Old 07-02-2008, 20:48   #26
Drives: corsa turbo, skyline
what do you mean mate?
jamie gsi16v is offline   Reply With Quote
Old 07-02-2008, 20:51   #27
i get you now mate, it came like that, i bought 2 and there exactly the same, so im guesing it should be like that?
Old 07-02-2008, 21:01   #28
Drives: a van
have a look at this mate, sump leak section.
http://www.max-boost.co.uk/max-boost....htm#sumpleaks
it may prevent you problems later on if you do bend it.
rudd86 is offline   Reply With Quote
Old 07-02-2008, 21:04   #29
lol "it should clear them but you never no" so do i go through the hassle of removing the sump bending that plate and refitting or not?
Old 07-02-2008, 21:09   #30
Drives: a van
aparently arp's touch sometimes so I was told, although mine didnt touch I bent it anyway.
Old 07-02-2008, 21:12   #31
looks like the sumps coming off again tomorrow lol cheers mate
Old 07-02-2008, 21:13   #32
Drives: a van
spin it over on the starter or by the crank pully bolt, you will know if its catching I would have thought
Old 07-02-2008, 21:15   #33
rc
rc's Avatar
Drives: 359.9bhp astra :D
progress looks very good mate! very nice corsa, engines goin to a good home!
but what the hell had happened to the calibra lol! whats the plans to do with the calibra now then?
re: sump gasket, i had this exactly not long go, already had arp's fitted, fitted a new sump gasket to try and sort leak, filled up will a new load of mobil 1, and tap tap tap tap, all had to come off again!
rc is offline   Reply With Quote
Old 07-02-2008, 21:17   #34
calibra sold on ebay for 620 mate only paid 700 for it lol so c20let engine and box came for 80 quid lol, yeah sumps coming off tomorrow, cheers for mentioning that rudd86
Old 11-02-2008, 22:48   #35
another update, changed my steering rack today, recieved my poly bushes and started fitting a few.
rack removed
new rack against old one
poly bushes
Old 11-02-2008, 23:17   #36
Drives: Corsa Tbo n Prelude
are they D flex? hope they gave you the right ones cos they fecked my order right up!
Bring back the power of LET
vxlgsi is offline   Reply With Quote
Old 12-02-2008, 07:44   #37
yeah d flex and they are all correct and fit very well, looks like you were abit un lucky, i think beardy deals with them and hes happy too
Old 12-02-2008, 09:05   #38
Drives: single turbo rx7
nice project
there is a guy in derby some where who builds crazy LET's carnt remember his name now though.
how did you manage to get the calibra sooo cheap??
i miss my vauxhalls breaking down
astragsi is offline   Reply With Quote
Old 16-02-2008, 16:55   #39
who are you on about in derby mate as i have not heard of anybody too special with them tbh
Old 16-02-2008, 17:37   #40
will try and find out for you.
Old 25-02-2008, 18:19   #41
not updated for a while but engines now fully built up after finally recieving my astra vxr injectors fuel rail adaptor and fuel pressure regulator then put the engine in, hadto get pirtek to make me a pipe up for my electronic power steering. engine went in fine, fitted it without the turbo and manifold then put that on after engine was in place. cut and welded the gear linkage and got all 6 gears first time i set them!!!!
moved the rad forward and across about 2" to get the pipes from the intercooler to fit each side, fitted a 10" slimline spal fan.
fitted all my front tie bar spacing blocks to clear the f28 6 speed gearbox
few pics
bottom arms spaced out
used the m-tech conversion parts
new injectors
astra vxr blues
regulator with gauge
engine in place
new cometic exhaust manifold gasket
intercooler in place
butchered an old bumper
weekend work included
fit carbon bonnet
fit gsi fogs in front bumper
painted bumper black
washed and hoovered
fitted turbo timer
jobs too do-
relocate battery into boot
mount saxo electronic power steering pump where battery was and wire up
fit new 2.5" scorpion exhaust made from escort cosworth system.
pick up some vmax evo 5 305bhp chips
buy a dash 31 actuator
and fit a boost controller
then hopefully should achieve 300bhp
then just need to find some 16" track tyres that will go on without scrubbing!
couple of pics from today
Old 25-02-2008, 18:56   #42
Drives: corsa gsi <soon>
simply sexual
gsi_sep is offline   Reply With Quote
Old 25-02-2008, 19:03   #43
Drives: 16v Nova, Astra TD
Sweet
LongLiveTheNova is offline   Reply With Quote
Old 25-02-2008, 19:45   #44
DaveB's Avatar
Drives: Corsa XE with TBs
matt black bumper= hardcore
Wedding Photographer and Portrait Photographer in West Yorkshire - www.2007bc.co.uk
DaveB is offline   Reply With Quote
Old 25-02-2008, 20:02   #45
Drizz's Avatar
Drives: Vectra GSi & A4 1.8t
Hows the top hat done? Looks like a fatter standard one, not aftermarket?
DRIZZ
DEVELOPMENTS
Old 25-02-2008, 20:37   #46
Drives: 2 fast,12 points eek
Top build going on here mate, recognise a lot them bits too
www.chrisastleymotorsport.com For all your Conversion, Rebuild, Fabrication e.t.c.
eBay shop: ChrisAstleyMotorsport
If there is something you need PM me or call 01257 262565
rallyman is offline   Reply With Quote
Old 25-02-2008, 20:40   #47
dearing5's Avatar
Drives: C20LET 5dr corsa
nice one mate!!
dearing5 is offline   Reply With Quote
Old 26-02-2008, 21:21   #48
dont no how its done mate, i always thought it was a standard let top hat until i stood it next to one, its gm stamped and as the turbo cover bolt holes but im unsure where it was ever made?
yeh cheers mate all seems to be going well now, apart from them male long head bolts were too long and bottomed out in the block not clamping the head gasket fully and i hadto take the head off again once it was all built up and in the car ready to fire up, just noticed it was wet down the front of the block from under the head just before i turned the key, lucky hey?
Old 26-02-2008, 21:41   #49
looking good mate, you over fueling with the vxr injectors?
sach is offline   Reply With Quote
Old 26-02-2008, 22:57   #50
hoping not mate, but better than running lean? i have it set at 2.5 bar with the vacume off.
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
