old 20-04-2008, 17:25   #24
Gagged
thanx m8, dunno wat the tank valve looks like on the corsa-c tho lol
Old 20-04-2008, 17:26   #25
Gagged
do u not wat this is on this pic, ive outlined it
[IMG]i194.photobucket.com/albums/z31/ben951_album/2837541500a4762852988l.jpg[/IMG]
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/356223-my-corsa-c-c20let-conversion.html
Posted By For Type Date
Projects & Restorations on MIGWeb | BoardReader This thread Refback 06-11-2008 18:46
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
