LinkBack (1) Thread Tools
Old 21-01-2008, 16:45   #26
Drives: Astra coupe turbo
Pretty much, i think the only thing that requires changing is something to do with the oild feed but it is very minor. Just need tosave £600 for the remap and i'll bung it on.
mattcoupturbo is offline   Reply With Quote
Old 05-07-2008, 16:01   #27
Re: Matt's Coupe Turbo
Its been yonks since i last updated, mainly because nothing has really happened due to buying my first house, which cost me an arm and a leg. Anyway a while ago i purchased some tatty alloys to replace mine so got them refurbed and have now finally saved up for the toyo tyres.
You'll also notice the M32 gearbox sat there, thats a long term project as well but will hopefully be on by the end of the year at some point. Just been adding a few layers of polish to the alloys before i cover them in poorboys wheel sealant and then its off to have them fitted. The current turbo alloys i have will be for sale soon after that, they are ver kerbed though.
Old 06-07-2008, 15:25   #28
Regional Co-ordinator
Benn's Avatar
Drives: A shineeeey Nova
Wheels look nice.
Old 12-07-2008, 10:04   #29
Right got the wheels and tyres on this morning very pleased with how much nicer than the scabby kerbed old ones.
Thats it really, got to lay some laminate flooring now, deep joy.
Old 17-07-2008, 20:31   #30
Right take, these....
And with a quick bit of cutting and fiddling you get this.....
Just got to wait for the glue to dry then i can pop out to the car to check the viewing angle is find then its time to smash a small amount of fibre glass and filler on.
Old 18-07-2008, 17:32   #31
So following on from yesturday i went out this morning to check that the holders lined up alright in the position they are in and they, although the bottom one is ever so slightly cover its very minor and can still clearly see the gauge. So got about fibre glassing it.....
Once that was done and all dryed out, out came the sand paper to take out all the rough edges and bumps. Ended up with this...
Needs a little more work on the one side but will be ready for a bit of filler soon enough. Then painting
Oh and a little tip, don't sand fibreglass with a top off, its itches to buggery
Old 23-07-2008, 14:50   #32
So got some fillering done today, plus plenty of sanding.
Needs a little more more work and it'll be ready for painting and fitting
Old 23-07-2008, 17:28   #33
Benn's Avatar
Good work,
Old 23-07-2008, 17:43   #34
cheers Benn
Old 11-08-2008, 16:22   #35
Why You Should Never Leave Jobs
Well just to give a bit of background information to this, thought i had a problem with my alarm so remove my inner wheel arch trim to get at it. As it was a mad rush job i left it tucked in afterwards as the clips had fallen out into a drain and the gutter. At the time i just thought i'll order some tommorrow jobs a gooun. Except i forgot and never ordered the clips. Cue me driving along the motorway last night at what would be a decent rate of knots when a horrid sound started come from the wheel arch.
Pulled over saw the trim hanging out, realised i was a tit and tucked it back in to the arch, making a mental note to get clips. Then it happened again driving along the motorway back home today, except it was light this time and when i got out to sort it i saw the damage it had done......
So now something that should have cost me a couple of quid will no doubt cost me a couple if hundred to get resprayed. To say im fuming is the biggest understatment ever. Feel like actually punching myself in the head. Ah well the bonnet and front bumper need respraying anyway so i guess it wil force me into doing it.
Rememeber kids, if there is a job that can be done, don't play xbox live instead, get your lazy arse outside and do it, small jobs become big jobs in no time.
Old 11-08-2008, 19:48   #36
Fow16v's Avatar
Drives: Astra Coupe Turbo
shame on the damage mate, saw you yesterday about 2 o clock i was going past the speed camera into newport you were going the other way car looked real nice
WELSH Member
Fow16v is offline   Reply With Quote
Old 12-08-2008, 12:07   #37
Administrator
Andy_L's Avatar
Drives: Cavalier 1.8
Oops!
Andy_L is offline   Reply With Quote
Old 13-08-2008, 02:47   #38
Was that you in the silver corsa that beeped me and waved Fow?? Didn't see you if not. need to get my arse into gear with this car, so much that i want to do it but funds holding me back.
Old 13-08-2008, 08:55   #39
Fow16v's Avatar
yep that was me i beeped and you looked the opposite way lol
Old 13-08-2008, 09:48   #40
Took me by complete surprise. I'd not long got up Corsa looked tidy.
Old 15-08-2008, 10:30   #41
New headunit
My new headunit arrived yesturday and as i had already sold the previous one it went striaght in.
Needed to run the Ipod cable somewhere though figured the small draw in front of the fuse box would make an ideal place for it. So cut a hole in the top of the draw to run the cable through.
and sat in the car all done
Old 18-08-2008, 17:40   #42
Finally got a new centre console and got rid of the comedy taped on gauges on the old one. Went to the breakers and managed to pick up this lot for a bargin £10...
So chucked on the new inner wheel arch trim, needed fiddling with was from a lower spec model so couldn't fit the brake ducts without drilling a new hole for the screw. Got all the new centre console stuff in too, looks much better now, never really liked the grey stuff.
Old 12-09-2008, 17:00   #43
Finally decided to sort out my oil leaks, plus the regular oil/filter change. Had a few other things to change like the tc surrround in the dash. Here's everything i needed to change....
First thing first get the car up on the stands...
Undid the sump plug which need changing as it thought it was leaking. So while the sump was draining i changed the pollen filter, by christ mine was filthy, as you can see....
The pile of crap in front of it is just a small portion of what came out of it, not to mention the load of stuff i pulled out from the slot. New one back in...
Also sorted the dash surround so the whole thing is black now, looking much better than the grey stuff if you ask me.
But then we get to the crux of my problems. After fitting the new sump gasket, i changed the copper slips in the oil feed return from the turbo which was leaking.
But now afterwards it is STILL BLOODY LEAKING. Noticed in another thread someone mentioned that the return pipe itself gets porous? is this a common problem? also on the off chance someone has changed one do they have a price of it? Also got another leak from the other side the engine, no idea where it is coming from so need to investigate this.
Old 18-09-2008, 11:32   #44
Finally finished my A pillar gauge holder. But if im brutally honest its nowhere near as good as i'd like, mainly because i got sick and tired of sanding the fecker lol. Now its sprayed satin black it doesn't look too bad but close up you can see the small defects, but thankfully nobody will be close to it due to me being the driver ha ha. Anyway here's some pics....
Once the paint has dryed properly it'll be getting chucked in the car, only have one working gauge at the moment but shouldn't be too long until i've saved enough for the additional one.
Old 18-09-2008, 13:05   #45
Drives: Fiesta XR2i 16v
Some nice mods you've done there. Wasnt keen on the engine bling IMO, bit too much shineey!! Black dash insert looks good, like the way you have hiddedn the scangauge (for the sensors i presume?!) in the ash tray.
Lewis Hamilton - Vodafone McLaren Mercedes - FIA F1 World Champion 2008
Still Building a valver nova...
Pete_58 is offline   Reply With Quote
Old 19-09-2008, 12:54   #46
fitted the A pillar cover back in today, managed to slightly damage it too but thankfully that is in a place that isn't visible. But on the whole now its in the car i don't think it looks too bad.
Also sprayed the oppositte pilar cover so it all matches up.
Old 19-09-2008, 14:33   #47
Looks good, but you've got a gauge missing. Seriously, on your oil leak, was either of the copper washers damaged? this maybe the cause of your leak?
Old 19-09-2008, 15:41   #48
davie_slim's Avatar
Drives: 1.6 16v Sport
my mate sells gauge holders on astra sport that means you just remove the wee storage area under the heater switches and you can have 1-2 or 3 gauges on that space, they look really good as well
david
davie_slim is offline   Reply With Quote
Old 19-09-2008, 16:25   #49
david
Seen them, but don't think its a very good position for line of sight, with this i can read the gauge straight away without taking my eye of the road. Plus i don't particulally like the cd holder versions.
Old 19-09-2008, 16:27   #50
I replaced both the copper washers so i now think its down to the face of it where the return attaches to the block, need to get under and take it all and have another look.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/342919-matts-coupe-turbo.html
Posted By For Type Date
"Žaibo Rato" klubo forumas • Temos rodymas - mOS'o Bertone Coupe This thread Refback 04-01-2009 12:56
Members: 43,212
Threads: 310,609
Top Poster: LEE69 (43,149)
