03-08-2008, 19:33
#76 | | MIGWeb User
Join Date: Jan 2002 Location: ayrshire scotland Drives: like a saint-9points
| Re: my corsa-c c20let conversion you cant buy the plug you need but you can cut it off another car that has the same type and wire it to the square green plug on eht LET loom. then you'll be able to plug a code reader in. i assumed you had the LET loom ecu wired up to the dash ecu light. you could always wire the LET ecu light to a seperate bulb, its a piss easy job. then you'll know if the LET ecu is throwing out codes aswell as the rest of the car.
is it the oil cooler connection washers you need? Vauxhall do them for a couple quid. is it leaking that bad that you cant even see if the thing fires up lol
rodgerq
__________________ thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me |
03-08-2008, 19:44
#77 | | Gagged
Join Date: Sep 2007 Location: Bristol Drives: corsa-c c20let
| Re: my corsa-c c20let conversion Quote:
Originally Posted by rodgerq you cant buy the plug you need but you can cut it off another car that has the same type and wire it to the square green plug on eht LET loom. then you'll be able to plug a code reader in. i assumed you had the LET loom ecu wired up to the dash ecu light. you could always wire the LET ecu light to a seperate bulb, its a piss easy job. then you'll know if the LET ecu is throwing out codes aswell as the rest of the car.
rodgerq |
i wud wire it into the corsa 16 pin plug but i dont no if they are the same colours tbh..
ye its just the copper washers i think mate
its coming out quite alot .. i mite be able 2 start in but its p****ing it down outside  |
03-08-2008, 20:18
#78 | | MIGWeb User
Originally Posted by showcorsa i wud wire it into the corsa 16 pin plug but i dont no if they are the same colours tbh..
its coming out quite alot .. i mite be able 2 start in but its p****ing it down outside  | the corsa plug is different to the plug that the LET loom uses as its interface. the LET loom plug is only a ten pin plug. easy to wire in though and you could get one from a scrappy from an old cavy or astra or something with an older engine in - none of this canbus pish
rodgerq |
03-08-2008, 20:29
#79 | | Gagged
Originally Posted by rodgerq the corsa plug is different to the plug that the LET loom uses as its interface. the LET loom plug is only a ten pin plug. easy to wire in though and you could get one from a scrappy from an old cavy or astra or something with an older engine in - none of this canbus pish
rodgerq |
thats tru m8,, wud it be the same on a corsa-b? |
03-08-2008, 20:50
#80 | | MIGWeb User
Originally Posted by showcorsa thats tru m8,, wud it be the same on a corsa-b? | aye im sure some of them will have that plug.
rodgerq |
03-08-2008, 20:51
#81 | | MIGWeb User
| Re: my corsa-c c20let conversion did you do the wiring on your own corsa? where did you wire the ignition switched feed from the LET loom to on the corsa loom? how do you get the clocks to keep working?
rodgerq |
03-08-2008, 20:59
#82 | | Gagged
Originally Posted by rodgerq did you do the wiring on your own corsa? where did you wire the ignition switched feed from the LET loom to on the corsa loom? how do you get the clocks to keep working?
rodgerq | yes i did wire my car m8... ign live on the let loom went 2 the ign live on the corsa-c loom.. wiv the gauges...
speedo is ran from a sensor that is by the driverside driveshaft end
rev gauge-- u hav 2 splice off the crank position sensor. so it goes 2 the let ecu and the corsa-c ecu at the same time..
water temp gauge--- on the thermostat where there are 2 connections.. 1 for the ecu on the let loom and 1 for the gauge on the let loom.. remove the 1 that goes 2 the gauge .. and drill it out.. then run a tap in it so it will take the cors-c temp sensor.. easy as that  |
03-08-2008, 21:25
#83 | | MIGWeb User
| Re: my corsa-c c20let conversion aye that doesnt sound overly taxing really. got any knowledge about puting a z20let in? im leaning more towards that just for the fact its newer
did you have to install the speedo setup yourself or is that standard gear?
rodgerq |
03-08-2008, 21:38
#84 | | MIGWeb User
| Re: my corsa-c c20let conversion will be spot on when its finished.. |
03-08-2008, 22:04
#85 | | Gagged
Originally Posted by GT190 will be spot on when its finished.. | thanx m8  |
03-08-2008, 22:04
#86 | | Gagged
Originally Posted by rodgerq aye that doesnt sound overly taxing really. got any knowledge about puting a z20let in? im leaning more towards that just for the fact its newer
rodgerq | its standard m8
and wat do u need 2 no? |
04-08-2008, 15:43
#87 | | MIGWeb User
| Re: my corsa-c c20let conversion mainly electronic related stuff - mating the engine loom to the car loom and making it all communicate properly. im confident i can mount the engine/box easily and with the right pointers could wire it but the canbus gear is new to me, its always older engines ive been used to sticking in novas and corsa Bs, so at least some starting tips would be helpful.
rodgerq |
04-08-2008, 17:32
#88 | | Gagged
| Re: my corsa-c c20let conversion no luck 2day either... got a massive oil leak tho
checked the plugs and they was dry |
04-08-2008, 17:43
#89 | | MIGWeb User
Originally Posted by showcorsa no luck 2day either... got a massive oil leak tho
checked the plugs and they was dry | ok so would you say its safe to say that the fuel rail has fuel but the injectors arent opening to allow it into the chamber?
if so you'll need to check the injectors power feed. each injector has a red/blue wire - this is the 12v +ve feed from the fuel pump relay. use a volmeter and make sure you are getting 12v to the red/blue wire.
cant check the earths as the ecu switches the earth to energise the injector so its pretty hard to check without a really good meter or a scope but just make sure your 3 ecu loom earths are on the rail and intact.
you could also check the 12v feed is actually comeing away from the relay base itself aswell. its the thin red/blue coming from the relay base
rodgerq |
04-08-2008, 17:44
#90 | | MIGWeb User
| Re: my corsa-c c20let conversion also what 2 digit code is on your LET ecu?
rodgerq |
04-08-2008, 17:46
#91 | | Gagged
Originally Posted by rodgerq also what 2 digit code is on your LET ecu?
rodgerq | pj |
04-08-2008, 17:48
#92 | | MIGWeb User
| Re: my corsa-c c20let conversion ah right thats ok then. thought it might have been an immobilised one you had.
rodgerq |
04-08-2008, 17:50
#93 | | Gagged
Originally Posted by rodgerq ok so would you say its safe to say that the fuel rail has fuel but the injectors arent opening to allow it into the chamber?
rodgerq | which1? the wire that goes 2 the pump? can i just do it wiv ignition on? |
04-08-2008, 17:53
#94 | | MIGWeb User
| Re: my corsa-c c20let conversion no its not the wire going to the pump. thats the thick red/blue coming out the relay base. its the thin red/blue coming out of the relay base you want to check. iirc its number 87 on the base and number 8 on the relay itself. And aye just put the ignition on and check you are gettin 12v +ve out of that wire. it feeds a load of sensors on the engine, not just the injectors so if thats goosed....
rodgerq |
04-08-2008, 17:54
#95 | | Gagged
| Re: my corsa-c c20let conversion heres the oil leak m8. its massive ....
it is coming out of here....
and i think its coming out of here aswell  .....  |
04-08-2008, 18:00
#96 | | MIGWeb User
| Re: my corsa-c c20let conversion they pipes are common. my nova was murder at one point, covered the whole inside of the wheel. took ages to clean it. some new washers will see that sorted though. and if that other bolt is leaking stick some ptfe tape round the threads to help bolster the seal cause i dont think you can buy that seal seperate.
rodgerq |
04-08-2008, 18:27
#97 | | Gagged
| Re: my corsa-c c20let conversion ive got sum copper washers coming 2moz for the oil cooler
do u no u sed if i wave a scredriver by the end of the carnk postion sensor then the relay shud click.. well.... it dont click  |
04-08-2008, 18:30
#98 | | Gagged
| Re: my corsa-c c20let conversion is it 2 or 4 i need m8? |
04-08-2008, 18:39
#99 | | MIGWeb User
Join Date: Oct 2005 Location: ThickFord, Shrops... Drives: around looking Cool!
| Re: my corsa-c c20let conversion yep. don't look like they have washers on, so get some new washers on there soon as mate
__________________ (='.'=)
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot! |
04-08-2008, 18:49
#100 | | Gagged
Originally Posted by Steve! yep. don't look like they have washers on, so get some new washers on there soon as mate | i didnt no they needed them tbh
is it 2 each side i need? |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
