07-02-2008, 20:43
#1 | | MIGClub Member
Join Date: Feb 2005 Location: Forres, Nr Inverness Drives: Cheap sheds
| My fourth MK3 Astra And it's a Sport  .
Spend a while looking for replacement for my last MK3, thanks to rust biting hard into the shell  .
So after looking at overpriced sheds, I found this one local to me. It's not perfect, no service history or any handbooks and it's a bit rough around the edges. Perfect for me, as I wanted a project.
Pics of it as bought.
Wasn't that pricey either at £210 with T&T intil March. |
07-02-2008, 20:46
#2 | | MIGWeb User
Join Date: Oct 2003 Location: aberdeenshire Drives: s2 escort rs turbo
| At £210 you cant go wrong!! decent runabout!! |
10-02-2008, 18:54
#3 | | MIGClub Member
| After getting sick of seeing it covered in road salt. I gave the car a wash, clay bar, bit of paint cleaner and a polish. Blacked up the black plastic too. It's come up rather well, me thinks  .
Gonna give it a service and get the cambelt done too. |
10-02-2008, 19:21
#4 | | MIGWeb Moderator
Join Date: May 2006 Location: beddau, South Wales Drives: mk3 astra
| cleans up nice chap, i did the same with my sport yesterday |
10-02-2008, 19:28
#5 | | MIGClub Member
| Quote:
Originally Posted by RobJenko cleans up nice chap, i did the same with my sport yesterday | Cheers fella.
I try and keep my cars clean, good exercise  and it looks better when you put in the extra effort  . |
13-02-2008, 22:04
#6 | | MIGClub Member
| Car's going to a mates garage for the cambelt, next Monday. As the car came with next to no service history, it's worth getting one fitted. I'll give it a service very soon too. |
13-02-2008, 22:07
#7 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| which engine have you got init mate, looks like a real good buy for the money
__________________ MIG Performance Vauxhalls WELSH Member |
13-02-2008, 22:44
#8 | | MIGClub Member
| Quote:
Originally Posted by Fow16v which engine have you got init mate, looks like a real good buy for the money | Whoops!
I'd forgotten to mention that  .
It's a 1.6 (X16XEL) mate, runs ok. Slight issue with it running on three (I think thats down to lack of servicing, HT leads were in a bit of a state.) and idles at 1.5k sometimes. Meh, what do ya expect for the money.
For the most part, i'm going to use GM bits or quality parts. Get it back up a good standard again. |
20-02-2008, 22:48
#9 | | MIGClub Member
| Car's in ATM for a cambelt and water pump. So it should be ready tomorrow, put into a mate's garage as I woozed out  . I didn't want to take a chance of messing it up.
Oil change and that's it, ready to use. Then on with the mods  , a 40mm drop should help the looks and i'll get some new GSi rear lights too. |
21-02-2008, 00:18
#10 | | MIGWeb User
Join Date: Feb 2008 Location: suffolk Drives: astra mk3 1.4mpi
| what did you use to get the plastics black again |
21-02-2008, 16:42
#11 | | MIGClub Member
| Looking good sir
Its amazing what a good cleanup can do for a car - looks 100000x better |
21-02-2008, 17:55
#12 | | MIGWeb User
Join Date: Apr 2007 Location: Wakefield West Yorks Drives: Nova SR 1984
|  can't go wrong at that price !
Brushes up nice too  , When is the XE coming?  |
21-02-2008, 19:14
#13 | | MIGClub Member
| Quote:
Originally Posted by hirsty99 what did you use to get the plastics black again | I used Megs trim detailer, got it out of the bargain bucket at hellfrauds  . Seams to last well enough so far. Quote:
Originally Posted by Rubix_Cube Looking good sir
Its amazing what a good cleanup can do for a car - looks 100000x better | Cheers bud  .
Only thing is now i've cleaned it i'll have to keep it that way  . Quote:
It is an XE L, honest  .
I'll see how things go, it might end up with one some day  . |
21-02-2008, 20:54
#14 | | MIGWeb User
| Quote: |
| does this cost much and is it true that the hot air gun works?? |
21-02-2008, 21:02
#15 | | MIGClub Member
| Not sure on the hot air gun trick, as I never tried it on the bumpers.
Megs trim detailer is about £6.50. |
22-02-2008, 11:06
#16 | | MIGWeb User
| hirsty the heat gun trick does work, just be careful so you dont melt them too much  |
24-02-2008, 22:29
#17 | | MIGClub Member
| Got the car back from it's cambelt and water pump swap.
So I had a bit of mince session today, dug out a irmy spolier and gave it a quick (and sh*tty  ) paint. Then got it mounted, it turned out okish but i'll use the right colour next time. It's the same colour as the boot panel ATM.  |
03-04-2008, 18:32
#18 | | MIGClub Member
| Re: My fourth MK3 Astra Got the old Cesaro stripped and started swapping bits over. Then I booked a test (A Vaux garage no less  ). But the test was at 1pm, thanks to taking a little longer getting the car togehter I turned up at 2  . It passed though, I got lucky and they tested it later that day.
Then a change of wheels as the 17's need two tyres. Still the lower the back and fit some other bits too.
Also did something with the left over Cesaro badges....  |
09-04-2008, 20:14
#19 | | MIGWeb User
Join Date: Mar 2008 Location: barnsley Drives: mk3 astra sport 2.0
| Re: My fourth MK3 Astra [IMG]051.jpl[/IMG] |
09-04-2008, 20:19
#20 | | MIGClub Member
| Re: My fourth MK3 Astra Quote:
Originally Posted by 888shane777 [IMG]051.jpl[/IMG] | Eh?
Was that a piccie? |
10-04-2008, 21:50
#21 | | MIGWeb User
Join Date: Aug 2005 Location: Manchester/Torquay Drives: Astra gsi/VectraGsi/
| Re: My fourth MK3 Astra havent seen this on mk3 before i dont think?
looks like it coming along, any more plans for it? |
10-04-2008, 22:07
#22 | | MIGWeb User
Join Date: Oct 2005 Location: ThickFord, Shrops... Drives: around looking Cool!
Haven't seen what on a Mk3 before?
__________________ (='.'=)
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot! |
11-04-2008, 17:50
#23 | | Regional Co-ordinator
Join Date: Dec 2006 Location: KEITH (N.E. SCOTLAND Drives: mk3 astra sport 1.8
| Re: My fourth MK3 Astra I think Barber may have meant mk3oc.com |
11-04-2008, 19:01
#24 | | MIGWeb User
| Re: My fourth MK3 Astra ah, maybe  |
11-04-2008, 19:02
#25 | | MIGClub Member
| Re: My fourth MK3 Astra Barber had already seen the thread and posted on it too  . |
Members: 43,212
Threads: 310,610
now!
of being a MIGClub Member.
