LinkBack (1) Thread Tools
Old 14-03-2008, 00:57   #51
ad4mb1nns's Avatar
Drives: carefully....
ah ok, i were gunna get some of them for a 10er till my mate told me to go for vxr! bugger!
ive had a glance through there before but il read more into in when i need to.
it give me good info on what exhaust manifold to put on and why
Turbo Nova
ad4mb1nns is offline   Reply With Quote
Old 15-03-2008, 15:38   #52
Drives: Corsa 1.4 Corsa 2.0T
actuator painted and trial fitted
new water pump
saab reds and EVO5 ECU
getting close now
Gaz86 is offline   Reply With Quote
Old 15-03-2008, 18:24   #53
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Please tell me its not a plastic impellor water tho...
Are the saab reds bigger/better flow?
Old 15-03-2008, 20:51   #54
yeah it is, i was told its better to get the plastic one as the metal one causes probs apparantly cant remember who it was who told me but it was someone who knew a hell of a lot more than myself
yeah the saabs flow more and only need around 3.5bar to work with the evo5 chips, the standard yellows need jacking over 4 bar to flow enough, ideally cosworth greens would have been a better choice as the impediance is the same as the yellows and they flow almost perfectly at 4bar, but they cost too much!!
also pulled the bottom end apart on my XEV block and it didnt look good, the big end bearings were ****ed beyond beleif and had deformed, all that just from low pressure on start up!!
so ive junked that idea as its going to cost too much to have it measured with bearings etc, ill just have to use my C20 block instead,
more bad news, cant get hold of a bearing for my F28 so im going to use the F20 for a bit till thats sorted.
Old 15-03-2008, 21:26   #55
donvaux's Avatar
Drives: Corsa GSI c20let WIP
have you tried www.cav16.co.uk for f28 bearings by any chance?
If in doubt give it a klout
donvaux is offline   Reply With Quote
Old 15-03-2008, 21:55   #56
yeah they dont do em from what ive seen going to try regal on monday chip reckons they do em.
Old 15-03-2008, 22:55   #57
neil105's Avatar
Drives: astra 16v turbo 1989
which f28 bearing are you after
neil105 is offline   Reply With Quote
Old 15-03-2008, 23:30   #58
the one you needed, ive got 2 carriers totally destroyed, thats the only reason i sold the good rollers to you.
i just want new ones so ill see how i get on with regal, my missus brother lives in germany so ill see if he can wangle some if i have no joy.
Old 15-03-2008, 23:58   #59
neil105's Avatar
have luck with the bearing
paul of here sounded like he could sort something out
Old 16-03-2008, 00:06   #60
Melv's Avatar
Drives: mk3 astra sport 1.8
According to pg 19 of March's (issue 81) Total Vauxhall, LMF do a bearing collar for the F28. Just incase this info is of any use
North of Scotland Regional Coordinator
MIGclub Calendar 2009 - click to order
Melv is offline   Reply With Quote
Old 21-03-2008, 21:17   #61
Gagged
Drives: Corsa Sport C20XE
The water pump impellers were changed to plastic because when the pumps seized up they were damagin or snapping the timing belt leading to total engine damage.
So, they made them plastic so if they seize now lots of little bits of plastic go about your water pipes ect.
Corsa Sport c20xe soon!
chris_16v is offline   Reply With Quote
Old 21-03-2008, 23:36   #62
calcification i think was what was happening probably caused by people running just water or the wrong mix, not too sure?
got my intercooler through a few days ago and offered that up, im well chuffed the bumper wont need cutting
more pics soon, just gotta upload them.
Old 22-03-2008, 09:09   #63
Benn's Avatar
Sounds good.
Old 06-04-2008, 18:50   #64
Re: my corsas evolution from XE to LET
not had much time lately to update the thred so ill just let the pics do the talking
been working on this for a while, took ages to get it to fit and close just gotta mount a switch for the fan.
turbo pistons cleaned up then polished the crowns
£36 worth of nuts and bolts from vaux, i though these were NLS but they have loads.
started to strip down the front end and clean it up, also gave the wheels a once over they were disgusting
was greeted by this this morning, **** that!
Old 06-04-2008, 19:26   #65
Benn's Avatar
Gauge is a bit trick.
Old 06-04-2008, 19:32   #66
had to be, i hate in your face pods but needed it in sight, the insides of the ashtraye have been heavily modded to get it to fit in without jamming up, im really happy with the result.
Old 06-04-2008, 19:35   #67
Benn's Avatar
Yeah looks very neet and tidy. Very nice.
Old 25-04-2008, 02:30   #68
no pics im afraid yet..
engine is pretty much done, even got as close to putting the head back on it but the ****ty ebay gasket i have decided to **** up on fitting, serves me right for saving pennies tw@ eh?
popping down the local carspares for a decent BGA item and getting a full cambelt kit for it while im there.
finally got all my intercooler pipes routed and fitted, need to get a custom high pressure PAS pipe made up and the engine is done and dusted
just got to wait a week or so then i can send this bloody turbo off for its work, been putting it off till last minute.
been sorting out rust too and as some may have spotted there was a bubble under the bootlid rubber about an inch long, after scraping it out i sanded a bit lower (would need painting anyway) and found ****ing filler covering a lovely bit of arse end action ****ing lazy bastard bodyshop bastards
so bought this, dont think that ****er will rust .
not cheap at £145 but on a full road trim car every little bit of weight saving counts
Old 25-04-2008, 07:02   #69
Benn's Avatar
I like your thinking with the boot lid..
save paying to get it semi smoothed too..lol
Glad the engines almost there.. ebay hg? sounds one to be warely of..
Old 25-04-2008, 14:42   #70
Drives: around looking Cool!
But surely you want to save wieght on the front?!?!? Not the back, you need to move the weight from the front to the rear.... you should buy a lead boot
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 25-04-2008, 17:23   #71
need weight over the wheels to get the power down, ive already shaved a few kilos out at the front to compensate for the extra weight of the turbo and cooler, will probably get a FG bonnet too but not just yet.
Old 25-04-2008, 21:27   #72
To think i did see this car in XE form, I cannot wait until LET form!!
Old 25-04-2008, 23:29   #73
me neither keep losing interest, walked to the shop the other day and an astra gsi turbo launched off the lights, the sound was beutiful, my interest was instantly fully restored , was really pissed off when the gasket ripped but kindof glad it did it then rather than at full boost lol.
got my new HG today, got a proper decent BGA item, touch wood ive never ever had a single bad product from them and never had one of their gaskets let go so should hold up.
depending on weather in the morning that should be fitted with the head then all i need to do is time it up and remount the rad then i can get on with the new exhaust.
got a nice Bailey DV26 for it too dont know how quick thatll get old but i kind of like the distinct noise.
also need to get my spray gun back from my mate as i need to redo the back bumper thanks to some inconsiderate **** over christmas ploughing it and driving off also the new tailgate.
Old 25-04-2008, 23:30   #74
Drives: admin up the wall
Any idea on the weight saving for the boot lid chief?
You can't moderate me, I am far too important!
wayne451 is offline   Reply With Quote
Old 25-04-2008, 23:37   #75
it says its around 5kilos (weight of new bare fg one) so when i cheesewire the glass out ill do a comparison, gotta remember ill be ditching the lock the wiper the motor the CL just going the have the bottom latch and have it on a popper.
Tags
c20let, conversion, corsa, sport, turbo
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/347958-my-corsas-evolution-xe-let.html
Posted By For Type Date
BTTOS - View Profile: Kev_mk3 This thread Refback 18-12-2008 00:50
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
