LinkBack (1) Thread Tools
Old 01-08-2008, 21:03   #51
Gagged
Drives: corsa-c c20let
Re: my corsa-c c20let conversion
ive tried 3 relays now m8..so cant be that.. hmm.. i think there mite be a slit in the cps come 2 think of it
showcorsa is offline   Reply With Quote
Old 01-08-2008, 21:05   #52
Gagged
tried 3 different relays m8.. and dunno about the cps
Old 01-08-2008, 21:06   #53
donvaux's Avatar
Drives: Corsa GSI c20let WIP
cps??
donvaux is offline   Reply With Quote
Old 01-08-2008, 21:08   #54
Gagged
crank position sensor..
Old 01-08-2008, 21:08   #55
Gagged
do u no any1 whos selling a crank position sensor?
Old 01-08-2008, 21:10   #56
donvaux's Avatar
ah right sorry lol, try removing the sensor from the block but leave plugged in and wave a metal screwdriver in front of it while listening to the relay it should click, i'm sure there are some on ebay for sale
If in doubt give it a klout
Old 01-08-2008, 21:11   #57
Drives: around looking Cool!
translated:
Do you know anyone who is selling a CPS?
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 01-08-2008, 21:21   #58
Gagged
Originally Posted by Steve! View Post
translated:
huh?
Old 01-08-2008, 21:22   #59
Gagged
ok m8 i will try that 2moz ... just really wanna get it started up now
Old 02-08-2008, 01:00   #60
Drives: like a saint-9points
enines in ppz.. its turning over but not firing up :S no peterol is gettin2 it and i the fuel pump aint working.. any ideas???
c20let? then it can only be a few things. as said, fuel pump relay or crank sensor are main culprits. do you have an ecu light wired in? is it on at all?
rodgerq
thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me
rodgerq is offline   Reply With Quote
Old 02-08-2008, 16:40   #61
Gagged
rodgerq
ye it is on m8
Old 02-08-2008, 22:30   #62
Gagged
put a tester on the crank position tester 2day. the are 3 pins in the plug at the top.tested them with the ignition on and they hav no power is that normal?
Old 03-08-2008, 11:57   #63
Gagged
i have put the fuel pump 2 positive and theres petrol coming out wiv the pipe off. but wen i connect it back up there is no fuel getting into the rail
Old 03-08-2008, 15:24   #64
Gagged
on the fuel rail!! which 1 is the in and the out?
Old 03-08-2008, 15:56   #65
Drives: cavi,nova,astra,325i
the out from the rail (return) is the pipe at the pressure regulator end left side
dream project lotus carlton lump in a viva
eggman is offline   Reply With Quote
Old 03-08-2008, 16:29   #66
Gagged
so ive done that right .... hmmm
dunno y it aint working then :S
Old 03-08-2008, 17:36   #67
ok so does the ecu light go out after a few seconds of engine cranking?
if it stays on read off the codes.
does it get a spark at the plugs?
rodgerq
Old 03-08-2008, 17:49   #68
Gagged
no it dnt go out m8
Old 03-08-2008, 17:50   #69
Gagged
plugs r sparking aswell
will the fuel pump only start working wen its running?
Old 03-08-2008, 18:06   #70
fuel pump should run when you crank the engine over. check the plugs and see if they are dry.
you say you get fuel to the feed line when you 12v direct feed the pump? are you positive the fuel lines are on the rail the correct way? inlet pipe to right hand side of the rail. did you try and start the engine with a direct feed to the pump?
if you are getting a spark i'd say the crank sensor was fine. next step up the chain would be fuel pump relay as long as you know the wire going from the relay to the pump is fine.
try a direct feed to the pump by bridging the thick red to the thick red/blue on the bottom of the fuel pump relay base. if the pump runs, try and start the engine and see if it starts.
if it starts then i'd say it was your fuel pump relay that was the culprit. if it still doesnt start keep the feed to the pump and press the shraeder valve on the fuel rail and see if fuel squirts out - just jab it quick or it'll cover you and the enigne bay in fuel. if it squirts out then you are getting rail pressure. if the plugs are dry and you are getting rail pressure then its the injectors thats not opening - that can either be an earth issue or a live feed issue(live feed comes from fuel pump relay)
i'd also get the fualt codes read off the ecu and see what they say incase its somethin else but TBH i cant see it - the ecu can pretty much compensate for every sensor being ****ed.
rodgerq
Old 03-08-2008, 18:33   #71
Gagged
rodgerq
ive tryed bridging it and the pump works.. tryed putting pump 2 a positive wen the fuel connection was off.. fuel went everywhere lol... will hav 2 check the plugs agen tbh m8.. i think they was dry cant remeber now
and the fuel lines are on the right way :S
Old 03-08-2008, 18:52   #72
sound. get the fault codes read off and see what they tell you aswell remember
rodgerq
Old 03-08-2008, 18:58   #73
Gagged
rodgerq
i havnt got anything 2 plug my reader into m8. isnt there supposed 2 be a 16 pin plug
mines only about 5 pins straight off the loom :S
Old 03-08-2008, 19:14   #74
you can read the codes using the ecu light. on the LET loom there will be a smallgreen square shaped plug near the ecu. find the brown/yellow wire in that plug and earth it. then turn on the ignition and the ecu light will flash the codes off.
see here for instructions on reading the flashes
http://www.topbuzz.co.uk/info/fault_...ault_codes.htm
its a good article that. have a read through it then see if you can read the codes off.
if you still dont get it, record the sequence on your phone as a video and post it and i'll do it
rodgerq
Old 03-08-2008, 19:22   #75
Gagged
rodgerq
i havnt got the let ecu wired up 2 the corsa-c dash tho m8.. is there a 16 pin thingy that u can buy 2 plug into it?
got fuel in the rail now m8...
cant start it cus there is oil coming out of the sandwich plate above the oil cartridge
any1 got any spare washers?
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/356223-my-corsa-c-c20let-conversion.html
Posted By For Type Date
Projects & Restorations on MIGWeb | BoardReader This thread Refback 06-11-2008 18:46
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
