Old 04-07-2008, 19:13   #551
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Re: A-2-Drizz Developments
Originally Posted by Fow16v View Post
have you turned the engine over with oil in it? if you have th head will probably need to come off as the oil between the gasket will stop it sealing, ive also had water stop the gasket sealing before to, if you can empty the fluids back out and get an e
airline in there try to get it dry as posible.
also just looking at your lifter and you said you need a new motor, whats wrong with the old motor can it be rewound? or is it a 3 phase?
No as the water leaked out before i even turned it over. But obviously i filled it with oil just before. Oil and water are dropped out now. Havent seen evidence of oil seeping so hopfully itll be ok. In theory i could leave the inlet manifold on the head to lift it off. Just undo the fuel lines couldnt i? But ideally id rather not! Wouldnt the pressure of the head tightning force fluids out? Are you saying use the airline to blow it out now or with the head off?
DRIZZ
DEVELOPMENTS
Old 04-07-2008, 22:12   #552
Fow16v's Avatar
Drives: Astra Coupe Turbo
i was thinking airline with the head on but only posible if there is a visable gap which by the sounds of it there isnt, its posible that the tightening may push the fluids out but i did one before with water on the head and the ****ing thing lost compression accross all four, gotta be worth a try tho rather than taking the head off.
WELSH Member
Fow16v is offline   Reply With Quote
Old 04-07-2008, 23:18   #553
Drizz's Avatar
Yeah well itll have all night to drain so fingers crossed. I may blast it with the airline as we're changing the bolts...
Old 05-07-2008, 14:59   #554
Drizz's Avatar
Well it runs. Need to flush the cooling system as it has oil in it from yesterdays issue so fingers crossed its not from anything else!
Old 05-07-2008, 21:13   #555
Drives: steve!'s bwm :D
atleast the problem has been solved (i hope!!!)...but my god, estate + turbo = the sex...but phail on FWD
nah but seriously, its gonna be awesome something different too
i sendz warningz...i haz uber phailz
volvo - the ultimate battle between rev counter and fuel gauge
Grim Reaper is offline   Reply With Quote
Old 06-07-2008, 09:10   #556
Drizz's Avatar
I flushed it out for over an hour. I think itll need running and flushing over a couple of weeks...
Old 06-07-2008, 14:19   #557
Drizz's Avatar
Re: Drizz Developments
Well the threads been renamed as Andy is moving out
New man joining the realms very soon though!
Old 06-07-2008, 14:25   #558
Drives: Opel Astra 180iE
ahhh - how come?
And who's the new guy?
Kev 180iE is offline   Reply With Quote
Old 06-07-2008, 14:33   #559
Drizz's Avatar
Lack of use apparantly? He was always in my way though
New guy would like to stay anon so you wont be seeing much of him!
Old 06-07-2008, 19:12   #560
Drives: Astra cabrio, Skoda
I always though it a bit odd to store a car in a barn in the middle of nowhere when he has plenty of parking space ay home.
Do you know if you had not have mentioned it I did not notice the thread change titles. I cant even remember what it was called...
MK III Astra 2.0l Turbo Cabriolet (Its sleeping for the winter) Landrover Discovery
Skoda Otavia 2.0 Diesel Elegance
BMW 330 Ci Sport Convertible
Brian Stirrup is offline   Reply With Quote
Old 07-07-2008, 10:21   #561
Drizz's Avatar
Well just took the estate for its maiden voyage!
Revs took themselves up to 6k for a bout 3 seconds but other than that fine. No power steerings a killer though. I need to dig out the correct engine mount so i can connect up the PAS pump.
SO ill sort the fuel pump now!
Old 07-07-2008, 16:01   #562
Drives: Corsa Tbo n Prelude
so what was up with the let then lad to make it go noisey?
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 07-07-2008, 18:59   #563
Drizz's Avatar
Dunno but seems ok so far...
Old 07-07-2008, 19:00   #564
Drizz's Avatar
Well today was a good day. Got it filled up with gearbox fluid, fitted the uprated fuel pump, put it all back together and went for a drive. Think i might have a boost leak but ill deal with that. Then as that was under its own steam time to play with the fiesta
John and Scott came round, and Elmo couldnt resist getting involved:
More tomorrow
Old 07-07-2008, 19:04   #565
Drives: around looking Cool!
why you cutting the floor?
(")_(")Station once said: Nowden. u nd 2 gt a bgr njin, dat way u cn get rid ov dat shttee njin u av an den stop torkin like a cumpleet chav. To some complete idiot!
Old 07-07-2008, 19:18   #566
I spy a RWD project....top stuff Drizz!
ultra-vaux is offline   Reply With Quote
Old 07-07-2008, 19:23   #567
J Sabo's Avatar
Drives: Mk3 GSi-T/SportiVan
in the above pic it looks like a Corsa subframe so.....
MID-engined Fiesta!
Astra GSiT - 285bhp - 325lb/ft torque
J Sabo is offline   Reply With Quote
Old 07-07-2008, 19:32   #568
Drizz's Avatar
Vectra subframe
Old 07-07-2008, 19:42   #569
seriously, what you doing cutting the floor?
Old 07-07-2008, 19:43   #570
Drizz's Avatar
erm?
Old 07-07-2008, 19:45   #571
J Sabo's Avatar
weight saving?
Old 07-07-2008, 19:48   #572
Drizz's Avatar
Originally Posted by J Sabo View Post
weight saving?
yeah thats it
Old 07-07-2008, 20:09   #573
Thought the Fezzy was gunna be a mk1 xr2 concours car?
Old 07-07-2008, 20:12   #574
Drizz's Avatar
Whatever gave you that idea? Its a 950 pop plus!
Old 07-07-2008, 20:37   #575
Originally Posted by Drizz View Post
Thats not far off how i want my Mk1. Not touched it for a few days as been sorting the estate.
erm?
Members: 43,212
Threads: 310,610
Top Poster: LEE69 (43,149)
