Page 10 of 112 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 60 110 ... LastLast
Results 226 to 250 of 2793
Thread: Drizz Developments
  1. #226
    Suffolk
    335d E90
    Yeah all done!
    DRIZZ
    DEVELOPMENTS
    MIGClub Member kevseymour's Avatar
    Nov 2004
    Stevenage
    Vectra SRi
    Quote Originally Posted by Spankee View Post
    Good progess dan mince mince..... ..did kev finsh of his brake lines.....
    After the 2 hours of swearing and fighting with the 1st one, the 2nd one went on in 30 seconds!
    Then i got the brakes bled and that put a finish to the rear beam change, finally!
  4. #228
    Suffolk
    335d E90
    Yay!
    DRIZZ
    DEVELOPMENTS
  5. #229
    Suffolk
    335d E90
    Well went and got a jerry can of petrol this morning and headed up there. Put the fuel in, took the battery off the Turbo and tried it. Turned over but thats it. Swapped the leads and coil off the turbo, and nothing still. So wired fuel pump up to permanent live and stil nothing, so wired ECU switched live to permanent and boom. Fired up straight away. So i sourced a switched live and connected it up, reconnected fuel pump wiring correctly and set about on other bits. Put a strut brace on:
    It was making a funny noise and i realised the atlernator earth was rubbing on the pulley so moved that out the way:
    Got the brakes on and the wheels on. Loving theyre look. Need to put the rear springs on now to see how it sits:
    Andy turned up in the White one with only third. We adjusted the linkage and lost second, so left it till tomorrow till we have the energy to make miniscule adjustments to get it right. Steve turned up and fitted his tinted headlights and GSi grille, i put the bonnet back on the estate, put the twin horns back on and we went home.
    More progress tomorrow....
    DRIZZ
    DEVELOPMENTS
  6. #230
    Suffolk
    335d E90
    Also anyone know what these are?
    DRIZZ
    DEVELOPMENTS
  7. #231
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    theyre multiplugs mate lmao
    think they are for the headlight adjusters
  8. #232
    Suffolk
    335d E90
    No theyre not anything headlight area..
    DRIZZ
    DEVELOPMENTS
  9. #233
    Jun 2003
    clacton on sea
    corsa c,125 dragster
    Quote Originally Posted by Drizz View Post
    The 1.6 gets collected and goes:
    could of said you was gonna take a pic and you could of took a better one
    still got the engine in the back of my car cant be bothered to lift it out lmao
    steve
    click here 2 c my old nova
    new WIP nova c16xe will get pics up soon
  10. #234
    Suffolk
    335d E90
    LOL as if you have. Lazy sod lol
    DRIZZ
    DEVELOPMENTS
  11. #235
    Jun 2003
    clacton on sea
    it was still in there,took it out today as i put high lift cam and got my nitrous filled up so i wanna see how it goes now lmao
  12. #236
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    looked a tidy nova you had there mate! i was in the van lol
  13. #237
    Jun 2003
    clacton on sea
    Quote Originally Posted by rc View Post
    van? didnt even see one lol
    its not as tidy as u think,goes well for a 1200 tho
  14. #238
    Suffolk
    335d E90
    Well, arrived today and heres how it looked:
    Pilfered some bits off the turbo:
    And got it looking like a car again:
    Then onto the rear springs:
    Good job im changing them as one had snapped:
    Old Vs New (half the size lmao)
    Back down but a bit too low (best put them up for sale then )
    So took them off and put some others on i had (much better!):
    But it wasnt without trouble (it hurt )
    Andy adjusted his power steering belt:
    Im so loving the way it looks on the wheels:
    Then oil, water, linkage adjustment and:
    Hell yeah! Loving it. Need to get my mate opposite to join the manifold to the STD system, get it booked in for MOT and away we go. Just forgot to bleed the brakes which was scary lmao!
    DRIZZ
    DEVELOPMENTS
  15. #239
    Nov 2004
    Stevenage
    Vectra SRi
    Looks good - the JL's will bring the back down bit more.
  16. #240
    Suffolk
    335d E90
    Theyre not going in there, thats what the Vecs for!
    DRIZZ
    DEVELOPMENTS
  17. #241
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    liking the estate on those rims lad..
    www.wix.com/vxlgsi/zxr-750-r
  18. #242
    Nov 2004
    Stevenage
    Vectra SRi
    Oh yeah, forgot about that!
  19. #243
    Suffolk
    335d E90
    Unsure on whether to get my spare GSi frontage painted or not...
    DRIZZ
    DEVELOPMENTS
  20. #244
    Suffolk
    335d E90
    Well came in today and was greeted with this (im loving this car at the mo ):
    Then over to Elmos for the exhaust to be welded up. He said he'd have a go at the locking wheel nut i couldnt shift too. Welder had to be used on it:
    And then one of his creations came back cos it was a tad low and needed lifting:
    So now the exhaust is welded up, the 4th alloy is on, brakes are bled (need doing again though) and its filled with oil and water i started her up. Tappety to hell. Thought sod it lets have a drive. Came back, silent Left it and started it again and no tappety tap so all good. Got it up to temp and helped the water round and it all seems good. Just got to get it MOTd and away we go. It was steaming out the exhaust for a while until the 2nd drive and it went. So possibly HG is on its way out but as its been sitting for nearly a month it might just have needed a clear out. Time will tell. It does go really well actually. Looking forward to the open road test drive. Probably have a night off tomorrow so more updates over the weekend i reckon....
    DRIZZ
    DEVELOPMENTS
  21. #245
    A2!
    A2! is offline
    MIGClub Member A2!'s Avatar
    Jan 2005
    In The Woods Suffolk
    Astra Turbo Audi A3
    Is that my turbo system your cutting up lol. Hope you didn't cut the down pipe at all.
    Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!!
  22. #246
    Jul 2000
    Braintree, Essex
    GTE/Mondeo
    looks good magpie..opps sorry i mean dan lmao now get the inside stripped... hardcore
  23. #247
    Suffolk
    335d E90
    Quote Originally Posted by A2! View Post
    Yeah, you said to use it??
    Only cut it where the downpipe was welded to the decat so it can be used for an astra again...
    DRIZZ
    DEVELOPMENTS
  24. #248
    A2!
    A2! is offline
    Jan 2005
    Astra Turbo Audi A3
    Messing with you matey Yeah only need to keep the down pipe as we know how handy they are lol
  25. #249
    Suffolk
    335d E90
    Right well todays mince wasnt the best but the issues will be dealt with.
    First was side repeaters. The old ford ones hanging out of it were no good so thought id get some new ones:
    Then one rear cluster had a hole in it so changed it for one i had in stock:
    Then a snack and a brew:
    The gear knob that was in it when i got it was rank so swapped it and the gaitor for another stocked item:
    It also had a random thing on the dash so that came off too, just need to clean the dash to get rid of the marks:
    Then noticed i had a bulb out in the clock so set about changing that, then realised the heater controls werent illuminated either:
    So took it all apart:
    Got the bulb holder out, shut up shop and nipped down the factors, got the right bulbs and came back. Put them in and the were very dim. So thought oh welltheyll do for now and ill source some LEDs at some point so put it back together. Checked how dim the were when complete and you could hardly see them, checked the bulbs packaging and they said 24 volt. Bloody woman! She gave me the wrong ones. So ive taken it apart again and left it till tomorrow when i pick up the 12 volt ones.
    Now next point was an issue. Ive ordered new plates so set about taking the old one off. As i went to undo it it fell off. And i was left with a nasty site. So i picked away some more and it looks like this:
    Not good. So its going back to Emersons (who done my exhaust) to have the bit cut out and a plate welded in and undersealed. Itll be behind the plate so doesnt have to be body coloured. The front wings are rusting too so i have replacements for them. Thankfully the underneath looks solid, so we shall see when its MOTd in the week. Might be taking the XE out again lmao.
    Anyhow cracked on with another job. Debadging. I was going to keep the 1.6 16v badges but they were loose anyway so ill get replacements. Griffin was manky too so that came off ready for a replacement too:
    Also thought about the rubbing strips too. Do i remove them or keep them. I quite like them so havent removed them just yet, and toyed with badge options:
    Not sure yet. Everyone close to me knows my head ticks a hell of a lot and tonight i was thinking of stripping the Saloon out and tracking that as a LET, and putting all the leather and such like in the Estate for daily duties. But i have a Vectra DTi CDX coming soon so is there anypoint to 2 comfy cars? But if i strip this ill still have the Turbo as a comfy car. So im stuck with what to do at the mo...
    Anyway heres my plates:
    So any thoughts on my dilemma lmao?
    DRIZZ
    DEVELOPMENTS
  26. #250
    Suffolk
    335d E90
    Its gona get washed and polished once its roadworthy too by the way lmao
    DRIZZ
    DEVELOPMENTS
