LinkBack (1) Thread Tools
Old 04-08-2008, 19:48   #101
Drives: around looking Cool!
Re: my corsa-c c20let conversion
Just the one washer at the head of the bolt please
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 04-08-2008, 20:23   #102
Gagged
Drives: corsa-c c20let
thanx m8... anybody no the best cams 2 have for the c20let? wat can i do 2 the head for bigger bhp?
showcorsa is offline   Reply With Quote
Old 04-08-2008, 22:07   #103
Drives: like a saint-9points
thats wrong stevie boy, IME its always one behind the bolt head then one between the banjo and the oil pump body.
rodgerq
thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me
rodgerq is offline   Reply With Quote
Old 04-08-2008, 22:09   #104
XE inlet cam seems a popular budget choice. bit more aggressive but you need a vernier pulley to get the most from it. cant remember exaclty what the best timing setup is but you need to retard it im sure, maybe half a tooth or somethin like that. loads on here have done it so have a wee search about and you'll find some info no doubt
rodgerq
Old 04-08-2008, 22:39   #105
Gagged
thanx m8....
so where do i hav 2 put the washers then???
Old 05-08-2008, 15:39   #106
I have one on mine and it is fine, but if you like, put two on...
One on the bolt, then put the banjo on, then a washer, then bolt it up!!
Old 05-08-2008, 21:05   #107
Gagged
tried the car agen 2day and still nothing
tryed a electrical tester on the crankpostion sensor. on the black plug that goes over the top of the engine.
i used 1 of them big screwdriver testers wiv the red an green light......
tryed turning the car over 2 see if any of the 3 pins was giving out a signal.... none of them done anything
Old 06-08-2008, 11:47   #108
Gagged
think thats y my fuel pumpaint working :S
Old 06-08-2008, 12:10   #109
DaveB's Avatar
Drives: Corsa XE with TBs
If crank sensor is knacked then the fuel pump won't work as it goes through the fuel pump relay
www.autovaux.com for new crank sensor
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 06-08-2008, 12:34   #110
Gagged
mite see if i can get a diagnostic plug for the c20let loom so i can see if there is anythin else wrong wiv it now
Old 06-08-2008, 19:45   #111
Gagged
replaced the crank position sensor... put a new dizzy cap on and rotary arm..... still the fuel pump isnt working.. bypassed the pump so its on constantly and tried firing it up and it still wont bloody start
Old 06-08-2008, 21:09   #112
if the spark plugs are sparking then the crank sensor isnt faulty.
did you electrically test the fuel pump relay injector feed wire like i said earlier? or just try a new fuel pump relay
rodgerq
Old 06-08-2008, 21:22   #113
Gagged
rodgerq
i dont think they are sparking m8
i have heard the fuel pump relay click when we put a piece of wire from the positive on the battery to the positive on the ignition coil tho
Old 06-08-2008, 21:24   #114
Gagged
rodgerq
was that the thick red/blue 1 m8?
Old 06-08-2008, 21:47   #115
Hiya mate, need to see if the ecu is getting the info to show the engine is turning over,unplug you ecu get a multi meter put it on ac voltage and go on pin 49 and earth with the other lead, crank the engine and it should read 1.4 volts or higher,if you get that then the crank sensor is good and so is the info plug in the ecu back in and put your mutli meter on 12vdc and unplug the airflow meter connect to pin 5 blue/red crank the engine it should switch to 9v or higher under cranking and bat voltage when running,and it would be and idea to power up the injectors just to check there not seized,if the engine has not ran for a long time the injectors can seize ive had 2 c20lets over the years do this to me, just put a 12 volt supply to the injector and each one should make a nice clean clicking sound if no sound comes of the injector its faulty
daz996 is offline   Reply With Quote
Old 06-08-2008, 22:13   #116
Gagged
thanx m8..i will try that in the morning
Old 07-08-2008, 12:48   #117
Gagged
where abouts is number 49?
Old 07-08-2008, 13:10   #118
Drives: Omega & 1.8 Corsa B
i didnt no they needed them tbh
is it 2 each side i need?
You need a washer on each face of the Banjo joint, so two per bolt.
The home of miserable bastids!
http://www.grumpyc*nt.com
Davey is offline   Reply With Quote
Old 07-08-2008, 13:42   #119
not strictly true, I am running one washer with no leaks.... but two is best here!
Old 07-08-2008, 13:56   #120
Gagged
only got 1 on and its stopped the leaks..
Old 07-08-2008, 14:01   #121
Gagged
if the distributor aint working.. will the fuel pump not kick in?
Old 07-08-2008, 14:06   #122
yes fuel pump will kick in
Old 07-08-2008, 14:45   #123
Gagged
it mite be that then :S
Old 07-08-2008, 16:07   #124
the distributor isnt anything to do with the fuel pump mate. plus if you are getting a spark then the distibutor is working!!
its the thin red/blue wire coming from the fuel pump relay you need to check to make sure the injectors are getting power. its the same as checking the pin on the air flow meter as the wire feeds the power to the airflow meter and the injectors plus other sensors.
rodgerq
Old 07-08-2008, 16:11   #125
unplug your ecu and look at the plug , the the pins are layed out like a letter T the bottom row should have 55 at one end and 38 at the other,start at 55 and count 7 back that should be pin 49(grey/black), the disi has a hall sensor built in, it is only a cam sensor (so it can run sequential injection) it will still trip the fuel pump in with the disi un pluged, all the ecu needs to put power to the fuel pump is a crankshaft signal
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/356223-my-corsa-c-c20let-conversion.html
Posted By For Type Date
Projects & Restorations on MIGWeb | BoardReader This thread Refback 06-11-2008 18:46
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
