Page 22 of 23 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 526 to 550 of 556
Thread: My Corsa XE to LET to XEV Project
  1. #526
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Re: My Corsa XE to LET to XEV Project
    I thought you got me the 56.0 setup lmao I've just checked both my ECUs and they are both 56.5 lmao
    the scrap yards I go to are cheap but they don't usually have the keys for the cars, I mean I can try, I take it you're missing dual tract sensors are causing problems.
    MIGClub Member giles473937's Avatar
    Jun 2003
    Portsmouth
    1.9 CDTi 190
    Gaz, I'm dissappointed - you could have had my 56.5 all along with the Superchip / customer key and key / transponder. Still available for 90 notes posted if anyone's interested - you all know it makes sense with front door locks and boot lock / extra key for £110 - bargain
  4. #528
    Nov 2009
    Ruskington, Lincolnshire
    Corsa B X20XEV
    yh i did get you 56 but didnt twig until i sent it cus i realised it had no egr, should of known because i had the none egr bracket off it
    yh 1 of the faults is too do with variable inlet and the other is to do with secondary air pump relay which is another thing i dont have, ive checked diagrams and what not and powered the pins up, light goes out then comes back on again though and because the eml is on its in limp home mode
    so i need 56 for it so it doesnt have them sensors in its system
  5. #529
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Giles - it was mainly the loom I needed, I've got a 2 56.5 ecu sets now lmao out of interest did yours have EGR?
    Liam - are you sure the SAI is putting it in limp? sure it's not something else, I'll see what I can turn up if I get to the yard.
  6. #530
    Jun 2003
    Portsmouth
    1.9 CDTi 190
    Quote Originally Posted by Gaz86 View Post
    Yes, had EGR but ECU / EGR and loads of other stuff removed when I switched to TBs / DTA ECU.
    Good thing with having the superchip programmed in the ECU was that every time I did a mod I could take it to the RR and get the program optimised to get better power gains.
    In the early days £250 really well spent, especially as the 56.5 is flash programmable - downside now is that there's no chip to remove (damn!!)
  7. #531
    Nov 2009
    Corsa B X20XEV
    cheers
    yh i had it plugged in on tech2 once i wired the 16 pin plug in, it came up with camsensor no signal, so changed the cam sensor and that cleared the code down for that and it also flagged up, secondary air pump relay low voltage, inlet switch over valve low voltage
  8. #532
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    I take it you don't have the wiring for it in your loom either I'll see what I can find but can't promise.
    just popped into vauxhall and picked up my block pipe and sort out the trade club for the region, I might have a go at fitting it later, not too sure hows it's gonna work in situ lmao
  9. #533
    Nov 2009
    Corsa B X20XEV
    yh the loom doesnt have the wiring for them lmao
  10. #534
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    decide to tackle the rear pipe today, I was going to try from underneath but it seems a bit silly as these engines are too easy to work on in the corsa bay so went in from above.
    started by stripping the inlet off, went from this
    to this within about half hour
    here's my frankenpipe at the rear and you can see it looks so much easier to acess from above
    this thing cost around £9 so I had to get it right first time, which I didn't
    it went in a bit squiff and then fell out, so I bashed it part way into a spare block I have to start it off which did the trick and let me locate it better so I could knock it in true.
    built it back up and filled with coolant, there's still a couple of pipes I want to change around but for now it's working properly and no more leaks!!
  11. #535
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    few bits and bobs
    downpipe before I welded it up
    started working on my compact boot build too as it's getting too cold and ****ty
    might pop to B&Q tomorrow afternoon get some MDF and start the exterior and face of the enclosure.
  12. #536
    Dec 2009
    Llynfi Valley
    Corsa B
    Thats good work, your talented all round i think Gaz haa. Flexi looks lovely and shiny too
  13. #537
    Good work dude.
  14. #538
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    quick update, while I've been "ill" and relegated to the use of only one arm I haven't been able to do much.
    I can wield a jigsaw though! so I got cracking on the sub box I started on aaaaaages ago.
    It's pretty much finished, there's a few inperfections that I'll need to sort and I've still gotta make a cubby hole down the side for the mini battery and glass that in but the general idea is done and dusted, I think it looks pretty sweet TBH.
  15. #539
    MIGClub Member corsadonk's Avatar
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    I've been wondering what happened to you. You ok?
    Good work.
  16. #540
    Love that, looks awesome.
  17. #541
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    So much commitment
    Are you carpeting that sub box or you gonna spray and lacquer it in arden blue? Benn would.
  18. #542
    He's right, i would.
  19. #543
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Mike - I'm good, had surgery on my shoulder
    Ben - at first I was going to carpet it, then I thought it would be a waste and a bitch!!
    Benn - I'm torn between Arden and a deep silver, almost grey metallic similar to the colour of the cone.
  20. #544
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Hopefully Benn approves lol
  21. #545
    Oct 2007
    North East
    320bhp Mk3 Astra Gsi
    looks real smart, top work there
  22. #546
    Jan 2010
    Luton
    Corsa B
    That looks sweet mate.
  23. #547
    Oct 2009
    Yateley
    Corsa B 2.0l 16v
    great work on the sub!
  24. #548
    Nov 2009
    Corsa B X20XEV
    looks really good, top work
  25. #549
    Sep 2004
    Nottingham M1 J26
    Any updates on this Gaz?
  26. #550
    How did i miss this?? I love that!
  1. 18-12-2008, 00:50
Tags for this Thread
