22-06-2008, 20:30
#526 | | MIGWeb User
Join Date: Oct 2005 Location: london Drives: steve!'s bwm :D
| Re: A-2-Drizz Developments
__________________ i sendz warningz...i haz uber phailz
volvo - the ultimate battle between rev counter and fuel gauge |
24-06-2008, 19:43
#527 | | MIGClub Member
Join Date: Jul 2001 Location: Suffolk Drives: Vectra GSi & A4 1.8t
| Re: A-2-Drizz Developments Lol thanks Grim!
Today was a little mince on the Fiesta. I firstly had to collect Claire so she could take her car home, then i tightened all the ramp bolts, proper tight now!
Then Fiesta time. Got the boot off:
Started threading the loom out:
Then started on the dash:
Then my wheels turned up all done:
And the loom all removed:
Felt good working on the old girl again!
__________________ DRIZZ
DEVELOPMENTS |
24-06-2008, 20:44
#528 | | MIGClub Member
| Re: A-2-Drizz Developments I nearly forgot, this was outside when i turned up:
Porno as fook! |
24-06-2008, 20:53
#529 | | MIGWeb User
Join Date: Jul 2007 Location: lichfield Drives: senator 24v/saxo
| Re: A-2-Drizz Developments that is sweet .
are you after some panels for the fiesta mate as im sure i got some in the lock up from when i had my super sport |
24-06-2008, 20:58
#530 | | MIGClub Member
| Re: A-2-Drizz Developments Yes mate i was going to order a load next week... |
24-06-2008, 21:00
#531 | | MIGWeb User
| Re: A-2-Drizz Developments il have a look for you and let you kno what i got . |
24-06-2008, 21:06
#532 | | MIGClub Member
| Re: A-2-Drizz Developments cheers! |
25-06-2008, 06:47
#533 | | MIGWeb User
Join Date: Nov 2004 Location: Huntingdon Drives: Opel Astra 180iE
| Re: A-2-Drizz Developments That yank tank look nice - take it it's with Emo for welding? or something more creative? |
25-06-2008, 11:25
#534 | | MIGWeb User
| Re: A-2-Drizz Developments is that the whole loom in the fez???  i have more wires in my computer
and that slammed thing looks friggin mint...im assuming its on hydrolics or air ride |
25-06-2008, 12:10
#535 | | MIGClub Member
| Re: A-2-Drizz Developments Kev it was the guy that gave me our ramp popped over to show it off, just got it off the boat. Its on airbags.
Yes thats the whole fiesta loom lol! Front lights, rear lights, 8 fuse fuse box lol the lot |
25-06-2008, 12:45
#536 | | MIGWeb User
Join Date: Mar 2002 Location: Reading, Berkshire Drives: Omega & 1.8 Corsa B
| Re: A-2-Drizz Developments Lol looks like our setup! |
25-06-2008, 18:05
#537 | | MIGClub Member
| Re: A-2-Drizz Developments First job of the day was to lift the estate up a bit as it was too low, then i started on my headlight conversion. I wanted tinted lights with HIDs and as they dont work properly in standard lights, i sacrificed the insides of a set of calibarge lights, heres work in progress:
Need a lot of work yet. The i fixed the ramp! Yippee, sussed out our cable issue, all fits and taught now. Just a motor needed now!  |
25-06-2008, 19:33
#538 | | MIGWeb User
| Re: A-2-Drizz Developments you have a pm |
01-07-2008, 16:54
#539 | | MIGClub Member
| Re: A-2-Drizz Developments |
02-07-2008, 20:20
#540 | | MIGWeb Moderator
Join Date: May 2006 Location: beddau, South Wales Drives: mk3 astra
| Re: A-2-Drizz Developments liking the headlight conversion for the mk3 fella, i will be interested in seeing how that turns out. |
02-07-2008, 20:34
#541 | | MIGWeb User
Join Date: Mar 2007 Location: Margate Drives: Cav 3 1600
| Re: A-2-Drizz Developments Quote:
Originally Posted by Drizz | Sorry for the silly question but the name Dantum cars seems so familiar.
Did you sell an Astra Decat pipe, tinted windows and a pipercross induction kit top some lad with a black sri mk3?
Thats me  sorry if im wrong but I do recognise the name.
__________________ Man who walk through airport turnstile sideways going to Bangkok |
03-07-2008, 07:33
#542 | | MIGClub Member
03-07-2008, 17:21
#543 | | MIGClub Member
03-07-2008, 21:10
#544 | | MIGWeb User
Join Date: Oct 2005 Location: ThickFord, Shrops... Drives: around looking Cool!
| Re: A-2-Drizz Developments Is it tomorrow yet |
04-07-2008, 15:43
#545 | | MIGClub Member
| Re: A-2-Drizz Developments Nope, wont run for a while yet. Was about to turn the key and found an issue. Not happy at all. |
04-07-2008, 15:48
#546 | | MIGClub Member
Join Date: Jan 2005 Location: In The Woods Suffolk Drives: Kadett 200ts
| Re: A-2-Drizz Developments Wats wrong with it? |
04-07-2008, 16:11
#547 | | MIGClub Member
| Re: A-2-Drizz Developments Was supplied the wrong head bolts. They were too long. So although theyre torqued down theyre not holding the head. Filled the header tank with water its poured out between the head and block. Took plugs out, pistons are wet, so might have to come all apart again. And thats not even the original problem. So could do all this and start it and still be another issue. Awaiting suppliers to call back with regards to replacement parts.
Perry has said if we replace the headbolts for the correct ones and torque it down, then turn it over without plugs, water should disperse. As it hasnt actually started yet we might be ok. And with any luck most has escaped externally. Get the water displaced, then run it, drop oil and start again. |
04-07-2008, 17:27
#548 | | MIGClub Member
| Re: A-2-Drizz Developments Well heres the day in pics.
Started on the boost pipes. Measured all up:
So while i was waiting for it to be made i get the rad and oil cooler on:
Then fitted the pipe:
Got all the filter side connected up and all the vacuums on:
The filled it up with oil, all good no leaks, then disaster struck. Poured the water in and out it came from between the head and block. Thats when we realised the wrong headbolts were supplied. So dropped the oil out with some water too:
Took the plugs out and dipped in a piece of paper and no dampness on the pistons so hopefully its just mixed in the oil ways.
Tomorrow then we will fit the new head bolts and torque them up, turn it over without plugs in to see if any water appears then plugs in and start and see what happens...
Big bugger to say the least. Cost me a fair bit as the suppliers wont help me out as I should have known which bolts i should have had and theyre mistake is my problem bizarrely. So with any luck, and theres not been much of that, i might run tomorrow morning. |
04-07-2008, 18:52
#549 | | MIGClub Member
Join Date: Feb 2006 Location: Pontypool, S.Wales Drives: Astra Coupe Turbo
| Re: A-2-Drizz Developments have you turned the engine over with oil in it? if you have th head will probably need to come off as the oil between the gasket will stop it sealing, ive also had water stop the gasket sealing before to, if you can empty the fluids back out and get an e
airline in there try to get it dry as posible.
also just looking at your lifter and you said you need a new motor, whats wrong with the old motor can it be rewound? or is it a 3 phase?
__________________ MIG Performance Vauxhalls WELSH Member |
04-07-2008, 19:00
#550 | | MIGClub Member
| Re: A-2-Drizz Developments Its 3 phase and there is no 3 phase supply. It could be rewound for single phase but its cheaper just to buy second hand or even new
__________________ Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!! |
Members: 43,212
Threads: 310,609
now!
of being a MIGClub Member.
