LinkBack (1) Thread Tools
Old 24-06-2008, 13:49   #51
Drives: nova gsi 16v
Re: my nova
Here is a pic of the throttle bodies re spaced out to suit the inlet manifold.i also hav fitted the xe fuel rail and had a small braket made to hold the rail in place.
The nxt job with these is to fit the xe throttle position sencor switch and make all the bodies open at the same time.
novadaz is online now   Reply With Quote
Old 24-06-2008, 14:19   #52
Drives: class 7 corsa;)
Re: my nova
try and use the centre of the carbs, and weld a couple of little tabs to make the butterflies open at same time(if know what im getting at)
philip2 is offline   Reply With Quote
Old 24-06-2008, 14:22   #53
Re: my nova
i was going to bend one into the other,what you think its brass i think.
Old 24-06-2008, 15:59   #54
Re: my nova
good work!
macc nova is offline   Reply With Quote
Old 24-06-2008, 16:01   #55
Regional Co-ordinator
CraigGreen's Avatar
Drives: smallblock Novas
Re: my nova
Do the carbs have independant cables or is the linkage missing?
V8 blender FTW
Old 24-06-2008, 16:07   #56
Drives: 16v Nova, Astra TD
Re: my nova
Single cable goes at the end Craig.
And then the spindles turn each throttle body open.
The spindle levers are going to need extending.
Out of interest why are you trying to get the xe tps etc fitted? If your trying to run these on the standard ecu your wasting your money/time IMO
EDIT-Ahh, your using MS v3. In that case dont use the xe tps as its not a tps, its a switch. Use the one thats already on the throttle bodies as standard.
LongLiveTheNova is offline   Reply With Quote
Old 24-06-2008, 16:09   #57
Re: my nova
im not running standerd ecu. iv got a megasquirt v3.im swoping the throttle position sensor because im using the xe loom plus it makes thing easy
Old 24-06-2008, 16:12   #58
Re: my nova
so u recon use the plug thats ther. so il get the plug that plugs into the TP's thats all ready on the boddies cut the old plug off the xe loom and join the wires.
Old 24-06-2008, 16:13   #59
Re: my nova
Hmmm, if you cant easily make it fit, just chop the wires on the xe loom and join them with the std tb tps.
And as said, Xes dont have a proper POT throttle sensor, its just a basic switch. MS needs a varying POT tps.
Old 24-06-2008, 16:14   #60
Re: my nova
why r the spindal levers going to need extending?
Old 24-06-2008, 16:44   #61
Re: my nova
Erm, because look at your pics?
Theres now a 1/4" gap inbetween the spindle lever on each body(the gold bit with the springs etc), they should be touching(which is how one linkage opens all four bodys simultaneously)
Old 05-07-2008, 18:02   #62
Re: my nova
Took the bottom end to my friend on friday hes gona start stiping it once hes finishd the head.Got my cams bk from autosprint so i gave them to friend.The bottom end needs stripin as i hav decided to go for 87mm pistons and lighten and balance the engine.
Got a pic of the head in progress also.
Old 05-07-2008, 20:13   #63
Re: my nova
any more pics of the head matey, and in the ports??
getting there slowly
Old 05-07-2008, 20:53   #64
Drives: Corsa 1.4 Corsa 2.0T
Re: my nova
i see you have one of those ilusive money trees
****in awesome build, i would use the tps that came with the TBs and bend over the spindles so they interconnect.
P.S. the first set of TBs look like CBR F1 bodies
Gaz86 is offline   Reply With Quote
Old 06-07-2008, 07:28   #65
Re: my nova
The first bodies are honda cbr 1000 thay hav a 43mm bore but as you can see thay do not split into 4 but into 2 plus it would be harder to make a box for them because theres nothing to hold onto.
Ive made the biggest choice of my life the other day,in september i will be starting a new job going to colage once a week and my wages will go from 22k to 12k.But i am thinking of the future as the prospecs are much better and i wownt hav to travel and do a lot of over time lol.So this means the car will take much longer to finish because of funds,but ive nearly finish coleting the parts for the engine so i could put the engine in when its finishd and hav sum fun with it as it looks lol.
Old 13-07-2008, 18:28   #66
Re: my nova
Got some work done today,me and my mate decided to do the chasi leg and put a spare bloc and head in to make sure ther is enough clearance.
Im geting the manifold back this week so i will put it on the head along with the bodies to se how much room i hav for a air box to be made.
Me and my mate were also thinking of bringin the air flow pipe through the dizzy side as ther is more room this side of the head not sure yet still thinking bout it.
Old 13-07-2008, 18:29   #67
Re: my nova
Old 17-07-2008, 19:50   #68
Re: my nova
Here is a strengthning kit from chris ashley ready for when the engine comes out.
Old 30-07-2008, 18:45   #69
Re: my nova
Because of funds and new job only weeks away i have decided to get 86.75mm pistons with cut out from auto sprint in stead of forged ones.
I have also sold my gsxr 750 throttle bodie set up on ebay last week.
Old 08-08-2008, 19:54   #70
Re: my nova
yesterday i orderd my direc to head throttle bodies from qed,and today i was stund that thay had been deliverd.cant wait to fiddle with them.lol
Old 08-08-2008, 20:07   #71
Gagged
Drives: corsa xe gsi rep
Re: my nova
Oooo them throttle bodies look sexual , how much they set you back mate ?
rwdmad is offline   Reply With Quote
Old 08-08-2008, 20:12   #72
Re: my nova
the bodies with trumpets,fuel rail,throttle position sensor and a few other little sensors including vat and p+p came to 730 pounds.
Old 08-08-2008, 20:18   #73
Gagged
Re: my nova
ooo not bad considering then
Old 09-08-2008, 06:41   #74
Re: my nova
you do know, once our cars are built, have to have a play, was down bangor the other day, so not much further to pop over anglesey
Old 09-08-2008, 08:10   #75
Re: my nova
your welcome m8.i cant wait now,going over to the workshop in a bit put them on the spare engine thats in the bay.u still aint reply to me about the spec of your xe.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/350270-my-nova.html
Posted By For Type Date
Nova Shell Worth? - Performance Nova Group - PNG This thread Refback 11-09-2008 22:01
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
